Old 06-18-2015, 01:30 PM   #6413
Cross
It's the Mad Cow
Cross's Avatar
Well I guess I get to join the Twin Screw Club now!
Just waiting on my 700cc Injectors, 70mm Raceseng Pulley and the tune from @moto-mike and we will be up and running. The New SC got here Yesterday and it's already on and waiting.
I have a question about registering for the warranty since mine is an Innovate Kit. It's brand new, I bought it from Visconti and have an invoice but I was under the impression they no longer deal with it so maybe @SprintexUSA could let me know what to do?
Hoping with my modifications to be knocking on 300's door on E85 but Mike keeps telling me to settle down. Hard to do after the Turbo setup I had before the motor blew and having as much power as it did. I am hoping this gets me back to really feeling like the car is enjoyable but it seems Mike is convinced I will need the 335 to feel that way.
Either way Build thread is here:
http://www.ft86club.com/forums/showthread.php?t=58591
Serial Number:
S5-210-150213-0014
Basic Mod's List:
PLM Header and catless 3" Exhaust All the way back
AiRaid Intake with Modified Snorkle
700cc Injectors
Perrin Lightweight Crank, Alternator and Waterpump Pulleys (Black)
Raceseng 70mm Pulley
Lightweight Flywheel
Single Piece DSS Aluminum Driveshaft
and tons of other modifications but those are the main ones besides braces, sway bars, springs, wheels, etc.
Here's to joining the club that makes whining sound so good.
Old 06-18-2015, 05:09 PM   #6414
Dream20b
Y u do dis?
hey that looks familiar
Dat Hot Lava Doe
Clearly you have no clue what you are talking about. Everything you said was completely and utterly the ramblings of a babbling idiot regurgitating garbage from his mouth. Everyone here is now dumber from reading your post. Please die now.
Dream20b is offline   Reply With Quote
Old 06-30-2015, 12:33 AM   #6415
Ultramaroon
not playing cards
Ultramaroon's Avatar
How does one go about obtaining an illustrated parts breakdown? Service manual?
I might want to repair/rebuild one in the near future. @SprintexUSA?
Old 06-30-2015, 11:19 PM   #6416
stockysnail
Just the tip
stockysnail's Avatar
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
I have the installation manual, but I don't think that is exactly what you're looking for. Matt asked if I can help him with his replacement part install so I may be there as well if it's on a weeknight or weekend after this.
stockysnail is offline   Reply With Quote
Old 07-01-2015, 12:06 AM   #6417
Ultramaroon
not playing cards
Super tight alignment/timing going on in there. I'd like to see what exactly failed and what can be engineered as a failsafe. Maybe a sacrificial shear pin somewhere upstream.
Old 07-01-2015, 11:19 AM   #6418
Chad86
DrivinginDreams...Cloud86
Chad86's Avatar
Drives: Toyota GT86
Question
I will have my 335 up and running shortly and want to make sure I'm not short on any parts for a solid start. I will be driving street only. Question is, am I fine running the stock injectors on pump gas?
Parts:
335 blower
85mm pulley
Radium Dual Catch Can Kit
Perrin 3" bigMAF CAI
Gauges
Everything else is stock at this point.
Chad86 is offline   Reply With Quote
Old 07-01-2015, 12:07 PM   #6419
SprintexUSA
SprintexUSA's Avatar
Drives: 2014 FT86
What exactly are you looking to rebuild?
SprintexUSA is offline   Reply With Quote
Old 07-01-2015, 01:54 PM   #6420
Ultramaroon
not playing cards
A 210 that failed recently. Caught it early enough but as a potential customer, I'd like to get a better understanding of the failure mode and, at the same time, help a friend get back up and running.
Old 07-01-2015, 03:00 PM   #6421
Dream20b
Y u do dis?
Parts:
335 blower
85mm pulley
Gauges
bad idea, Get injectors and pump, see the 335 thread and either run e85 or 91+ and Meth injection
Dat Hot Lava Doe
Old 07-01-2015, 04:18 PM   #6422
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
Parts:
335 blower
85mm pulley
Gauges
Since you're on the 85mm pulley and pump gas you may be ok. Preferably injectors at the least though, it would prevent overdriving the DI too much. I'd start by limiting revs to 6500 until the pulse widths are evaluated.
Xero-Limit is offline   Reply With Quote
Old 07-01-2015, 04:26 PM   #6423
SprintexUSA
Drives: 2014 FT86
We don't send out our drawings. I do have a stash of spare parts here, now. We can work with you on the sub-assembly parts you might need. I just shipped a BRZ blower with a nose-drive attached, for instance.
Twin-screw blower assembly is a complex thing that requires a delicate touch. There are not a lot of parts in our unit, but the tolerances are very tight and specific. We don't recommend that end users try and rebuild these units on their own, even if they have worked on roots or centry blowers before. Castings are reusable, but the rotorpack cannot be if there is any kind of bearing failure behind the gears.
Old 07-01-2015, 05:32 PM   #6424
Ultramaroon
not playing cards
A wise policy.
Understood. Ok to pm you after I dig in? No rush on any of it.
Old 07-01-2015, 07:27 PM   #6425
SprintexUSA
Drives: 2014 FT86
Email is better. Gturner@sprintexusa.com
Old 07-01-2015, 09:55 PM   #6426
xjohnx
Grip>Slip
xjohnx's Avatar
do you guys offer a rebuild or refresh service?
2 whp better than n/a e85, 2 whp? you're an idiot., 2screwsbetterthan0screw, 65 whp better than na e85, bspt fittings ftl, hate u all me no have sc, im just here for the tags, inorite!, it's no turbo but, only big numbers matter, screwyou, whine sexier than turbo, whines_more_than_your_gf, wts grey market butthurt.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 12:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 05:14 PM
