Old 04-13-2015, 01:33 AM   #6245
FT86RGV
Originally Posted by Fizz View Post
Its terribly difficult to replace them without removing the elbow, but it can be done with lots of patience and swearing. When I replaced mine to brass fittings, I simply snapped off the plastic fittings (helps when the weather is cold) then unscrewed the remaining piece.
But I found it next to impossible to screw in the new 90deg barbed fittings. Instead, what I did was get 2-piece fittings to make it 90deg. If that makes sense.
And get a set of crow foot wrench....it'll help massively.
This is pretty much what I figured I would do. But out of curiosity, is it terribly difficult to remove the elbow and put it back on? Which Loctite is used on the bolts and anyone know what to torque the bolts too when putting it back on? Sorry if this is answered somewhere earlier in the thread.
FT86RGV is offline   Reply With Quote
Old 04-13-2015, 10:34 AM   #6246
brianhj
Drives: 2017 Camaro 1SS
Remove the whole manifold and blower from the engine. It's a pain in the ass but it's an even bigger pain in the ass to try to replace the fittings or remove the elbow while the manifold is installed.
brianhj is offline   Reply With Quote
Old 04-13-2015, 10:57 AM   #6247
xxscaxx
Drives: 2013 SWP BRZ
removing the blower is completely unnecessary and a complete waste of time.
All you need are the right tools to get the elbow off. If you don't have a set pick up allen key socket extensions with the ball ends on them. Something like this:
http://www.homedepot.com/p/Husky-Lon...S7PC/202934856
Thats all you need. its 6 bolts holding the elbow on the back. The bottom ones are tricky to get to but not really, they are directly under the top bolts so just follow a line straight down to find them. When putting them back on, put a little piece of tape around the allen bolts so you can just guide the bolt into the hole to screw them back in, then simply pull back and pull the tape off.
I also don't recommend snapping the fittings off to pull them out easily. Why break a fitting that isn't broken? You never know if you may need it in the future. Thats just me though.
xxscaxx is offline   Reply With Quote
Old 04-13-2015, 04:54 PM   #6248
brianhj
Have fun with that!
Old 04-14-2015, 09:38 AM   #6249
vaderbloke
Drives: 2014 Subaru BRZ
Just had a belt fail on me Thank God I had a spare. I am running a 69mm pulley with a K061015 belt, but heard elsewhere that K061010 would be better with pulleys < 72mm. Any opinions/experiences?
vaderbloke is offline   Reply With Quote
Old 04-14-2015, 10:54 AM   #6250
R3NIK
R3NIK's Avatar
Drives: 2013 FR-S/C
I'm running the 70mm and had my K061015 fail two weeks ago. I replaced with a K061010 and it's marginally tighter and seems like a better choice. No issues so far. Was able to overnight it from Amazon for less than $30.
R3NIK is offline   Reply With Quote
Old 04-14-2015, 12:20 PM   #6251
vaderbloke
Thanks - I may try that.
I replaced my failed K061015 with a K061015RB that I had bought earlier. I couldn't find a K061010RB. I may call Gates.
Old 04-14-2015, 12:59 PM   #6252
vaderbloke
Gates got back to me really quickly - they suggested the K061010HD:
[ame="http://www.amazon.com/Gates-K061010HD-Micro-V-Belt/dp/B001CIAOBO"]Amazon.com: Gates K061010HD Micro-V Belt: Automotive[/ame]
Old 04-14-2015, 01:31 PM   #6253
CK_Bladesmith
CK_Bladesmith's Avatar
Drives: Raven FR-S
My stock innovate belt keeps trying to slip off as well. I always carry a wrench and 14mm socket just in case. Also just ordered the belt you linked.
Raven FR-S mods: Unichip, Ground Control street coilovers with camber plates and strut tower brace, SPC Lca's, Drag DR-38 wheels with Dunlop Direzza DZ101s, Perrin CAI and silicone inlet tube, Perrin 3" resonated catback, Perrin high flow catted front pipe, Rev Works UEL header.
CK_Bladesmith is offline   Reply With Quote
Old 04-14-2015, 01:38 PM   #6254
xxscaxx
Originally Posted by brianhj View Post
Have fun with that!
I did it multiple times when i had my innovate. Removing the whole blower is completely unnecessary. The more you remove bolts/parts the more likely they are to break or strip over time, not to mention the gaskets that seal the manifold to the block that are meant to be a one time seal.
I find it funny how people think it so hard to remove 6 bolts, just because its in a tight location. If you have the right tools its easy. If you don't, its a nightmare.
Old 04-14-2015, 02:30 PM   #6255
R3NIK
R3NIK's Avatar
Drives: 2013 FR-S/C
I wonder how the HD compares to the Blue belts I've heard about.
Old 04-14-2015, 02:34 PM   #6256
brzaapi
CAR-AHOLIC
brzaapi's Avatar
Drives: 2018 BRZ Ts - CWP
I would like to know this as well. I am installing my kit this weekend.
Track Toy - 2018 BRZ Ts - CWP
Daily: Audi TT RS
DD/4WD - Colorado ZR2 Bison - Mallett Supercharger
brzaapi is offline   Reply With Quote
Old 04-14-2015, 03:15 PM   #6257
brianhj
They're o-rings... Just put more grease on them.
Unless you're an idiot and over-torqueing the bolts you're not going to break/strip any of them lol.
Old 04-14-2015, 03:23 PM   #6258
xxscaxx
Unless you're an idiot and over-torqueing the bolts you're not going to break/strip any bolts lol.
O rings are meant for one time use (not saying you can't reuse them, but you really shouldn't)...And taking off bolts over and over again will wear them out, they aren't indestructible lol, not to mention you are unbolting steel bolts from an aluminum engine block so anti seize is a must (which should be done regardless).
You can waste your time however you want. I'm just here to remind you of it. It can be done either way, but like I said, it's completely unnecessary. Why disconnect fuel lines over and over again, multiple bolts, clamps, etc. if you can't see how many more risk factors there are pulling off the entire manifold then I don't know what to tell you.
2 whp better than n/a e85, 2 whp? you're an idiot., 2screwsbetterthan0screw, 65 whp better than na e85, bspt fittings ftl, hate u all me no have sc, im just here for the tags, inorite!, it's no turbo but, only big numbers matter, screwyou, whine sexier than turbo, whines_more_than_your_gf, wts grey market butthurt.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 12:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 05:14 PM
