Old 07-31-2013, 02:27 PM   #631
sw20kosh
Drives: 2013 Black FR-S
Originally Posted by jamesm View Post
Exactly, creeping along is the only realistic case. Does anyone really care how much torque they're laying down when creeping? You'll be at very low load, low rpm, and going full throttle at 2k rpm (to actually make the number on the graph) in high gear isn't exactly advisable anyway.
It's useless knowledge if you never actually see the conditions in real life.
You don't install a supercharger to have less or equal pull down low. This type of supercharger is designed to make the motor feel bigger.
On my first tune I had less torque than stock sub 3k. I had to downshift more with the supercharger than I did stock. It bogged and felt useless anywhere below 3k. No one wants that in a daily driver.
The Following User Says Thank You to sw20kosh For This Useful Post:
lbroskee (07-31-2013)
Old 07-31-2013, 03:48 PM   #632
R2
Interesting. How much did this change with an updated tune? How does it now feel at 1000 to 2000rpm compared to stock?
R2 is offline   Reply With Quote
Old 07-31-2013, 03:52 PM   #633
swift996
swift996's Avatar
I'm close to pulling the trigger on the AEM water/meth kit. Trying to find a date that works for me and @moto-mike.
I think 70mm pulley and a cold-air intake will be added too...
I'm hopping for 275whp which looks achievable.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 07-31-2013, 03:55 PM   #634
ft_sjo
Drives: GT86
You can add me with a stage 2 kangaroo kit if you like.
Old 07-31-2013, 03:58 PM   #635
whataboutbob
AutoX-10/10ths every run
Originally Posted by DeliciousTuning View Post
Drive an automatic, they love creeping along at super low RPM's.
Cheers,
William Knose
So true. Driving around my neighbourhood at 25-35 mph on a flat surface my car is routinely at 1500-1700 RPMs.
Build thread:Here
Old 07-31-2013, 05:20 PM   #636
nonicname
Drives: it has 4 wheels and a motor
how is this kit affecting the throttle response?
any negative difference?
nonicname is offline   Reply With Quote
Old 07-31-2013, 05:43 PM   #637
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
Only thing stoppin me is i dont want to spend extra buyin it now and then stg2 parts later if all in 1 go is cheaper
lbroskee is offline   Reply With Quote
Old 07-31-2013, 05:48 PM   #638
xjohnx
Grip>Slip
xjohnx's Avatar
i seem to recall reading that the stg1 users can upgrade to stg2 upon its release for the delta in price. Too lazy to find it right now though.
Old 07-31-2013, 05:57 PM   #639
lbroskee
lbroskee's Avatar
I sent them an email directly asking that earlier today. So we ahould know for sure soon. If so then ill get this next and wait on audio
Old 07-31-2013, 06:42 PM   #640
lbroskee
lbroskee's Avatar
Ok well here is the exact message from innovate motorsports for any1 wondering
Old 07-31-2013, 07:29 PM   #641
NickFRS
Drives: 2013 Asphalt FRS
Originally Posted by xxscaxx View Post
@NickFRS mentioned his made more power.. Still waiting for him to post a pic of it though.. *hint hint*
i'll get a picture up tonight
2013 Sion FRS
2014 Subaru WRX
2014 Subaru XV
NickFRS is offline   Reply With Quote
The Following User Says Thank You to NickFRS For This Useful Post:
xxscaxx (07-31-2013)
Old 07-31-2013, 07:29 PM   #642
xjohnx
Grip>Slip
xjohnx's Avatar
Sounds like good news. What're you waiting for? Order!
Old 07-31-2013, 07:31 PM   #643
NickFRS
so y is max TQ only 220 so far? is that its limits or is it jus b/c no1 has sprung for a clutch yet?
Me and Evan both have the same clutch + lightweight flywheel. (ACT stage 1 street lightweight kit) <- Prolight flywheel
Also I seem to like to keep my car above 2500 RPMS... I cruise anywhere from 2500-3000 Under 2500 seems like your bogging the engine to much with the charger. + who drives at 2k RPMS with a 7500 redline???? More beneficial to be above 2500. From 2500 + wot there is a noticeable difference.... Compare our graphs to a Vortech car and you will understand.
Also remember the blower is attached to the pulley system so it's a little different then a turbo. Your actually adding more rotational weight for the boost. This gives a weird peddle feel at low RPMS (2-2500) Kinda jumpy but once your above 3k the car screams through the rev range.... My traction control lights up in first around 4500 in a straight line if i'm WOT.
You can look at my dyno comparison to see how the WHP/WTQ come at 3k/4k/5k/6k/7k RPMS. All 3 cars are very different in power delivery due to modifications.
Also remember these are 3 different cars on 3 different days in 3 different temperatures with 3 different set-ups but on the same dyno with the same tuner.
Darren and I will be at PIR dragging our cars on Friday. That should be some fun data!
(if you want more torque get a Perrin Intake / Header back exhaust / Clutch + Light Weight Flywheel. If you want more overall power get meth injection or E85)
2013 Sion FRS
2014 Subaru WRX
2014 Subaru XV
The Following 3 Users Say Thank You to NickFRS For This Useful Post:
DarrenDriven (08-01-2013), ill86 (08-02-2013), Subzero (07-31-2013)
Old 07-31-2013, 07:47 PM   #644
NickFRS
BTW DON'T FORGET TO REFILL YOUR COOLANT AFTER INSTALL! I HAD FORGOTTEN AND LIKE AN IDIOT WAS SEEING WATER TEMPS 210-230 DEGREES!
2013 Sion FRS
2014 Subaru WRX
2014 Subaru XV
2 whp better than n/a e85, 2 whp? you're an idiot., 2screwsbetterthan0screw, 65 whp better than na e85, bspt fittings ftl, hate u all me no have sc, im just here for the tags, inorite!, it's no turbo but, only big numbers matter, screwyou, whine sexier than turbo, whines_more_than_your_gf, wts grey market butthurt.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 11:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 07:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 01:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-18-2012 12:38 AM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 06:14 PM
