11-29-2023, 03:58 PM | #631 |
Drives: Q5 + BRZ + M796
I was considering the first stage SpaceX Super Heavy's reentry:
https://en.wikipedia.org/wiki/SpaceX_Super_Heavy 0.5 million (250 US tons) pounds dry 7.4 million (3,700 US tons) pounds fuel 7.9 million (3,950 US tons) pounds wet/total 95% of the weight is in the fuel. I've read that the reentry fuel is estimated at 6.5-10% of the fuel, some of which might be residual fuel because you don't want to run out on reentry. At 10%, we are looking at 740,000 (370 US tons) pounds of fuel, which is significantly more than three 2,000 (1 US tons) pound parachutes, which would be an one-hundred fold savings. Seems like SpaceX is considering this too, as the Super Heavy booster will be caught on a tower (if that is still the plan), and like the arresting wires slowing a jet on the landing of an aircraft carrier, the tower seems to have counter weights, hydraulics or magnets to slow the booster. Maybe this is the best compromise.
11-30-2023, 07:50 AM | #632 | |
1st86 Driver!
The directional fins at the top of the booster are strong enough to hold the entire booster as an artifact of the strength required for directional forces during landing. The booster also has enough power that it can effectively hoover during the transition.
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". Last edited by Dadhawk; 12-05-2023 at 07:22 AM. |
The Following 2 Users Say Thank You to Dadhawk For This Useful Post: | Irace86.2.0 (11-30-2023), NoHaveMSG (12-04-2023) |
11-30-2023, 02:52 PM | #633 | |
So the tower saved some weight off the booster by being a shock absorber, and the booster isn't hovering because that is sketch and wasteful, so again, it acts as a shock absorber, but could it be more? Maybe they could make a giant magnetic catch system like Drop Zone. Seems like at minimum parachutes could reduce the speed to 50 mph before rockets finished the job. The reusable payload is 100-150T, so there would be huge savings to the cost of flight by reducing the reentry fuel for the Super Heavy booster and Spaceship. The Starship has a dry weight of 120T and a weight weight of 1,320T with 1,200T of propellent. Ten percent of that is 120T, so if we are saving 120T from Starship and 370T from Super Heavy then we increase out payload from 100-150T to 600-650ish. This is a factor of 4-6x. For perspective, Falcon 9 was $67 million per payload, which had a capacity of 25T, but Musk says Starship will be around $10 million for the same 25T payload. If they could increase the payload by 4-6x then the price for the same 25T payload could drop to $1.5-2.5 million, doing rough math.
The Following User Says Thank You to Irace86.2.0 For This Useful Post: | Dadhawk (11-30-2023) |
11-30-2023, 03:32 PM | #634 |
1st86 Driver!
Well, to clarify it can hover with only the decent engines. Apparently, at least from what I read, Falcon 9 can't do that.
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
The Following User Says Thank You to Dadhawk For This Useful Post: | Irace86.2.0 (11-30-2023) |
11-30-2023, 04:06 PM | #635 |
This was well done, especially with all the great images.
The Following User Says Thank You to Irace86.2.0 For This Useful Post: | alex87f (12-01-2023) |
12-02-2023, 11:57 PM | #636 |
Drives: GR86 (Sold) -> C6 GS Edelbrock SCed
12-04-2023, 06:11 AM | #637 |
Because compromise ®
Drives: Red Herring
This is f*cking incredible.
The Following 4 Users Say Thank You to Captain Snooze For This Useful Post: |
12-04-2023, 09:48 PM | #638 |
extra what?
"If you haven't read this, shame on you."
I'm shocked at the glaring deficiencies he uncovered. Fascinating.
The Following User Says Thank You to Ultramaroon For This Useful Post: | Dadhawk (12-05-2023) |
12-05-2023, 07:38 AM | #639 |
1st86 Driver!
I find it a little off-putting how "positive" all the SpaceX pundits continue to spin SpaceX failures that if NASA had done there would be an outcry of shut them down.
Calling this flight and "outstanding success" even though it didn't reach it's primary goal (orbital flight) and lost both the booster and Starship is less than unbiased reporting, yet all of them seem to follow SpaceX lead on this. The launch was amazing and they received lots of good information from it I'm sure, but call it as it is. The flight failed.
The Following 2 Users Say Thank You to Dadhawk For This Useful Post: | Spuds (12-05-2023), x808drifter (12-05-2023) |
12-05-2023, 08:53 AM | #640 | |
1st86 Driver!
The one thing I found concerning for me was I learned from this was the lack of using a hypergolic fuel source for ascending from the lunar surface. Not that ignition systems fail that often but it just seems simpler. Complexity for no discernable reason. I had also never seen the photo of the Apollo 1 crew praying over a model of the command module. That was unsettling.
The Following 2 Users Say Thank You to Dadhawk For This Useful Post: | bcj (12-05-2023), Ultramaroon (12-05-2023) |
12-05-2023, 10:19 AM | #641 | |
LMGTFY
Drives: 13 FRS, 91 Miata
Same with the 1st flight where anything after it got off the pad was icing on the cake. So technically they were "outstanding successes" but at the same time if considered from a was the flight complete it was a failure. But both stages blowing up was also a huge step backward. Have SpaceX been calling it anything but a failed flight? I stopped paying attention to them beyond the Starship trials after Elon said fuck YouTube I'm gonna only stream on twitter. At least no vans died this time. |
The Following User Says Thank You to x808drifter For This Useful Post: | Irace86.2.0 (12-05-2023) |
12-05-2023, 10:41 AM | #642 |
1st86 Driver!
I don't think SpaceX has ever called one of their flights a failure regardless of the results. That said, I didn't check.
12-05-2023, 10:43 AM | #643 | |
1st86 Driver!
I agree it wasn't a complete failure, but I wouldn't call it a resounding success either.
The Following User Says Thank You to Dadhawk For This Useful Post: | x808drifter (12-05-2023) |
12-05-2023, 12:19 PM | #644 |
Drives: '23 BRZ
Starship lunar lander missions to require nearly 20 launches, NASA says
https://spacenews.com/starship-lunar...hes-nasa-says/ I never considered Starship a viable lunar lander. They were picked because lower price. This seems like a ridiculously impractical way to put humans on the moon again. 1x SLS launch at ~ same mass as Saturn V, plus upwards of *20* Starship/Superheavy launches at nearly 2x that mass each, 1 for the lander and the rest for refuelling? I mean, it's fricking absurd... |
The Following User Says Thank You to ZDan For This Useful Post: | Dadhawk (12-05-2023) |
Similar Threads | ||||
Which Space Saver will fit? | Andrew666 | AUSTRALIA | 25 | 06-18-2020 09:07 AM |
Cockpit Space | Chad86 | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 03-15-2014 03:24 PM |
First run 86's (Space Saver question) | DriftEightSix | AUSTRALIA | 11 | 01-10-2013 07:25 AM |
FR-S space saver | sierra | Scion FR-S / Toyota 86 GT86 General Forum | 2 | 11-29-2012 12:18 AM |
Trunk space? | tranzformer | Scion FR-S / Toyota 86 GT86 General Forum | 34 | 04-13-2011 12:29 PM |
