Old 08-02-2014, 10:04 AM   #631
FT86RGV
Just ordered an innovate tune from these guys. They sent a map for the wrong fuel first but quickly fixed that and sent the right map the next day. Top notch service and quick responses. I know the tune will be just as great. Looking forward to this weekend. Thanks again guys.
FT86RGV is offline   Reply With Quote
The Following User Says Thank You to FT86RGV For This Useful Post:
Old 08-03-2014, 11:18 PM   #632
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Hi All,
Just sent out the latest version of our Innovate Supercharger tune to everyone, took just about the entire day.
The latest Innovate Supercharger version is 8.65 and includes the following updates
1. Smoother acceleration from a dead stop
2. Smoother power delivery under partial throttle low RPM
3. Smoother power delivery under quick throttle changes at high RPM's
4. Better cold engine low end acceleration
5. Works on our 69mm pulley and up to 80mm pulleys (91 through E85)
6. Completely Updated to RaceROM Version7
7. Accelerator Trim Options (Soft, Standard, Aggressive, Drag)
Will have final results of the 69mm pulley online later this week. Also the 69mm pulleys are now available for sale.
Also our FlexFuel kits are just about done. We have been testing them on our vehicle for a few weeks now and it has been working flawlessly. Now just need to finish up a few small things and it will be ready for release.
Cheers,
William Knose
The Following 4 Users Say Thank You to DeliciousTuning For This Useful Post:
DesertFrs (08-04-2014), Ethan (08-03-2014), texasbound972 (08-03-2014), whataboutbob (08-03-2014)
Old 08-04-2014, 12:38 AM   #633
JesseE
JesseE's Avatar
Drives: LS Swapped BRZ
Hey have a problem installing the update, I downloaded it and when installing it when it hits 100% it immediately says error 22 and vehicle will not start without re-programming it, I made sure everything was off, updated everything and restarted computer turned ignition off and on, and tried again and same thing.
Hope someone can tell me what I'm doing wrong... followed directions and had no problem when I first originally programmed the first tune
JesseE is offline   Reply With Quote
Old 08-04-2014, 12:47 AM   #634
JesseE
JesseE's Avatar
21:43:11: Date & Time: 03/08/2014 21:43:11 Version 1.0.0.16274
21:43:11: Dongle ID: 6A F2 8A 0 Licenses Remaining
21:43:11: EcuTek RaceROM CAN Vehicle Interface: Firmware 02.14.07, Driver 01.01.E5
21:43:11: FTDI Driver Version: 2.08.26
21:43:11:
21:43:11: Selected ROM File: C:\EcuTek\MapAccessLogs\ZA1JA01C-enc_SC75-69-IC-91-M8.65.BIN
21:43:11: ROM File CRC: 055F C34A
21:43:12: ### User Selected 'Read Registration Details'
21:43:12: VIN = 'edited' (4A 46 31 5A 4E 41 41 31 32 44 31 37 31 30 37 31 30 )
21:43:12: Calibration ID = 'ZA1JA01C'
21:43:12: ECU = US BRZ Manual (ZA1JA01C)
21:43:12: The following ROM file versions are compatible with this ECU:
21:43:12: US BRZ Manual (ZA1J500C)
21:43:12: US BRZ Manual (ZA1J700C)
21:43:12: US BRZ Manual (ZA1J900C)
21:43:12: US BRZ Manual (ZA1JA00C)
21:43:12: US BRZ Manual (ZA1JA01C)
21:43:12: US BRZ Manual (ZA1JB00C)
21:43:12: US BRZ Manual (ZA1JB01C)
21:43:12: US BRZ Manual (ZA1JD00C)
21:43:12: RaceROM Patch Version 14599
21:43:12: ECU contains a Standard Tuner flash licence
21:43:12: Present ECU Information:
21:43:12: Comment: 8.65map
21:43:12: Dongle ID: edited
21:43:12: Program Count: 8
21:43:12: Program Date: 03/08/2014 2158
21:43:12: A Standard Tuner licence is present in this ECU. Programming will NOT consume a further flash license.
21:43:17: ### User Selected 'Program ECU'
21:43:17: Date & Time: 03/08/2014 21:43:17 Version 1.0.0.16274
21:43:17: Dongle ID: 6A F2 8A 0 Licenses Remaining
21:43:17: EcuTek RaceROM CAN Vehicle Interface: Firmware 02.14.07, Driver 01.01.E5
21:43:17: FTDI Driver Version: 2.08.26
21:43:17:
21:43:17: VIN = 'deited' (4A 46 31 5A 4E 41 41 31 32 44 31 37 31 30 37 31 30 )
21:43:17: Calibration ID = 'ZA1JA01C'
21:43:17: ECU = US BRZ Manual (ZA1JA01C)
21:43:17: The following ROM file versions are compatible with this ECU:
21:43:17: US BRZ Manual (ZA1J500C)
21:43:17: US BRZ Manual (ZA1J700C)
21:43:17: US BRZ Manual (ZA1J900C)
21:43:17: US BRZ Manual (ZA1JA00C)
21:43:17: US BRZ Manual (ZA1JA01C)
21:43:17: US BRZ Manual (ZA1JB00C)
21:43:17: US BRZ Manual (ZA1JB01C)
21:43:17: US BRZ Manual (ZA1JD00C)
21:43:17: RaceROM Patch Version 14599
21:43:17: ECU contains a Standard Tuner flash licence
21:43:17: Present ECU Information:
21:43:17: Comment: 8.65map
21:43:17: Dongle ID: edited
21:43:17: Program Count: 8
21:43:17: Program Date: 03/08/2014 2158
21:43:17: A Standard Tuner licence is present in this ECU. Programming will NOT consume a further flash license.
