#603 |
Drives: 2017 Toyota 86
FR-S / BRZ Wheel Directory, Gallery and Fitment Guide Chart
First set of aftermarket rims for the 86. There enkei rs7 17x7 et42.
#604 |
Drives: 2017 Subaru BRZ Limited with PP
I see that Discount Tire carries these for $99 in black, but they claim they don't fit a 2017 Subaru BRZ Limited with the Performance Package, but it sure looks like that's what you have in your picture right? Did you have to add spacers?
https://www.discounttire.com/buy-wheels/vision-cross Last edited by jredders; 09-24-2019 at 08:43 AM. |
#605 |
BC DS Coilovers
Voodoo13 RLCA Voodoo13 Toe arms Michelin Pilot Sport 4 S 255/35/18 ESR SR05 18x9.5 +35 ![]() ![]() ![]() ![]() Sent from my Pixel XL using Tapatalk |
#606 |
Drives: '13 Scion fr-s
I was originally looking at TSW Nurburgrings and Konig Dekagrams and were told these were reps... Is this true? I thought these companies had good reputations.
Which companies aren't considered to make reps but still have affordable options for daily use and occasional track use? Are Enkei RPF1's the only real option without spending $400+ per wheel? |
#607 |
Drives: 2013 Subaru BRZ Premium WRB
Hi all,
I am new to the BRZ (FRS and 86) community and interested in buying rims for my (almost) stock '13 BRZ. Please note I am on STOCK suspension and STOCK struts, I am not planning to change these to coilovers or add lowering springs and would like the fitment to be for fully stock brz suspension (WITHOUT SPACERS) The size of these wheels and tyres are as follows - FRONT: Enkei RS05RR 18x8.5 42 INSET 225/40/18 REAR: Enkei RS05RR 18x9.5 43 INSET 235/40/18 I have used the (wheel-it-fit) visualiser and it says it will hit the strut, however after reading posts and forums I am even more confused. I am not wanting to roll fenders, trim or grind struts, not wanting to use spacers or any modifications of that nature. I appreciate your consideration and keen to hear from you all. CHEERS!!! LINKS: https://enkei.com/shop/wheels/racingrevolution/rs05rr/ |
#608 | |
Only happy when it rains.
Drives: series.blue
you will take a performance hit running 18's. It is so not worth it. Even though the wheels themselves are a decent weight, the tires will be heavier. Also you do not want to stagger wheels on this car, especially if you do not want to modify anything else, unless it is a show car that you do not drive daily. |
#609 |
Evening Primrose
Hey folks, wanted to add these to the list as I was looking myself.
Kansei KNPs 18x9 +35 bronze Continental Extreme Contacts 235/40/18 Silvers Neomax coilovers 1inch drop No rubbing at all.
#610 |
Drives: 2018 BRZ tS
Ray's Gram Lights 57CR Wheel - 17x9 / 5x100 / Offset +38
Michelin Pilot Sport 4 S 245/40/17 Stock Suspension
#611 |
Drives: Toyota 86 Gts 2013
2013 Toyota 86 Gts Asphalt
18x8.75 Hussla 030's (basically an Aussie version of xxr 530's) Offset +40Front +35Rear 235/40/18 PS4's (Stock suspension ...for now. Soon Eibach Pro or Sport) ![]() ![]() ![]() ![]()
#612 |
Drives: 2014 Scion FR-S
16" Work Equip 05
Work Equip 05
16x8 Fronts are +29mm offset Rears are +17mm offset Those are my own measurements, there are no markings in them other than 16x8, as they are 3 piece wheels. I guess these are one of those few old school wheels that have a 5x100 pcd? Stock ride height taken last year... ![]() ![]() ![]() Mildly lowered on TEIN Flex A taken recently... ![]() ![]()
#613 | |
Drives: 2017 BRZ PP (White)
I have Konig Hypergrams and I love them on the track. Konigs are reps but they are still good wheels, still good reputation. I don't get the problem with people wanting rep wheels. As long as they're not cast wheels, I'm fine with not spending $3000 on something to impress people I don't even know. |
#614 |
Human
Drives: 2015 BRZ Black
Method MR502 (non VT-Spec) 16x7 +30
Method MR502 Rally (non VT-Spec)
5x100 16x7 +30 215/55/R16 Stock suspension
"Always listen to experts. They'll tell you what can't be done, and why. Then do it." - The Notebooks of Lazarus Long
#615 |
Drives: 2019 BRZ
Apex Racing EC-7R 17x9 ET42 with Continental Control Contact Sport SRS+ 245/40 tires. No spacers. Just barely fits. I read that they wouldn't fit with a stock suspension, but no issues. Maybe because it's a 2020? Should be a non-issue soon once I install coil overs and lower it a touch.
#616 | |
Drives: 2018 Subaru BRZ Limited with PP
EDIT: Looked it up, looks like ET35, so yeah that makes sense. My 18x8.5 ET38's cleared with a good bit of space left over. |
| Tags |
| brz aftermarket wheels, brz wheels, fr-s aftermarket wheels, frs aftermarket wheels, scion fr-s wheels, scion frs wheels, subaru brz wheels |
| BRZ/FR-S Wheel Fitment Photo Topic | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 16 | 07-12-2012 04:16 AM |
| BRZ/FR-S/86 Wheel Fitment Simulators | JDMSushi | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 0 | 07-05-2012 10:49 PM |
| Stock Suspension and Wheel Fitment | bneale | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 11 | 06-29-2012 07:42 PM |
| Wheel size and fitment | bsclywilly | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 48 | 03-27-2012 12:34 PM |
| Wheel fitment | sfwg | BRZ First-Gen (2012+) — General Topics | 6 | 10-28-2011 06:33 PM |
