#5923 |
Senior Addict
Drives: 86 GT
Anyone here using the Delicious 8.65 version tune, and have throttle hesitation issues at low revs? In my case when moving off quickly from a standstill...as soon as I release clutch pedal and get on the throttle, it surges forwards as you'd expect, but then momentarily jerks/bogs down a little (around the 2200-2400rpm area) before picking up revs again. The only way to take off smoothly without the car jerking is to carefully let off the clutch doing it slower than I would normally do previously.
Same thing also happens during in-gear rolling acceleration if I get on the throttle too quickly at low revs. Contacted Bill and he said he's working on a 8.75 update which should sort this out....but I'm just wondering if anyone else is experiencing the same issue as me? By the way I've already checked all hoses and fittings....no leaks. |
#5924 | |
Drives: Raven FR-S
Mine does the same thing. No worries.
Raven FR-S mods: Unichip, Ground Control street coilovers with camber plates and strut tower brace, SPC Lca's, Drag DR-38 wheels with Dunlop Direzza DZ101s, Perrin CAI and silicone inlet tube, Perrin 3" resonated catback, Perrin high flow catted front pipe, Rev Works UEL header.
#5925 | |
Drives: 2014 WRB BRZ
Quite annoying as it feels the cars about to die when your trying to hurry and get out in front of traffic. |
#5926 |
Drives: 86
VOLK LE37 17X7.5, SWIFT Springs, Bilstein B8, HKS intake duct, Cosworth Air Filter, HKS headers, PLM Over Pipe, EVS Down Pipe & Exhaust, FD 4.55, GFB pulleys, Axle-Exchange Drive Shaft, Mishimoto oil cooler, Cusco F&R strut bar, TRD door stabilizer, Innovate SC, Delicious Tuned
#5927 | |
Senior Addict
Drives: 86 GT
#5928 |
Drives: 86
Outch. I was going to order the stage2 tune.
Now I have to wait for another month.
#5929 |
Drives: Too heavy
#5930 |
Drives: Subaru BRZ
I've been searching all morning but haven't been able to find the information:
Can anyone provide the hex bolt size for the 6 bolts that attach the rear intake chamber? See image below. TIA. |
#5931 |
Drives: 2017 Camaro 1SS
5mm
#5932 |
Drives: Subaru BRZ
#5933 |
Drives: 2013 WRB BRZ
So I'm looking into the stage 1 kit right now and wondering if these come with a base map tune or if it's just the tuner kit and it's up to you to to buy the EcuTek license and cable and source your own tuner out?
#5934 |
#5935 |
Drives: 2020 DGM BRZ Limited
#5936 | |
PhoneFlash by EcuTeK
Cheers, William Knose Delicious Tuning |
| Innovative ideas to increase interior storage capacity? | swift996 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-30-2013 10:45 PM |
| AVO vs Innovative | diss7 | Forced Induction | 32 | 01-21-2013 06:15 PM |
| Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 12:18 PM |
| Technical topic sub-forums | OrbitalEllipses | Site Announcements / Questions / Issues | 1 | 07-17-2012 11:38 PM |
| Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 05:14 PM |
