#603 | |
Drives: 2017 BRZ PP, 2004 WRX
Ours is about 50/50. Those on a budget or doing 20-30 events per year are looking at the RT660's. People who are really gunning for times or have cars with enough camber to not totally chew through them are going A052. The A052 tends to not take the heat well. If you overdrive it, you can also scorch through a set very quickly. Like 30 runs quickly. Yet I've seen others go 150 runs on them surprisingly. The RT660's are basically a refined RE-71R. They might be a hair slower or right on par, but have been showing not to heat cycle out as quick. It seems like RE's are downhill after 60-70 good runs. By 100, you have tread, but the compound is getting hard. 660's are looking like they are more or less good to the end of tread. |
#604 | |
Drives: 2013 WRB BRZ
#605 | |
The change doesn't really affect me since I went into this knowing DS has other much faster cars. The fields at local events also aren't big enough to worry about but I might regret my decision for trying to compete in DS using a twin at a larger regional or national event.
#606 | |
#607 | |
Drives: 2016 Scion FRS
From the events that I've attended, the DS winners (which always seem to be from Steel Cities) are about a second slower than CS over 2 days and about 3 seconds slower than AS over 2 days. |
#608 |
Or a course design style that doesn't reward the agility of the Miata/86 and instead the power/torque of the turbo-hatches.
#609 |
I'll probably catch flak for this, but are you guys running 0w-20 or 5w-30 for autocross?
I ran Motul 0w-20 last year (first year with the car) and didn't notice anything terrible about it. On my WRX, I ran 5w-40 when 5w-30 was recommended, so it feels sketchy running a 20 weight. I know 5w-30 is recommended on these cars for "track use" to keep oil pressures up. The highest my oil temp got was ~240ish on the 0w-20 in grid after runs. I never saw anything near the 270 mark.
#610 |
Nah, I still use 0W-20, probably will switch to 5W-30 as I cross 100k miles and I'm a little more hopeful to hit up the track this year.
And you're not going to notice a difference unless you're doing consistent oil analysis and you run the engine to it's death. Not many have actually crossed 100k miles and the few who do run them hard have had issues. Cheap insurance, but not worth losing sleep over, unless of course you can't afford the $3k-$5k to replace the engine... Last edited by strat61caster; 02-12-2021 at 12:02 PM. |
#611 | |
Just run whatever you feel comfortable with since there's really no price difference between the 2 oil grades and no harm in the 0W30. I'm personally using Pennzoil Platinum Euro 0W30 year-round. |
#612 |
I was getting an intermittent CEL for slow cam response at pro solos running 0w20. I switched to 5w30 and it seemed to clear up.
#613 |
Drives: Yes
5w30.
I think DS will beat CS on the smaller courses with digs that I've seen the past couple years in the smaller lots many regions have to use now. I couldn't match my own time in a GS Civic Si with my CS FR-S two seasons ago because the Si could dig out of the 3-4 sub 20mph corners! On a normal national course, CS should have no trouble gapping DS. Pittsburgh does have strong DS drivers though. The PittRace national events I attended years ago favored the slow dig type course I mentioned above... if that is where events are held? |
#614 | |
Steel Cities' DS is basically called 'pro' class here. All the top drivers from other classes have moved into DS... and then the BRZ was reclassed, which is how I got tossed in.
#615 |
This past week I picked up OE crash bolts, StopTech Sport 309 pads, SuperPro 22mm FSB, and 215/40R17 Maxxis VR-1s. I just have to find time to install all the parts and I'm all ready to go for D Street prep.
#616 |
I ended up getting my A052's in 225/45/17 installed. Used a 3mm spacer and the performance pack +48 wheels. I thought they'd be close because everyone was saying the A052's ran so wide, but here's a good pinky finger's gap between the strut and tire. Much more than my RE's in 225 on a +53 wheel.
Initial impressions: They're not as vague as everyone is claiming. I hair less steering feedback/feel, but not that much less. Noise wise, they're QUIET. Comfort/impact wise they feel generally like a 200TW tire. Had them installed in 70 degree weather and now it's going to be 25 degrees the morning of our first event on Saturday. They'll be in a warm garage until I pull out in the morning. Think they'll be damaged driving 1 hour to the site?... then also sitting 2-3 hours while it's ~30 degrees and running them?
| SCCA Solo Street Modified (SM) Discussion | whataboutbob | Tracking / Autocross / HPDE / Drifting | 61 | 07-27-2020 10:03 AM |
| SCCA Solo C Street Discussion | Kido1986 | Tracking / Autocross / HPDE / Drifting | 4831 | 07-08-2020 03:52 PM |
| Gen3MR2's C Street (SCCA SOLO) Progress | Gen3MR2 | Tracking / Autocross / HPDE / Drifting | 0 | 02-12-2016 01:02 PM |
| 2014 SCCA Solo Nationals/Pro Solo Finale thread | edj | Tracking / Autocross / HPDE / Drifting | 206 | 09-19-2014 11:34 AM |
| Henry's C Street (SCCA Solo) progression | Kido1986 | Tracking / Autocross / HPDE / Drifting | 74 | 05-04-2014 08:20 PM |
