Old 11-10-2019, 08:24 PM   #62875
sounds like it needs a battery maintainer.
what year are you working on? i'd start with the ecm fuses, and then move to anything on the interior that has a memory
That's what I was working on today, and couldn't find anything. Going to go through them once again if necessary. Shouldn't need a battery maintainer for 3 to 7 days ( about as long as it goes).
Also, haven't had the issue in the 6 years I've owned it until this past month. 2004 Suburban ZL1.
Dadhawk is offline
soundman98 (11-10-2019)
Old 11-10-2019, 08:26 PM   #62876
soundman98
ProCrastinationConsultant
soundman98's Avatar
Originally Posted by davesrave View Post
From: https://automedicsafrica.com/cause-o...battery-drain/
PARASITIC DRAIN
If you have your radio presets, security alarms or clocks running after the engine is off, it can drain your battery. The most common causes of parasitic drain are under hood lights, trunk lights, headlights or glove box lights that do not turn off when the door is closed. Relay switches that are stuck in the “on” position can also cause a battery to drain.
FAULTY CHARGING SYSTEM
A faulty or unreliable charging system can also drain the battery while the car is running. When an alternator is not pushing out enough voltage, which should be between 13.5 and 14.5 volts, the battery will drain quickly.
BAD ALTERNATOR DIODE
Alternators with bad diodes can cause battery drain. A bad diode can leak and allow the current to flow in the opposite direction. When this happens, it may keep the charging circuit on after the vehicle engine is shut off, which will cause the battery to drain.
OLD BATTERY
Batteries that are old or have been drained continuously may not hold a full charge anymore. The rule of thumb for replacing a battery is every four to five years.
the first one was a 'yeah dummy' one for me. now i'm suspecting the bad alternator diode.. that's almost as easy to test as fuses-- just pull the cables off the alternator and let it sit a few days.
a faulty charging system would have driveability issues over the course of a few hours as the battery goes dead, and he said he already replaced the battery, ruling both those out.
Say WHAT?
humfrz
those had generators, right? a lot easier to troubleshoot though!
soundman98 is offline
humfrz (11-10-2019)
Old 11-10-2019, 08:33 PM   #62877
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
Might check the battery case itself. When did you give it a good scrub up and clean?
Try disconnecting it and test from the neg. over to almost but not quite the pos. on the top.
bcj is offline
Dadhawk (11-10-2019)
Old 11-10-2019, 11:31 PM   #62878
humfrz
Yes, they had generators. But, if a voltage regulator is working properly, how could a generator cause a parasitic drain on a battery?
humfrz
humfrz is offline
Lantanafrs2 (11-11-2019)
Old 11-11-2019, 01:02 AM   #62879
soundman98
soundman98's Avatar
humfrz
in the great words of AvE, batteries are angry pixie containment devices. alternators are angry pixie movers. sometimes, the pixies get angrier than the movers or the containers are designed for!
Old 11-11-2019, 01:13 AM   #62880
soundman98
soundman98's Avatar
yeah, i'd definitely try disconnecting the alternator next. but obviously somethings not shutting down. automotive electrical systems have changed a lot over the years-- used to be any load over 0.5A was considered excessive, anything under that was 'normal'. now i'm told some modules can consistently draw less than that when they're running properly. but many rely on signals from other modules before they shut down. lose that signal in any number of ways and the module will continue drawing power until there's none left.
my parents have had a '94 and a '99 (technically a late-production '98), both have had issues with random grounds from time to time rotting out. so if the alternator doesn't show anything, i'd definitely try locating and inspecting the various grounds that are exposed to the elements within the engine bay.
one time, the starter ground came loose, and through whatever voodoo, the shortest electrical path for the power was through the 18 gauge horn wire. couldn't figure it out, tried starting it 3 times, stopped trying when magic smoke came out of the grille-- a long ways from the starter location.
agreed, but a maintainer is sometimes easier than tracking down the real issue!
Dadhawk (11-11-2019)
Old 11-11-2019, 01:41 AM   #62881
humfrz
Ahhh…….haaaa! That explains it! -
humfrz
humfrz is offline
Old 11-11-2019, 01:55 AM   #62882
humfrz
A salute to all of you Veterans out there.
humfrz
humfrz is offline
The Following 11 Users Say Thank You to humfrz For This Useful Post:
bcj (11-11-2019), Clutch Dog (11-11-2019), Dadhawk (11-11-2019), echo419 (11-11-2019), JD001 (11-11-2019), new2subaru (11-11-2019), NoHaveMSG (11-13-2019), ScoobsMcGee (11-13-2019), spike021 (11-13-2019), Spuds (11-11-2019), Stephen W. (11-11-2019)
Old 11-11-2019, 09:37 AM   #62883
....agreed, but a maintainer is sometimes easier than tracking down the real issue!
Thanks for all that. I agree on this as well, if it were more feasible, at least until I could find it. Unfortunately the Suburban lives in the out of doors with no electrical source near it. I'm going to charge it every couple of days until I find the issue.
Alternator test next.
Dadhawk is offline
Old 11-12-2019, 11:41 PM   #62884
Will BRZ
Damn that's crazy...
Drives: 2015 BRZ
Damn finally working again
Will BRZ is offline
The Following 5 Users Say Thank You to Will BRZ For This Useful Post:
Clutch Dog (11-12-2019), korhun (11-13-2019), soundman98 (11-13-2019), spike021 (11-13-2019), Ultramaroon (11-13-2019)
Old 11-12-2019, 11:49 PM   #62885
Clutch Dog
Drives: 2017 BRZ PP , 2005 Saab 97X
i was literally about ready to reactivate my nasioc account to start selling some products
this forum has the biggest "will it fit my brembos" posting as well
that was knarly as all get out
and missed the usual suspects
humfrz, soundman, spuds and the like
Clutch Dog is offline
The Following 7 Users Say Thank You to Clutch Dog For This Useful Post:
humfrz (11-13-2019), korhun (11-13-2019), Nevermore (11-13-2019), ScoobsMcGee (11-13-2019), soundman98 (11-13-2019), Spuds (11-13-2019), Will BRZ (11-13-2019)
Old 11-13-2019, 12:19 AM   #62886
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
What year is it??
NoHaveMSG is offline
The Following 5 Users Say Thank You to NoHaveMSG For This Useful Post:
humfrz (11-13-2019), korhun (11-13-2019), Nevermore (11-13-2019), ScoobsMcGee (11-13-2019), Ultramaroon (11-13-2019)
Old 11-13-2019, 12:29 AM   #62887
soundman98
soundman98's Avatar
What year is it??
doesn't matter, it's too late for most.
Old 11-13-2019, 12:44 AM   #62888
Ultramaroon
not playing cards
Ultramaroon's Avatar
Jeez, that was awful. I had to talk to people.
Ultramaroon is offline
The Following 5 Users Say Thank You to Ultramaroon For This Useful Post:
korhun (11-13-2019), Nevermore (11-13-2019), ScoobsMcGee (11-13-2019), Spuds (11-13-2019), Tcoat (11-13-2019)
