Old 10-16-2018, 12:09 PM   #603
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
Originally Posted by Racecomp Engineering View Post
BRAID has 16x7 wheels that fit over STI brembos.
Is the profile of the wheel barrel itself different from other wheels to facilitate this?
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
venturaII is offline   Reply With Quote
Old 10-16-2018, 01:04 PM   #604
Not entirely sure. BRAID wheels are designed to have a lot of brake clearance in general but I don't know how they do it.
- Andrew
Old 10-16-2018, 01:58 PM   #605
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
- Andrew
Never heard of them. Any weights on the the wheels they carry. I read their intro thread and some of the weights seemed heavy. Defeating the purpose in most cases of going smaller/lighter
SuperTom is offline   Reply With Quote
Old 10-16-2018, 02:13 PM   #606
They're not the wheel to get if you're looking for the lightest possible, but they are extremely strong and designed to take a beating. A lot of people looking for small wheels are focusing strength more than weight...these are used often in motorsports applications for rally, tarmac rally, endurance racing, etc. In those applications, weight is not as important as strength. These are made in Europe, flowformed, and built to order in whatever size/offset/color you want.
For a lightweight 16 inch wheel, the Enkei 16x7 RPF1 is a good way to go. I have those Enkeis and a set of 17x8 BRAIDs for my own car.
- Andrew
Old 10-16-2018, 02:27 PM   #607
venturaII
venturaII's Avatar
They're a longtime manufacturer/supplier of wheels for the rally community. Strength over light weight is what's valued there. Top quality wheels; not cheap.
Old 10-16-2018, 02:28 PM   #608
venturaII
venturaII's Avatar
Oops...what the other Andrew said...lol
Old 10-16-2018, 03:09 PM   #609
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
yes, Braid does have a line of forged wheels, but finding out actual weights is next to impossible.
Old 10-16-2018, 04:06 PM   #610
SuperTom
SuperTom's Avatar
gotcha they are more for the rally crowd
Old 10-17-2018, 01:38 AM   #611
churchx
churchx's Avatar
Drives: 2014 GT86
.. for rally crowd .. which makes them good choice for winter wheels. Extra strength may help on bad roads, good brake clearance may allow running smaller diameter wheels, in turn allowing usage of cheaper winter tires with also higher profile for more comfort/compliancy/wheel protection.
Old 02-26-2019, 12:24 AM   #612
newyorkreload
Drives: Safari build FR-S
Originally Posted by kuno View Post
Sorry, missed the photo
Sent from my SM-G920I using Tapatalk
I got the same set up on my summer rubber. I can't wait to put them on.
newyorkreload is offline   Reply With Quote
Old 03-13-2020, 12:38 PM   #613
RuyGuy2
Dysentery Enthusiast
RuyGuy2's Avatar
Drives: 2017 toyota 86
16x7" +35 sportline P4 Rims, advertised weight was over 16 I scaled mine at 15.7, The Tires are 225/60 General GMax-AS-05, on the scale at work the tire combination weighed 6.8 pounds less per wheel/tire.
I've had them on for a few days my impression of the 225/50r16 vs 215/45r17 is that the 16 inch wheel and tire set up is much more planted in the corner and during acceleration. There is a little loss in the steering response that was noticeable at first after driving the car for an hour or two I don't notice it anymore. Also once you start to get loose in a corner it's much easier to recover by backing off a little. Over all the 225 on a 16 is far better feeling than the 215 on a 17. Total cost for rims and tires was less than $1k.
This comparison is vs the stock wheel and tire setup. I'm sure there is some better 17" or 18" rim setup with 295's on 1/2" tall sidewalls, it took me quite a bit of deliberation to go with the 16" wheel over a 17" wheel. At the end of the day I wasn't going to go over a 225 tire most likely or larger than a 7" rim. It would have cost me nearly 175% more to do that with a 17" wheel and keep the weight of the wheel and tire I have with the 16" wheel.
RuyGuy2 is offline   Reply With Quote
Old 03-13-2020, 12:55 PM   #614
RuyGuy2
RuyGuy2's Avatar
Here is a link to the photos if they don't show up in the post, https://photos.app.goo.gl/ig4ij6awJpFWx7eg8
Old 03-13-2020, 01:05 PM   #615
why?
why?'s Avatar
Drives: series.blue
not one of those pictures work.
Old 03-13-2020, 03:10 PM   #616
Ernest72
Drives: 16 Silver BRZ, 04 Silver WRX wagon
Most rally wheels are more than 20lbs. A lot of subie guys use them as winters because weight and performance matter less. But summers you want lighter wheels.
Ernest72 is offline   Reply With Quote
Wheel Directory: Styluz S006 18x7.5 +40 Pavel Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 23 01-22-2014 04:16 PM
FS [SYD] 16 inch GT wheels and tires! luv85 Australia Classifieds 3 11-04-2012 06:15 AM
Help! Two 10 inch vs One 10 (or 12) inch cyntage Electronics | Audio | NAV | Infotainment 7 09-27-2012 11:20 PM
I need 19 inch wheels today! benqld7 AUSTRALIA 16 08-07-2012 08:33 AM
16 inch wheels for the base model!!! Blokatos Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 12-07-2011 11:17 AM
