Old 04-10-2022, 05:29 PM   #617
Muskoka800
Drives: 2016 Scion FRS Release Series 2#439
Originally Posted by 7thgear View Post
god, they look so fragile
how would they hold up in the winter time?
are they even designed for prolonged exposure to the elements without cleaning? Maybe put on a ruber-condom type thing on the fronts for harsh winters?
yes i winter drive my car, cuz i'm a badass.
Ohlins at Scandinavian and supply great dampers for Yamaha snowmobiles.
Winter survival is the least of your worries.
Muskoka800 is offline   Reply With Quote
Old 04-10-2022, 05:30 PM   #618
Muskoka800
Ohlins are Scandinavian and supply great dampers for Yamaha snowmobiles.
Old 04-10-2022, 08:39 PM   #619
churchx
churchx's Avatar
Drives: 2014 GT86
It's less winter/temperatures, that are aggressive to shocks. It's roadsalt that is commonly used on roads, that may ask for more more resistant shock finish. Thus not sure, if snowmobiles are right thing for argument, as they simply drive on clean snow, not on salted tarmac. At least cars last much longer without rust/corrosion in areas where they don't use road salt in winter.
Old 04-26-2022, 01:11 AM   #620
Lucky21
vroooooooom
Lucky21's Avatar
Drives: 86
Originally Posted by NJ-JDM View Post
I installed my Ohlins this past weekend. I ended up not leaving well enough alone and ordered 5k Swift springs for the rear and used the 4k that came with the Ohlins up front. I got some new Pedders tophats off the forum.
I set the pre-load on all four per the instructions while watching the final four on Sat. And got them all installed on Sunday.
Ride height wise I ended up at exactly what the 4k instructions said in the front. 349mm (23") from fender lip to wheel centerline. The instructions from Ohlins are written differently for the 5k, they don't give the overall target. Just what the drop should be. I was already lowered and don't know what stock ride height was. I ended up at 597mm (23.5").
My car has whiteline end-links and TRD bars. I used the 10mm spacers up front. I did hear a knocking or something, not sure yet, need to inspect. Everything should be tight and the end-links were in good shape and not worn out or loose when I had it apart. It may not even be sway bar related, but I heard it when the suspension cycled in compression more so than rebound.
First drive, the car is so much better now. My alignment is obviously off, but not enough that I can't drive it around town to let it settle. I noticed one of the front springs popping when I was parking. Should I have slathered some anti-seize on the spring seats? Or do people live with it? Or will it stop?
TIA for any additional info.
Hi, I have trd lowering springs and stock shocks as well and I just picked up a set of mp20s. Is there really a huge difference in ride comfort compared to the trd springs?
Lucky21 is offline   Reply With Quote
Old 04-26-2022, 08:09 AM   #621
NJ-JDM
Drives: 2013 BRZ Limited
I just bought my car back in Dec. For the most part the comfort side of the TRDs was fine, around town, smoother roads. But if my stock dampers were original at 84k miles, then they were having a tough time "controlling" the spring. The car never bottomed out or scraped, but it you hit a bridge transition on the interstate the rear in some cases would crash and bottom out on the bump stops. And then pogo back up. You could tell something wasn't right.
I've had Koni yellows on an FD RX7 and NA Miata with stock springs. And stock dampers with progressive Eibachs on a Fox body and a BRZ. Without a doubt the high end Ohlins with a decent set of springs matched to their valving range are better for sure.
I hit an even bigger bridge transition at 78mph the first longer drive out with the Ohlins, it went over it with no drama at all.
2013 BRZ Limited
NJ-JDM is offline   Reply With Quote
Old 06-03-2022, 11:10 PM   #622
Lucky21
vroooooooom
Lucky21's Avatar
Drives: 86
Got the MP20 kit installed and my ride seems pretty bouncy in the street. I followed the recommended pre load in the user manual and have tried various damping settings. Is there anything I can do about this?
Old 06-04-2022, 10:47 AM   #623
grumpysnapper
grumpysnapper's Avatar
Definately shouldnt feel "bouncy", good dampers should ideally make your car feel more "settled" on the road.
If you are able to find a local trusted suspension guy, a little bit of money/time with them tuning your suspension will be worth every cent.
Good luck (and they are a great choice in damper, I loved mine)
grumpysnapper is offline   Reply With Quote
Old 06-04-2022, 11:26 AM   #624
marco_mc22
Drives: Toyota 86
Define bouncing…anyway using 6kg springs might “fix” the rear lack of travel but still delivers you too high frequencies for a road car, 5kg is the maximum in my opinion.
How many clicks? Ride height?
marco_mc22 is offline   Reply With Quote
Old 06-06-2022, 02:29 AM   #625
Lucky21
vroooooooom
Lucky21's Avatar
Drives: 86
The person who installed the coilover insisted that we should follow the recommended pre load in the manual resulting in the poor ride quality.He claimed adjusting it incorrectly would result in a blown damper.
Old 06-06-2022, 02:30 AM   #626
Lucky21
vroooooooom
Lucky21's Avatar
Drives: 86
i currently have 12 clicks on mine as it is the most acceptable ride so far but still bouncy. Ride height is about an inch drop.
Old 07-04-2022, 03:32 AM   #627
Lucky21
vroooooooom
Lucky21's Avatar
Drives: 86
Just to update this car rides fine now, the coilovers was rebuilt improperly and the recommended preload was too bouncy for our roads.
Old 09-19-2022, 11:27 AM   #628
RacingredGR86
RacingredGR86's Avatar
Drives: 2022 GR86
@Lucky21 - what spring rates are you running on your R&Ts? I'm considering going with Ohlins and wanted to get some info from current users. Thnx
RacingredGR86 is offline   Reply With Quote
Old 01-30-2024, 05:16 AM   #629
ffh2303
Drives: BRZ 2013
Hi, can you share the preload settings you used?
ffh2303 is offline   Reply With Quote
ohlins road and track shock absorbers CyberFormula Suspension | Chassis | Brakes -- Sponsored by 949 Racing 31 11-11-2014 05:00 AM
>> OHLINS Road & Track Coilovers - First Shipment IN - FT86 Special - FREE Shipping! Circuit Motorsports Brakes, Suspension, Chassis 90 08-16-2013 12:39 PM
Ohlins Road & Track Coilovers - IN STOCK!!! RallySport Direct Brakes, Suspension, Chassis 7 05-28-2013 04:11 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 08:15 AM
Ohlins Road & Track Subaru BRZ and Scion FR-S HP Autowerks Brakes, Suspension, Chassis 0 04-24-2013 03:27 PM
