go_a_way1
Old 09-15-2013, 03:59 PM   #589
epoch707
Drives: brz
Originally Posted by hamlet View Post
I love my Ap1. But it was starting to show the effects of age, chassis flex, rattles. And ofcourse I could learn to drive better, I was simply comparing cars
Chassis flex? wtf, you must be dreaming. the s2000 chassis is very stiff, even if pushed to the limit. If you are seriously racing the car then of course you must add reinforcement.
epoch707 is offline   Reply With Quote
Old 09-15-2013, 04:24 PM   #590
ST185RC
Drives: White Out FR-S
Any car chassis will flex over time regardless of how rigid it is when it leaves the factory floor. His AP1 is at least 10 years old as I'm not sure what M-Y he has for his car. He is saying that over time it's starting to flex more with metal fatiguing.
Please think a little deeper than bench racing....
ST185RC is offline   Reply With Quote
Old 09-15-2013, 06:39 PM   #591
epoch707
Drives: brz
watch the youtube video I posted:
[ame="http://www.youtube.com/watch?v=cGj3oC-wPF0"]Spoon - Type One Interview: S2000 - Type R Rigid Collar Gusset Plate - YouTube[/ame]
Spoon welds reinforcement plates and new subframes on its s2000 to withstand endurance races. Once reinforced, they are good for a 100 years as Tatsuru Ichishima says (founder of spoon and type one).
I don't think some dude's ap1 will have chassis flex because of racing, nor his cornering G's exceeding 1.xx. Daily driving, no chassis flex, more like rust and worn down bushings. Don't call it chassis flex, call it rust and worn down bushings buddy...
Old 09-15-2013, 07:44 PM   #592
fatoni
you can weld reinforcements to an frs too. its not something that is unique to the s2k so it doesnt hold weight in this conversation imo.
Old 09-15-2013, 08:21 PM   #593
Suberman
Drives: Subaru BRZ Sport Tech Satin White
I don't think so. You know there at DC 3 aircraft still flying and flexing away....
A closed coupe will not suffer significant metal fatigue in decades of use. Mild steel is very resistant to fatigue.
Open mild steel cars are known to suffer from several structure weakness unless built as a tub. Can't be done with conventional door cut outs. Building a durable open top mild steel car is difficult. Add a metal roof and the problem is solved, permanently.
Suberman is offline   Reply With Quote
Old 09-16-2013, 12:40 AM   #594
hmong337
Emperor JDM
hmong337's Avatar
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
Spoon is full of shit.
hmong337 is offline   Reply With Quote
The Following User Says Thank You to hmong337 For This Useful Post:
bolecailey (09-25-2013)
Old 09-24-2013, 05:34 PM   #595
iceman666
Drives: 2013 Subaru BRZ / 2001 Honda S2000
As an owner of an 2001 S2000 (with 37K miles) and a 2013 BRZ (purchased to replace my Prelude daily driver), I would say the following:
1. If you want one of the best pure sports cars on the market over the last 15 years (for under $25K) and/or want a car for track purposes, find a used S2K with low miles and enjoy the experience (you will not regret it).
2. However, if you plan on using this car as your daily driver, need a bit of extra storage space (bookshelf back seat comes in handy) and/or you live in the northeast the BRZ is very good alternative.
I actually purchased my S2K inspite of it being a convertible (with the goal of buying the hardtop). Given the limited use per year, I never purchased the OEM hard top (was never truly needed) and only purchased a fiberglass hardtop for track events.
As indicated in the other posts, both cars are similar in a lot of ways (with the BRZ being more user friendly as a daily driver). In terms of track use, I will disagree with a number of people on forum. The S2000 is a great track car (I've done multiple track events at Limerock and NJ Motorsports Park). With fresh tires (I still use SO2s), and proper heat in the tires, and a full tank of gas, the S2000 is not spin happy. Its very planted and drives like its on rails (unless you get your turn-in way wrong).
Both cars have their +'s and -'s, you can't go wrong either way. . . I'm just glad I own both.
iceman666 is offline   Reply With Quote
Old 09-24-2013, 05:44 PM   #596
iceman666
Also, in terms of the S2K looking "dated", beauty is in the eye of the beholder. That said, the front bumber on the 00' to '03 models does look a bit dated.
When I bought my S2K in November 2000, it looked great. . . When Honda revised the front bumber for 2004 forward (sharper look), my older bumper looked dated. I replaced my front bumber / grill in 2006 for the newer look and thought my S2K has looked as modern as most new cars on the road ever since.
Old 09-24-2013, 06:34 PM   #597
DarkSunrise
DarkSunrise's Avatar
Have you been able to get away with just a hardtop for the track, or do you pass broomstick as well?
2022 BRZ Build
2013 FR-S Build
Old 09-24-2013, 07:10 PM   #598
iceman666
The S2000 passes the "brookstick" test as well. A number of owners have run SCDA events at Limerock and NJMP without a hardtop, as the factory rollbars are fixed and (slightly) above the helmet height.
Old 09-24-2013, 08:50 PM   #599
DarkSunrise
Out of curiosity, how tall are you?
2022 BRZ Build
2013 FR-S Build
Old 09-25-2013, 01:59 AM   #600
fatoni
thats not how that works. cars dont pass broomstick tests. drivers do. besides, a hardtop isnt a piece of safety equipment at all. another issue is that i think you are supposed to have a harness when using a convertible and that usually means running a racing seat so the test shouldnt be much of an issue in the first place.
Old 09-25-2013, 07:50 AM   #601
regal
When you buy a 10 yo S2k you potentially get a complex double wishbone suspension with a bunch of dried-out bushings. They are difficult to replace without a press , I was quoted over $2k to rebuild the suspension with OE rubber that didn't include new struts and springs.
Plus the hard tops are difficult and expensive to obtain.
So low milage S2k $16k + rebuilt suspension $3k + hard top $3k = at least $22k for a car you need to pay for in cash. With interest rates low the FRS is just the better deal.
So for a daily driver I think the FRS is a better choice but in comparison to the S2k the FRS has a less desirable engine. I'd be more satisfied without the torque dip and the OE tune but those issues are fixable now.
The other thing is the twins are selling world wide better than the S2k ever did, so likely we will see low replacement parts cost in a few years. These should be fairly easy on the budget dd's.
2013 FRS Argento Silver 6MT
Mods:
Clear fender side lights
Tactrix ZA1JB01C 2014 Calib
regal is offline   Reply With Quote
Old 09-25-2013, 09:08 AM   #602
ZDan
ZDan's Avatar
Drives: '23 BRZ
No way a driver over 5'2" is passing the broomstick test with the stock S2000 roll hoops. Many organizations don't recognize factory S2000/Boxster/MX-5 roll hoops anyway. First thing I did with my S2000 was to install a HardDog roll bar for track events.
FR-S vs S2000 vang FR-S / BRZ vs.... 436 09-19-2012 05:52 PM
E36 M3 vs FR-S vs S2000 (for me) RearDrive FR-S / BRZ vs.... 48 07-02-2012 11:46 PM
S2000 or MX-5 balance Other Vehicles & General Automotive Discussions 10 11-01-2011 03:01 AM
S2000 from hell CyberFormula Other Vehicles & General Automotive Discussions 13 07-09-2010 10:05 PM