21:43:18: A Standard Tuner licence is present in this ECU. Programming will NOT consume a further flash license.
21:44:40: An Error Occurred:
21:44:40: Error Class: Exception
21:44:40: Error Message: Programming has failed.This ECU may need to be programmed again before the car will start.Error was: Start Routine by Local Identifier: 22 conditionsNotCorrectOrRequestSequenceError
Old 08-04-2014, 01:47 AM   #635
steve99
21:43:11:
21:43:17:
Thinnk you have same problem as these guys solution to revert to previous version
http://www.ft86club.com/forums/showp...58&postcount=9
whole thread
http://www.ft86club.com/forums/showthread.php?t=71398
Old 08-04-2014, 02:43 AM   #636
JesseE
JesseE's Avatar
Thank you! I was able to load my old map again to have a running car!
problem is I tried to program the new map and now get this error when trying to do so...
23:42:17: Selected ROM File: C:\EcuTek\MapAccessLogs\ZA1JA01C-enc_SC75-69-IC-91-M8.65.BIN
23:42:17: An Error Occurred:
23:42:17: Error Class: EUnknownPatchFeature
23:42:17: Error Message: Unable to Identify Feature ID=-255
any ideas?
Old 08-04-2014, 03:27 AM   #637
steve99
any ideas?
Mate i know sod all about ecutek but guessing i would say the new map has features or patch that not compatable with the older version of the ecutek software.
Best stay on the old map till the ecutek dudes sort out the new software update
JesseE (08-04-2014)
Old 08-04-2014, 04:37 PM   #638
DeliciousTuning
Hi All,
I have spoken to EcuTeK this morning about this issue. They have told me they are aware of the issue and have a resolution in the works that will be available for download tomorrow to fix this problem.
Thank you for your patience,
William Knose
The Following User Says Thank You to DeliciousTuning For This Useful Post:
JesseE (08-04-2014)
Old 08-05-2014, 08:50 PM   #639
Dustin
Twin Screw You
Dustin's Avatar
Drives: 2013 Supercharged Whiteout FR-S
Originally Posted by DeliciousTuning View Post
Hi All,
William Knose
Do you know if the new update from EcuTek was released today? Didn't want to try again and have issues.
Dustin is offline   Reply With Quote
Old 08-05-2014, 08:55 PM   #640
DeliciousTuning
Spoke to them today. Yes the new update is out.
Cheers,
William Knose
Dustin (08-05-2014)
Old 08-05-2014, 11:50 PM   #641
DeliciousTuning
Pulley's are now available on our website and ready for shipment. Innovate / Sprintex 69mm Pulley
The Following 2 Users Say Thank You to DeliciousTuning For This Useful Post:
Dustin (08-06-2014)
Old 08-07-2014, 03:06 PM   #642
JesseE
JesseE's Avatar
Ordered a 69mm pulley, Hopefully Flex fuel kit will be ready soon so I can make another order!
The Following User Says Thank You to JesseE For This Useful Post:
Old 08-07-2014, 09:55 PM   #643
DeliciousTuning
Flex Fuel kit is on the home stretch
Sincerely,
Zach
texasbound972 (08-10-2014)
Old 08-07-2014, 11:18 PM   #644
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
What's the upgrade cost to go from 93 octane to flex fuel tune? Bill can you please re-enable evap in my tune so I can pass emissions testing? Thanks.
post_break is offline   Reply With Quote
Delicious Tuning: Offering Innovate Supercharger Stage 1 "Tuner" EcuTeK Maps DeliciousTuning Engine, Exhaust, Bolt-Ons 24 09-20-2013 03:04 PM
Delicious Tuning: EcuTeK Stage 1 or 2 on 91, 93 or E85 fuels DeliciousTuning Engine, Exhaust, Bolt-Ons 1 09-19-2013 05:58 PM
Delicious Tuning - Dyno Tuning Weekend at Mann Engineering's (San Jose, CA) DeliciousTuning Announcements, Contests, Giveaways 6 09-19-2013 05:55 PM
Delicious Tuning: FlexFuel Innovate Supercharger EcuTeK Maps DeliciousTuning Engine, Exhaust, Bolt-Ons 1 09-13-2013 01:34 AM
Delicious Tuning and HG Motorsports: 86Fest Only Special - Take $100 off EcuTeK DeliciousTuning Announcements, Contests, Giveaways 5 08-26-2013 02:33 PM
