Old 09-10-2018, 06:22 PM   #631
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
For Neil @The Racers Line
Any CARB updates?
Old 09-10-2018, 06:45 PM   #632
Trefoil
Trefoil's Avatar
Drives: GBS BRZ Harrop SC/PTuning Header
Ran into a problem with my Harrop SC '13. Whenever I am stopping with the clutch in and in neutral, the engine dies. Recently rerouted some vacuum lines back to stock configuration on the car and had to take off the airbox (with maf) and disconnect the wiring loom extension that reaches to the maf, throttle body, IAT, and MAP.
Any suggestions? Is it as easy as cleaning the MAF or is this a larger issue like a vacuum leak from a hose that I missed?
The engine power is fine, but runs rich. If I can keep the throttle in using toe-heel, i can keep the engine running by keeping the rpm above 1.4k.
Trefoil is offline   Reply With Quote
Old 09-10-2018, 08:35 PM   #633
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Did you plug the bypass valve vacuum line back in?
Old 09-10-2018, 09:50 PM   #634
gtengr
Drives: 2017 BRZ
Originally Posted by Yoshoobaroo View Post
It's definitely significant, I wanted to know if the math translated to reality.
FWIW, BMW used a different front spring for the E46 M3 CSL depending on whether the AC delete was spec'd.
The unruly part isn't it sliding all over the road, just to be clear, although it really isn't hard to make that happen in 1st or 2nd; it is just the annoyance of having the traction control coming on all the time I seriously get on the accelerator.
Beyond tires, a good damper and stiffer bushings might help.
gtengr is offline   Reply With Quote
Old 09-10-2018, 10:41 PM   #635
Yoshoobaroo
TRACKBREAD
Yup, BMW does that all the time. They spec different springs for heavy option packages, 4 door vs coupe vs wagon vs convertible, AWD vs. RWD, etc.
Old 09-11-2018, 01:08 AM   #636
johan
Drives: '14 981CS, '99 NB1
Making it stiffer will just make it even harder to put power down though. IMO if you're struggling to put power down now, keep it soft and keep the traction brackets, get stickier tires.
You're absolutely right. My reference to too soft vs too hard was in relation to the fact that I previously had a my15 FR-S, and that suspension was perfection to me. I always felt the '17 lost some precision in comparison.
johan is offline   Reply With Quote
Old 09-11-2018, 03:40 AM   #637
Yoshoobaroo
TRACKBREAD
Interesting! I went from the original springs on my 13 BRZ to a set of 2017 springs and the car feels more planted! Different driving styles I guess!
Old 09-11-2018, 06:28 AM   #638
Trefoil
Trefoil's Avatar
I dont think I ever unplugged it but I'll check when I pull the alternator out this afternoon. Before putting in the AC compresser all vacuum lines on that side were plugged in correctly.
There's power under acceleration now. I receive no cell codes after the car stalls/dies.
Old 09-11-2018, 11:17 AM   #639
johan
Well, Toyota/Subaru spec'd different springs/dampers across 13/15/17. So that's not an a/b comparison. Also if you put the 17 springs on 13 dampers, that's a mismatch that would give a completely different experience as well.
Old 09-11-2018, 11:46 AM   #640
Yoshoobaroo
TRACKBREAD
Nah 17 dampers too.
Old 09-11-2018, 07:14 PM   #641
Trefoil
Trefoil's Avatar
Update: Messed with my brake booster line layout which I've suspected of having a crack and noticed while the power was on, the throttle body was humming/buzzing. Unclipped it and all other sensors, checked the connectors then reattached them. After quickly clearing the codes, the vehicle started up and idled for a few minutes while I was logging. Made it a good portion of the way home to a gas station where I refilled (e70) and then all of my problems started over again with the clutch-in stalling.
After a little ways down the road, I noticed if I eased into a stop and was gentle on the clutch disengagement, then the problem went away. Kept logging the entire time.
What the heck?
Old 09-11-2018, 08:08 PM   #642
Irace86.2.0
What the heck?
Clutch in or clutch out in neutral makes a difference?
Old 09-12-2018, 03:34 PM   #643
johan
What the heck?
Throttle body always buzzes. Completely normal. You just can't hear it over the engine when it's running.
Old 09-15-2018, 03:16 AM   #644
Trefoil
Trefoil's Avatar
New update:
The old vacuum lines were fine even after two years of hot weather driving conditions. Rerouting the front vent hose into the correct position has helped with cells.
A new ACT HDSS went in and the the old FX400 had totally lost all puck material and was down to just the steel backing! I really recommend shopping with CSG as they both have an amazing price on it while supporting the forums, or to support your local shop.
As I'm getting older, working from a garage alone has lost its appeal, since I cant bench press like i used to with a transmission on my chest and it's darn near impossible to work without a lot of investment into more tools. I asked a local subaru mechanic to do the work. After a rather quick install (~2.5 hrs) on his lift, the mechanic noticed an exhaust leak by the header or front overpipe... Which he mentioned could cause the sudden stalling issues at stop lights. Does that make sense?
JDL turbo kit owners thread yomny Forced Induction 1352 01-08-2025 04:20 AM
HKS Supercharger owners thread wbradley Forced Induction 1054 10-26-2024 01:18 PM
P&L Turbo kit Owners thread Hawaiian Forced Induction 73 07-07-2018 02:31 AM
Harrop car lip kit? djdnz Cosmetic Modification (Interior/Exterior/Lighting) 15 12-15-2015 02:50 PM
**Offical 213/323/626/818 owners thread** mr. slim Southern California 71 10-07-2013 12:58 PM
