#589 |
Yes the kit is legal since it's just a replacement bushing and offset bushings are allowed.
You can either use camber plates or lower control arms, but not both. I'd opt for camber plates. |
#590 |
Drives: Whiteout FRS
yep sorry ment Front LCA's arnt legal
life's greatest stories usually start with the words, "fuck it!".
#591 |
Night Owl
Drives: 2013 Subaru BRZ
Thread is now sticky! With this much helpful info in here, it seemed wrong NOT to sticky it. Thanks to all who have contributed!
#592 |
Drives: 2014 BRZ
Just picked up a P&L header (I think) and some Motiv pipes with only 3k miles on them for relatively cheap. Don't know when they'll go on, but I'm getting closer to my mild build. Swaybars, bushings, and a few other goodies to come from stranoparts.com in March more than likely.
#593 |
Anorexic
Drives: 2003 Honda S2000 Suzuka Blue
I was originally building towards SP but I'm considering redoing everything towards STX. The WDCR (Washington DC) told me the AOS is illegal in STX, because "the engine cannot be touched between MAF and exhaust header." I'm really blown, because I just purchased one before making up my mind for this season.
#594 |
Drives: 2014 BRZ
I'm 99% positive an AOS or other catch can is legal, so long as it doesn't interfere with the MAF or other input/output locations. Would have to look at the rule as written and the details of the parts purchased, but in general that kind of mod is legal.
#595 |
Drives: 2014 BRZ
Found it. Part of the Street/Stock ruleset. For 2014, it's under 13.10:
E. The installation of water expansion tanks is allowed. The installation is not altered.of oil catch tanks is allowed provided the function of the PCV system While the ST rules state you can't modify the PCV or MAF, you can add the catch can or AOS as long as it doesn't modify/replace the PCV/MAF. |
#596 |
fastest frs in sbg
Drives: sick ass ultramarine frs
So we can delete the rear cat as long as we have the 1st cat still on?
2013 ultramarine frs sold
2014 turbo ultramarine frs Sold 2014 firestorm frs |
#597 |
Dodging cones
Drives: 2013 BRZ Limited, 93 Z28
Correct. Or you can delete the primary cat (most aftermarket headers) as long as you have a secondary in stock location, as it is within 6" of the OEM primary
#598 |
Cone basher
Drives: 2017 Subaru BRZ Series.Yellow
You can delete both cats but you must have a cat within 6" of the rear most stock location.
#599 |
fastest frs in sbg
How about perrin mounts i have the read shifter bushing and the trans mount
#600 |
Dodging cones
All bushings are fine, as long as they contain actual material and not solid mounts (aka Aluminum)
#601 |
Drives: -'02 PSM WRX, '94 Miata, '13 BRZ
So... What is everyone thinking on tires since the RS3 seems to not be able to be found. R1R/ZII/Rival
![]() Sponsered by:Chasebays/Corr Performance Tuning/KartBoy/Bad Panda Motorsports/Racer-X Fabrication STX Build thread 14th/67 SCCA Nationals (2014) Last edited by SubiePig; 02-03-2014 at 03:43 PM. |
#602 |
Drives: Subaru BRZ Limited M/T
R1R's are only good for this year. 140 tread wear.
ZII's apparently will fit the stock rim In a 235/40/17. Chime in if that is a no no. As that is what I was going for on my next set of tires. My current Rival's are holding up well and are a blast. But change is good right. Sent from my iPhone using Tapatalk |
| Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? | PatrickSAN | Electronics | Audio | NAV | Infotainment | 22 | 11-14-2012 02:12 PM |
| SCCA sway bar rules | gmookher | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 09-01-2012 06:48 PM |
| Suggestion for vendor rules... | Tainen | Site Announcements / Questions / Issues | 31 | 08-15-2012 01:53 PM |
| Rules for posting in this section | Hachiroku | User/Vendor/Sponsor Reviews, Feedback, Comments | 0 | 06-25-2012 11:02 AM |
