go_a_way1
Old 05-21-2023, 05:02 PM   #5951
tomm.brz
Drives: brz 2017 hksv2
ywah i think outside of America hks is a cheaper choice usually
Also is a good kit, i like it more than jackson actually
The Following User Says Thank You to tomm.brz For This Useful Post:
Teseo (05-21-2023)
Old 05-21-2023, 07:34 PM   #5952
Teseo
Drives: frs
Wonder if you could add like blow off valve later to make chu chu noises
Old 05-21-2023, 07:46 PM   #5953
tomm.brz
these kits already have a blow off valve
blow off valves dont make that sound, the lack of a blow off valve does it in turbo systems when you get flutter
superchargers only make whoooosh sound when you release the throttle
Old 05-21-2023, 08:56 PM   #5954
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
Just stay on throttle and it will be more than loud enough
Breadman is offline   Reply With Quote
Old 05-21-2023, 11:08 PM   #5955
86Hakone
86Hakone's Avatar
Drives: 2020 GT86 Hakone
I found a decent clip of the sound the JRSC makes. This not my car just some random short.
https://www.youtube.com/shorts/mbBDA3yy0wY
86Hakone is offline   Reply With Quote
Old 05-22-2023, 06:42 PM   #5956
Ignore Your Doctor
Ignore Your Doctor's Avatar
Drives: 2015 BRZ WRB
Originally Posted by 86Hakone View Post
Yeah I went back and saw your previous post with the dyno sheet. Jackson Racing has a 375 a dyno sheet for the HBP with essentially the same setup so I guess its accurate. The highest my flex fuel sensor has ever read is 90% from a Sunoco near me but usually it's between 75-85.
Everything else on the car is stock except the radiator and oil cooler. I still drive the car 10/10ths like it was stock and it's holding up great so far with no issues. If it blows up I guess I can just build it faster.
If youre ever interested in tracking it I got nothing but good stuff to say about the jackson racing dual radiator oil cooler. I have had it since my car was NA. Even with spirited driving temps are cooler than stock idle.
Ignore Your Doctor is offline   Reply With Quote
The Following User Says Thank You to Ignore Your Doctor For This Useful Post:
Teseo (05-22-2023)
Old 05-26-2023, 01:20 PM   #5957
johnnyeisu
Does anybody have this problem with noise on the C38 kit?
Currently getting in touch with Jackson Racing about it but they seem to be ruling it as functional. Unfortunately for me it's ear-splittingly loud with the hood open and pretty bad in the cabin as well.
Have tried conditioning the belt and the shop that installed it has also checked the pulley.
johnnyeisu is offline   Reply With Quote
Old 05-26-2023, 02:18 PM   #5958
Breadman
Breadman's Avatar
I have never heard anything remotely like that. Honestly, I would keep the car off until you can figure it out.
What does your traction fluid look like? It almost sounds like there is an imbalance.
Old 05-26-2023, 03:13 PM   #5959
johnnyeisu
As I was given the green light by the manufacturer itself to drive, it's worked well for the past 5000 or so miles with advertised gains. The noise itself has been the only problem. I was told it would get better over time but it hasn't...
The traction fluid looks fine.
The response I've been given just now is that the whistle is present on most units and is in their opinion "fine". I could send it in for warranty inspection, but if there is no issue I will be charged $350.
Guess I'll die.
Old 06-01-2023, 05:43 PM   #5960
wheelhaus
wheelhaus's Avatar
Here's another thread on Rotrex noise. It might actually be normal.
If the thing makes solid power and all the right wooshing noises, and doesn't act up or do anything weird at high rpm, then it's probably just the same low rpm resonant harmonic noise the rest of us hear, yours just may be a little louder. It's really hard to tell without two installations side by side. Is there anyone in your area you could meet up with that also has a C38? Might be worth it to ask around for peace of mind.
wheelhaus is offline   Reply With Quote
Old 06-27-2023, 03:57 PM   #5961
Cstond151
Drives: 2020 Toyota 86 Hakone Edition
Just ordered my C-38 JRSC kit. I currently have a Jackson dual radiator oil cooler. I track my car so I know I’ll need a dedicated oil cooler. Has anyone capped off the oil ports of the DROC and just used it as a radiator with the c38 kit? Any issues with doing it that way? I would rather not have to replace the radiator again.
Cstond151 is offline   Reply With Quote
Old 06-27-2023, 04:25 PM   #5962
M0nk3y
I'd evaluate the performance of the DROC before splurging for something else.
IME, Harrop SC with E85, ACE Radiator Shroud, Verus Hood Vents and DROC I was able to keep coolant temps sub 200F and oil sub 230F in Alabama heat...
Kyle H. - #89 STX
Old 06-27-2023, 05:31 PM   #5963
Cstond151
Thanks for the feedback. Were you tracking your car? Mine is mainly a track car so it will see a lot of abuse.
Old 06-27-2023, 05:33 PM   #5964
M0nk3y
Yup, it was 85-90F ambient temps. IAT/ECT/Oil all logged on the video for reference.
Kyle H. - #89 STX
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 05:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 10:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 01:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 04:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 05:14 PM
