Old 10-06-2012, 10:21 PM   #6077
wrxgoose
WUB WUB
Drives: 2013 Firestorm
Dude, I try Clit & they said it wasn't a word... WTF
did you try "Swag"?
wrxgoose is offline
Old 10-06-2012, 10:31 PM   #6078
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Originally Posted by wrxgoose View Post
did you try "Swag"?
nope, when I get those letters, I'll try it and see
ichitaka05 is offline
Old 10-06-2012, 10:34 PM   #6079
serialk11r
Drives: '06 AM V8V Coupe
@Dimman
You say your car is noisy? Are you able to hear groaning jackhammer like noises when the engine is at low rpm? If not, I think I need to do that steam cleaning thing on my engine asap...I can't tell what that noise is, but it can't be good
serialk11r is offline
Old 10-06-2012, 10:39 PM   #6080
Dimman
Kuruma Otaku
Dimman's Avatar
Originally Posted by serialk11r View Post
@Dimman
I have forged pistons, 3" exhaust and an open wastegate...
Plus a piggyback that can't figure out a stable idle to save its life.
Because titanium.
Dimman is offline
Old 10-06-2012, 10:43 PM   #6081
serialk11r
Ugh, Megasquirt3 time?
I'm just wondering whether all engines make a groan when you put a little bit of load on them at low rpm (accelerating out of first for example) and that this is the first car where I'm able to hear it because the engine is like 30 inches from my head, or if I have legit knocking problems or something like that. It's a rather loud jackhammer like noise, so I feel like it's abnormal since I've been in cars where you can hear the engine, I've been in cars where giving it gas at low rpm makes a shuddering and slight noise like this, but this noise is rather loud :/
Old 10-06-2012, 10:48 PM   #6082
Dimman
Kuruma Otaku
Dimman's Avatar
Groan?
Video would be better to describe.
The guy I want to do the tune is a Haltech dealer, I think.
Because titanium.
Dimman is offline
Old 10-06-2012, 10:50 PM   #6083
serialk11r
Groan?
Hmmm probably. However as a pianist who's done recordings, I'm always skeptical about the effectiveness of using a crappy camera mic or something to capture sounds. Like, exhaust sound clips... no don't take a video, get a proper omnidirectional condenser or ribbon mic and record it for me.
Old 10-06-2012, 10:54 PM   #6084
Guff
Now w/ over 400 womprats!
Guff's Avatar
Drives: BRZ LZR
STANDALONE! STANDALONE! STANDALONE!
PROEFI! PROEFI! PROEFI! On the fly Corn-Map switching for teh winz!
- The Ancient BRZ Sacrament
by Zaku
Guff is offline
Old 10-06-2012, 11:01 PM   #6085
wrxgoose
WUB WUB
i'm tired of being fat.
wrxgoose is offline
Old 10-06-2012, 11:04 PM   #6086
Dimman
Kuruma Otaku
Dimman's Avatar
Still better than 'groan'.
When I had a misfire issue with my 1jz car, I talked with the above-mentioned tuner over the phone and described the sound by trying to reproduce it with my mouth/tongue (sort of a farting noise) and he was instantly 'Check the coils for cracks under the rubber boot. ' Sure enough...
Point is the sound being close is far better than a written description most of the time.
For example I'm having trouble associating jackhammer with groan.
It's not the clutch chattering? Does the whole car buck a little, like just before a stall?
Keep in mind what is happening at low rpm/off idle. Air speed in is really slow so mixing sucks. At idle to compensate they throw in lots of fuel so enough evaporates to burn.
Have you tried slipping the clutch a bit more or using more rpm to see if the sound goes away?
Because titanium.
Dimman is offline
Old 10-06-2012, 11:09 PM   #6087
serialk11r
Yea that's true. I did a little bit of rudimentary "bsfc testing" at low rpm just letting it idle in different gears, and sure enough once the load is past like 30% it runs like crap and starts guzzling fuel.
Anyways the deal is that between idle (which is not consistent, it's anywhere from 650-900 after the car is warmed up depending on what mood the ECU is in, and that ECU is damn moody!) and about 1250rpm any throttle pressure at all will induce said groaning. Up till 1500rpm there is groaning if I do more than just barely tap the throttle.
Old 10-06-2012, 11:10 PM   #6088
Dimman
Kuruma Otaku
Dimman's Avatar
Eventually to sort out some of the tip-in, idle and part throttle issues, for sure. I think Haltech is going to be the one, though. Tuner prefers Vipec, but gets horrible pricing on them so recommends Haltech Platinum Series for bang-for-the-buck.
My other buddy is all about the MoTeC, but that would cost more than I paid for the car...
And no E85 here, so have to make do with ethanol-free 94.
Because titanium.
Dimman is offline
Old 10-06-2012, 11:16 PM   #6089
Dimman
Kuruma Otaku
Dimman's Avatar
Serial, aside from the noise, what does the car do?
Because titanium.
Dimman is offline
Old 10-06-2012, 11:20 PM   #6090
serialk11r
Pretty smoothly runs, some vibrations in cabin. Not much performance but that's to be expected at low rpm.
