Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 03-02-2022, 07:34 AM   #631
Varelco
Drives: '15 GT86 & '22 GR86
Originally Posted by PBR View Post
Cusco rear lcas/Bilstein B8s/Swift Spec R. Been on the car a couple of days. Letting them settle then back for a proper alignment in a few weeks.
Looks great, whats the ride quality like compared to stock?
Varelco is offline   Reply With Quote
Old 03-02-2022, 09:27 AM   #632
PBR
PBR's Avatar
Drives: 2022 BRZ Limited 6 speed manual
It's only been a few days. Letting them settle fully then back for a proper alignment. Definitely stiffer but the ride quality is more than acceptable for me. Not crashy or bouncy. Ive read Spec Rs can be rough on stock shocks. Not experiencing that. Feel more of the road. Less body roll, squat and dive is immediately apparent. Hit a few pot holes and expansion joints, obviously not as nice as stock but worth the ride height and less "floaty" feeling. Former modified cars include S2K AP2 Koni/Swift and FRS Lca/tein flex z/RPF1 17x9. Also think the steering weight may have increased but I'll report back. TWS T66-F 18x8 and HKS Spec L II should be on the car as well as Raceseng camber plates by then also.
PBR is offline   Reply With Quote
Old 03-02-2022, 10:36 AM   #633
MikeNSX2
Drives: Ice Silver 2022 BRZ Limited
Installed my WC Lathewerks stainless steel shift knob.
MikeNSX2 is offline   Reply With Quote
Old 03-02-2022, 10:52 AM   #634
EZLVN
Drives: 2022 BRZ Premium, 1990 Miata
That’s a very nice knob! A cool sleek look.
Well done.
EZLVN is offline   Reply With Quote
Old 03-02-2022, 07:17 PM   #635
Flarpswitch
Flarpswitch's Avatar
Drives: 2022 BRZ Ltd, 2025 Ascent Touring
Very cool, but does the increased mass of the shift knob affect the 'feel' of the shifting action. Some years ago I installed a shift knob a friend fabricated for me. I even gold plated it since I had access to plating equipment at the time. It looked like top shelf. However, the inertia of the knob on the shift lever and the weight of the knob actually shifted out of third gear during hard braking. Not entirely the fault of the knob as the hub and synchros in the transmission were well worn at that point. Anyway, I had to go back to my tried and true custom turned wood knob to be able to put off work on the transmission. The extra weight of the metal knob caused me to miss shifts and again some of that likely due to worn linkage.
Flarpswitch is offline   Reply With Quote
Old 03-02-2022, 10:45 PM   #636
slimfit
Drives: ‘22 BRZ
^^I’ve had weighted knobs in all of my cars since’05 and never had an issue like that. Loved my Latheworks and Blox knobs I used in my WRX. Switched it up this time and have a Likewise Thicc Boi on the way.
slimfit is offline   Reply With Quote
Old 03-02-2022, 11:17 PM   #637
Midnightsky
Midnightsky's Avatar
Drives: 2022 BRZ WRB
Some shift knobs weight more than others. It's a personal preference for the most part. If you look long enough you can find ones that weigh in between the super heavy ones and the lighter stock ones. I found that the OEM ND Miata shift knob has a good balance between them. I had blox knob on a previous car and it weighed probably double what the ND Miata knob is.
Midnightsky is offline   Reply With Quote
Old 03-03-2022, 12:32 AM   #638
diga
Drives: 2022 Subaru BRZ Limited 6MT
I did a brake fluid swap - OEM to Motul 600, I'm planning on doing some beginner track days, also have Ferodo DS2500 on the way. One thing I want to share with folks, if you're using the Motive Power Bleeder be very aware of how you put the cap on the reservoir. I was extremely careful but still ended up slightly damaging one of the flanges on the reservoir. I have the plastic cap version so I don't know if the metal cap version works better but I just wanted to post my experience with this product. I don't believe it did enough damage to cause any issues but I'm pretty disappointed. I won't be using it again.
diga is offline   Reply With Quote
Old 03-03-2022, 01:40 AM   #639
Up4speed
Drives: 2023 BRZ Limited
What do you mean by flanges on the reservoir? I'm not sure what you are explaining? Please clarify if possible, as I always use the Motive bleeder on my cars, and don't want to damage anything when it comes time to do the fluid change.
By the way, another hint with that bleeder: Change the hoses if they are old!! (> 6 or 7 years old, mine were about 10)
I just did a fluid change on a friend's car, and even though I physically inspected the hoses, and also did a dry run, and pumped it up without fluid in the tank to test it, it sprung a leak after I filled it with fluid and pumped it up!! It was a little bit of a disaster, but thank god I was careful, and put down thick blankets protecting the car, and the frunk (front trunk on mid engine car). I was able to release the pressure, and get everything away from the car, without getting a drop on the car. It was a very scary experience that could have been avoided if I replaced the hoses sooner.
The worst part.... I literally said this as we were getting started:
"I think my hoses are getting a little old, I am going to order new ones before I have a problem" Well, I'm really glad that I got VERY lucky this time. It could have been REALLY bad. I think I will change them every 5 or 6 years from now on.
Up4speed is offline   Reply With Quote
Old 03-03-2022, 02:00 AM   #640
diga
not really sure how to describe what a flange is - a protruding lip or rim used to fasten two objects?..in this case the brake fluid reservoir and the cap.
Old 03-03-2022, 08:44 AM   #641
MikeNSX2
I have had a WC Lathewerks stainless steel shift knob in my Focus ST for about 4 years, also one in my previously owned Miata ND, and now in my BRZ.
I love the feel of a heavy weighted shift knob, and have never had any issues arising from using a heavier knob.
Old 03-03-2022, 09:23 AM   #642
pinkwheels
Drives: 2016 HyperBlue BRZ
I didn't get to do anything yesterday, but Randy Pobst got to drive both my BRZs around AMP to figure out which one is faster...
pinkwheels is offline   Reply With Quote
Old 03-03-2022, 09:27 AM   #643
MikeNSX2
Actually yesterday, my Perrin 3.0 exhaust was delivered.
Old 03-03-2022, 10:12 AM   #644
LRNAD90
Drives: X5 35d, D90, CX-5 Turbo
Alright, where is the link to the video, tease..
LRNAD90 is offline   Reply With Quote
WHAT DID YOU DO TO YOUR FRS TODAY? KalbiCool88 Scion FR-S / Toyota 86 GT86 General Forum 1 11-04-2015 10:36 PM
Do you know what today is? Yruyur Off-Topic Lounge [WARNING: NO POLITICS] 26 01-21-2015 02:51 PM
just got my OFT today...help please! carlitosway6891 Software Tuning 9 02-20-2014 10:05 PM
TODAY, TODAY, I GET IT TODAY!!!! :D Trashed675 Scion FR-S / Toyota 86 GT86 General Forum 54 02-14-2013 01:16 AM
