Old 04-06-2014, 09:26 PM   #603
steve99
Originally Posted by vgi View Post
@AdrianG @steve99 @Td-d @all
ok guys, it's warmer and i finally got few hours today to spend on my logcfg.txt and check my thoughts.
i think that the onboard logging code seems to be buggy or has some kind of limitations.
1. i got the defog switch to work by defining all params in ascending sorting by mem addresses.
2. i have 73 params defined, if i enable all of them the logger just chokes with logcfg.out empty and no csv file. Either there is a limit on number parameters or theres is limit on length of parameter name. or something else.
here's my cfg file: https://drive.google.com/file/d/0B4i...it?usp=sharing
That good to here , I still have not got defogger working will try the ascending order trick.
also noticed when I added extra parameters for defogger it seemed to upset my RPM trigger, even if I had defogger stuff commented out , it still triggers but seems to trigger at about 1000 rpm instead of zero so got heaps of log files every time i went to idle. Running with no triggers it fine will have to look at it some more when I get time.
Thanks for update.
Old 04-07-2014, 10:19 AM   #604
AdrianG
Generally Well Liked
Drives: '08 STi Hatch, '11 Outback 3.6R
73 parameters is a lot, probably too many. I have tried re-ordering my logcfg.txt by memory address, I thought when the config file was parsed that it would be done automatically by the OP2 but if it helps then i'm not complaining.
I'll try this out with the defog trigger and see if there's any improvement. I've updated the logcfg.txt on my dropbox but it's not tested yet.
AdrianG is offline   Reply With Quote
Old 04-07-2014, 01:08 PM   #605
D-VO
Drives: Whiteout FR-S, Evo 8 RS
Hey guys. Just wanted to let everyone know that I was able to successfully reflash my ROM with 10 revisions so far. The RR logger with OBD 2 "logging protocol" ticked works just fine but its missing a few parameters that aid with tuning. I can't wait to see what else is in store. FFS and LC would be awesome! FLKC logging would be amazing! Thanks!!
D-VO is offline   Reply With Quote
Old 04-07-2014, 01:19 PM   #606
stugray
Drives: 2013 GBS BRZ Limited
FWIW - (may not be related) - the tactrix guys admitted that they had found some sort of bug when I was trying to log only the analog voltages that appear on the OBDII connector.
No trigger would make the tactrix start logging.
You needed something from the OBDII (ECU) traffic to "kickstart" the logging.
I never got that resolved, but you might be on to something.
Old 04-07-2014, 01:42 PM   #607
vgi
Drives: frs
you can try out straight my config file, it worked for me this morning. then if it works for you, you can mod your own file.
vgi is offline   Reply With Quote
Old 04-07-2014, 02:30 PM   #608
AdrianG
@vgi I tried out your config, commented out a few things and added a few things and it's working with the trigger! I have no idea what was wrong with my file, but even with the triggers commented out it wouldn't log for me. Thanks for providing that.
Old 04-07-2014, 04:07 PM   #609
Td-d
Garden variety obsessive
Drives: 2009 Sti Hatch; 2015 Audi RSQ3
So you got the defogger trigger working now with reshuffling the parameters?
Td-d is offline   Reply With Quote
Old 04-07-2014, 04:15 PM   #610
AdrianG
I ended up taking @vgi's file and modifying it to use the parameters I wanted (and took out the conversion to MPH etc). I don't know what went south with the file I was working off, it wouldn't throw any kind of error, all the parameters looked fine in logcfg.out but no matter what the triggers would not work and with them commented out it still would not start logging.
Either way, it works and I'm going to try doing some real logging on the way home today... Though sadly it will be a log of bumper-to-bumper Toronto traffic.
Yes, the trigger is working. Before giving up on my own file I did reshuffle and it didn't make a difference. It wouldn't even start logging with the triggers commented out.
Old 04-07-2014, 04:32 PM   #611
vgi
Drives: frs
here's another thought - can you double check that your file is just ascii file with ansi encoding?
Old 04-07-2014, 04:50 PM   #612
Td-d
Ok, cool - at least that's one down!
Old 04-07-2014, 04:55 PM   #613
Td-d
I guess you could use the OFT Stage 1 tunes if you wanted LC and FFS - eventually the stuff that NSFW and Merp coded will land up on this platform as well (I've chatted to Merp, he is having a look, time is always a constraint).
The Following User Says Thank You to Td-d For This Useful Post:
D-VO (04-11-2014)
Old 04-07-2014, 05:14 PM   #614
vgi
Drives: frs
btw, who coded LC and FFS? i was under impression it was proprietary code from Tinywrex? curious then if OFT guys implemented it from scratch or ...
Old 04-07-2014, 05:20 PM   #615
AdrianG
Well BRZEdit had it really early on, no telling where Vishnu got it, presumably RombinHood coded it and put it in whitespace in the factory ROM.
- AdrianG
Old 04-07-2014, 05:33 PM   #616
Td-d
Tinywrex was the first to provide a patch, NSFW then coded it up from scratch and posted up the source on the RR forums, this was then incorporated into Merp's work. Not sure where the OFT code comes from, but it's really quite a simple piece of code, not difficult to code up in C.
Close iJason Member's Car Journals 1 08-04-2013 08:26 PM
Close pche Engine, Exhaust, Bolt-Ons 3 08-04-2013 02:04 AM
Sorry. please close. finch1750 Scion FR-S / Toyota 86 GT86 General Forum 1 07-31-2013 01:00 AM
please close abutterman Wheels and Tires 0 07-05-2013 09:40 AM
