Old 04-07-2015, 12:31 AM   #6217
Vten
Drives: Too heavy
This last week has been a complete nightmare for me ...asked a local shop to install my intercooler upgrade kit onto my existing non ic and moto flex fuel kit and has the P0171 bank 1 too lean. I replaced both of the plastic fitting behind the blower with the brass bspt and tightened them as much as we can but the rpm is still increase when we spray some brake cleaner ...
I want to split open the blower again and reseal them using red permatex silicone around the edges where the bolts are , do you guys think it's a good idea ?
Really need some input at this point ...
Thanks guys
Vten is offline   Reply With Quote
Old 04-07-2015, 10:53 PM   #6218
s2d4
s2d4's Avatar
Originally Posted by Chad86 View Post
Anyone run a vented hood for their supercharger? Looking at the RKSport hood to pull more air.
Need more air out bro
The Following 2 Users Say Thank You to s2d4 For This Useful Post:
Chad86 (04-08-2015), Dream20b (04-08-2015)
Old 04-07-2015, 11:59 PM   #6219
Chad86
DrivinginDreams...Cloud86
Chad86's Avatar
Drives: Toyota GT86
Varis vented hood with rainguards looks like a good option.
Not sure if I should be going with or without the NACA duct with the supercharger though.
The more air the better I would think.
Chad86 is offline   Reply With Quote
Old 04-08-2015, 02:45 PM   #6220
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Hey everyone, here to announce the official release of version 8.83 of our Innovate tunes for intercooled systems.
From 8.65, 8.83 offers the following improvements:
Improved traction control algorithms specifically for the Innovate kit in Flex Fuel and pump gas variations.
Tunes support anything from a 69-75mm pulley without changing the tune.
More low end torque, specifically 10-15ft-lbs from 2500-4500 rpm.
Smoothed out acceleration on the very low end, 1500-2500rpm range.
Version 8.83 of the Innovate tune will be a paid update, requiring a service fee of $65 to update from 8.65, available here: http://www.delicioustuning.com/service_work
PSA on the side:
Common issues if you're experiencing problems with your car:
Poor Idle, Acceleration, Prone to Stalling: The plastic fittings on the back of the supercharger are leaking, guaranteed. If there is ANY movement of the fittings at all, there is a vacuum leak causing the problem. You need to remove the manifold in order to tighten the fittings enough to fix the leak; it is recommended to replace with quality brass fittings at this time. If these leaks are not fixed, this can cause preemptive engine damage.
The next potential cause of the above issue are the bolts that connect the supercharger to the intake manifold. These bolts are known to break, or not be torqued down enough and cause leaks again. This will also cause engine damage if not addressed.
Poor Throttle Response, Loss of Power, Lean AFR: Where the OEM airbox connects to the Innovate/Sprintex intake tube, directly after the MAF sensor, the clamp provided is quite often overtorqued, which causes the plastic intake tube to deform and skew airflow after the MAF sensor.
Car will cold start okay, but after 15-45 seconds when the car switches to port injection at idle, the car dies and won't start again: Please make sure you switched over the rubber injector grommets from the OEM intake manifold onto the Innovate/Sprintex manifold. Without the grommets, the injectors cannot seal, causing a major vacuum leak. The only reason the vehicle is able to run at all in this condition is when direct injection is operating alone.
I know these problems and solutions may have been presented before, but I thought it'd be nice to compile them together and put it in the latest section of the thread here.
Sincerely,
Zach
The Following 5 Users Say Thank You to DeliciousTuning For This Useful Post:
brianhj (04-10-2015), CK_Bladesmith (04-08-2015), poorsche (04-08-2015), sato (04-08-2015), whataboutbob (04-08-2015)
Old 04-08-2015, 03:07 PM   #6221
xxscaxx
Drives: 2013 SWP BRZ
Thanks guys
You shouldn't need that...did you put teflon on the fittings?
xxscaxx is offline   Reply With Quote
Old 04-08-2015, 04:48 PM   #6222
brianhj
Drives: 2017 Camaro 1SS
How do I get the 8.83 update
brianhj is offline   Reply With Quote
Old 04-08-2015, 05:26 PM   #6223
DeliciousTuning
8.83 is only for intercooled kits, you're non-intercooled correct?
