#631 | |
Road-hole
Drives: 2013 Whiteout FR-S
learn adobe inventor...
Jaden |
#632 | |
Resident Gear Head
They also use a circular off the shelf throttle body which is smaller than the opening of the port on the head so you build velocity then lose it before it enters the head. It's almost like drag racing and hitting peak boost then your wastegate dumping it then hitting peak boost over and over surging.
Subaru BRZ/FRS Facebook News and Tech Page
My FB Build page CLICK AND LIKE! Twitter and Instagram @misairubrz |
| The Following 3 Users Say Thank You to celek For This Useful Post: |
#633 | |
Drives: Q5 + BRZ + M796
#634 |
ft86club resident b-boy
Drives: Yamaha R3, moonslate 2018 GT Black
Interesting. Dunno if you know the answers to these yet or not but, what are you going to use in place of the factory maf? Will your setup require an aftermarket full standalone ecu?
#635 |
Resident Gear Head
speed density tuning with Ecutek
#636 |
Drives: UK GT86
Not Alpha-N? It is possible with EcuTek
Would possiblt run better and just have SD for idle etc.
.: Stealth 86 :.
#637 |
| The Following 2 Users Say Thank You to fika84 For This Useful Post: | Ultramaroon (01-23-2018), yberther (01-22-2018) |
#638 | |
Road-hole
adobe inventor allows you to choose the output format...
Jaden |
| The Following User Says Thank You to Jaden For This Useful Post: | Ultramaroon (01-23-2018) |
#639 | |
Take it from me, machinist get REAL mad if they run your code and it rapids the tool into the part or part holder... replacing bearings isn't cheap.. |
| The Following User Says Thank You to fika84 For This Useful Post: | Ultramaroon (01-23-2018) |
#640 | |
Road-hole
you're not understanding me.
I'm sure not all of them could possibly be covered, but a vast majority of them are. If you ask your machinist what controller they are using, you can check if Inventor has the capability to output in that format. Jaden |
#641 |
not playing cards
Ok, guys. Please allow me to mediate.
1. Let's agree that Adobe Inventor has a comprehensive manufacturer-specific g-code library. 2. It's up to the machinist to verify any code before running it. Even if you and I were the best of buddies, I would still test the shit out of any code you handed me and would expect you to do the same. That's just being a grownup doing grownup stuff. 3. Unless it's a super simple part, the machinist will probably disagree with some aspect of the code because he likes doing a certain thing his way on his machine. I would offer the machinist an export as a courtesy only after discussing my drawings with him. Fully defined engineering drawings are still the standard. ...now back to our regularly scheduled ultimate build thread.
| The Following 5 Users Say Thank You to Ultramaroon For This Useful Post: | fika84 (01-24-2018), Icecreamtruk (01-24-2018), Jaden (05-29-2018), oso_25 (01-24-2018), Zentec (02-12-2018) |
#642 | |
![]() I find it awesome that you made your own lathe! |
| The Following User Says Thank You to fika84 For This Useful Post: | Ultramaroon (01-24-2018) |
#643 |
Road-hole
thanks...
Thanks.
technically it is a mill as well. I created it with 3 axes so I can mount a piece where the tool for the lathe would normally mount and put a mill bit in the lathe chuck and can use it as a mill or I can lock down the lathe in one of 24 positions and use it as an indexable 3 axis mill with something mounted in the lathe. Jaden I also have a 12X36 gun-smithing lathe for the real precision work. I make custom pool cues. |
| The Following User Says Thank You to Jaden For This Useful Post: | fika84 (01-24-2018) |
#644 |
Drives: 2017 Ice Silver BRZ Limited
@celek- If this is not proprietary info, how did you go about sourcing custom pistons, as in how do you know if you've got things like compression ratio, valve locations/lift clearance, etc. right? Sorry if this is a vague question, I'm just learning this stuff.
Thanks! Will |
| Tags |
| 2.3ltr, all motor, helpful, hks, hks stroker, informative, na brz |
| Beginner STX Build Whiteout FRS Build Thread | Hachi86Roku | Tracking / Autocross / HPDE / Drifting | 21 | 03-31-2020 08:52 PM |
| Ultimate coilover thread, What do you run on your car? got REVIEWS post it up! | THMotorsports.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 12-11-2013 06:25 PM |
| The *ULTIMATE* Exhaust Thread by ECS Motorsports! | Over 2 Dozen Options! + FREE S&H! | AJ@ECSMotorsports | Engine, Exhaust, Bolt-Ons | 27 | 09-05-2013 10:14 AM |
| *--->>ULTIMATE COILOVER THREAD<<---* The Best Deals + Free Shipping | FT-86 SpeedFactory | Brakes, Suspension, Chassis | 95 | 01-30-2013 08:48 PM |
| Who's in for the long haul? | Laika | BRZ First-Gen (2012+) — General Topics | 47 | 07-09-2012 10:48 AM |