Sincerely,
Zach
Old 04-08-2015, 06:47 PM   #6224
CarzCarzCarz
CarzCarzCarz's Avatar
Drives: 2014 WRB BRZ
PSA on the side:
Sincerely,
Zach
Does this new tune address the issue when accelerating from a stop where the engine stumbles/dips at low revs? See post #5925 for reference.
Also, why is this a paid update where 8.70 wasn't charged for?
CarzCarzCarz is offline   Reply With Quote
Old 04-08-2015, 07:25 PM   #6225
8686
8686's Avatar
Drives: 86
PSA on the side:
Sincerely,
Zach
Payment sent.
VOLK LE37 17X7.5, SWIFT Springs, Bilstein B8, HKS intake duct, Cosworth Air Filter, HKS headers, PLM Over Pipe, EVS Down Pipe & Exhaust, FD 4.55, GFB pulleys, Axle-Exchange Drive Shaft, Mishimoto oil cooler, Cusco F&R strut bar, TRD door stabilizer, Innovate SC, Delicious Tuned
8686 is offline   Reply With Quote
The Following User Says Thank You to 8686 For This Useful Post:
Old 04-08-2015, 07:46 PM   #6226
DeliciousTuning
Hi,
Version 8.70 or 8.75 were never an official release but more of an test bed over 8.65 for a couple who wanted to try out the changes we were working on. If you have an issue with one of these tunes we recommend reverting back to 8.65 as this has been a very reliable tune for over half a year now for literally everyone around the world.
As for the stumble/dip, it looks as though there are only a handful (3 from what I can tell) that have this issue. We have not experienced this particular issue on our in house development vehicle (13 BRZ Manual) running a inter-cooled stage 2 package with 75mm, or 69mm pulley on 91 or E85. Maybe this was specifically on auto's or maybe a small vacuum leak since this is usually a tell tale sign of a vacuum leak.
The new version 8.83 is a paid update because we now maintain a database of over 250 customers on this kit and have been offering free updates for nearly 2 years. At this time it is just not feasible to provide each customer their specific custom features set at no charge:
Custom features sets that are unique to each tune we maintain:
1. FlexFuel Upgrade
2. FlexFuel Input for Rear O2 or CPC
3. E85 Transition Maps
4. Launch Control
5. Auto-Blip
6. Flat Foot Shifting
7. Per Gear Rev Limit
8. Traction Control
9. 91-100 Octane or RON fuels
10. Cold Air Intakes
11. Exhaust System
12. Throttle Control (Soft to Drag)
13. Valet Mode
Cheers,
William Knose
Old 04-08-2015, 08:56 PM   #6227
Vten
Drives: Too heavy
I did. And the rpm still going up Everytime i spray the brake cleaner around the fitting .
Most likely the blower will be split apart again this weekend, I think that the best option.
Called mike@moto , and he said the car is should be okay to drive around, but I'm still worry if it'll do more damage to the engine .
Old 04-08-2015, 08:58 PM   #6228
CK_Bladesmith
CK_Bladesmith's Avatar
Drives: Raven FR-S
Put brass fittings with Teflon on them and then put rtv sealant around the outside. No more leaks
Raven FR-S mods: Unichip, Ground Control street coilovers with camber plates and strut tower brace, SPC Lca's, Drag DR-38 wheels with Dunlop Direzza DZ101s, Perrin CAI and silicone inlet tube, Perrin 3" resonated catback, Perrin high flow catted front pipe, Rev Works UEL header.
CK_Bladesmith is offline   Reply With Quote
Old 04-08-2015, 09:08 PM   #6229
Vten
Drives: Too heavy
Hmmm, red hi temp one ?
Old 04-08-2015, 09:13 PM   #6230
CK_Bladesmith
Drives: Raven FR-S
Nah. I just used a black rtv that comes from a pressurized can. It's used to make head gaskets so it can easily take the heat. Got it from advance auto, although I don't remember the name of it.
2 whp better than n/a e85, 2 whp? you're an idiot., 2screwsbetterthan0screw, 65 whp better than na e85, bspt fittings ftl, hate u all me no have sc, im just here for the tags, inorite!, it's no turbo but, only big numbers matter, screwyou, whine sexier than turbo, whines_more_than_your_gf, wts grey market butthurt.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 11:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 07:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 01:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-18-2012 12:38 AM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 06:14 PM
