Pat.Thornton
Old 04-13-2017, 04:26 PM   #575
Ethereal05
Ethereal05's Avatar
Drives: 2015 BRZ Series.Blue
I am working with my local dealer to get it repaired. Will keep you all posted on my progress.
Ethereal05 is offline   Reply With Quote
Old 04-13-2017, 06:18 PM   #576
sato
sato's Avatar
Drives: Dodge Patitas
A TSB came out to replace the TOB, but only covered for 36k miles. Might want to look into getting that new TOB P/N (SU003-07349) installed rather than the old P/N (SU003-00802)
http://www.ft86club.com/forums/showthread.php?t=117440
Sent from my E6653 using Tapatalk
The Following User Says Thank You to sato For This Useful Post:
Ethereal05 (04-15-2017)
Old 04-15-2017, 02:29 PM   #577
Ethereal05
Ethereal05's Avatar
Awesome, looks I am rolling into the dealer with the TSB number...Thanks!
Old 05-23-2017, 09:10 PM   #578
bottle
Originally Posted by Oxyg3n View Post
I just left it as is for the time being because it has gotten really cold in the past few months and when weather is below 50F, the problem is almost eliminated. I'm sure it will come back again as summer is approaching, then I'll probably bring it in to check.
Any updates on this? I started getting the same sound, both pushing and releasing the pedal.
bottle is offline   Reply With Quote
Old 05-26-2017, 06:28 PM   #579
BFIFE22
BFIFE22's Avatar
Drives: 2013 GBS BRZ Limited
I had the same symptoms. You need to get grease (I used Lucas Oil Red N Tacky) around where the clutch fork pivot ball is. It's called the release fork support in the photo here. http://s315.photobucket.com/user/cam...lutch.jpg.html I used this photo to get a feel for the area and orientation of the clutch fork. You will need to pull the boot around the shift fork up to be able to access this area. You can also pull the top of the clutch fork toward the front of the car to gain a little bit of room. I used a paintbrush to get the grease worked around the area.
I let the grease sit for a few minutes then pumped the clutch pedal for about 20-30 seconds and the creak/squeak was gone.
APEXi / JDL / Perrin / Grimmspeed / Tein / Hotchkis / TRD / RAYS / Michelin / Raceseng / JPM Coachworks / SWEIDIT / Carsmo / TOM's / OFT / OEM Audio
BFIFE22 is offline   Reply With Quote
The Following User Says Thank You to BFIFE22 For This Useful Post:
wrh3 (05-28-2017)
Old 05-26-2017, 08:23 PM   #580
bottle
It's not the same squeak. I've had the clutch pivot squeak issue before and fixed it already with a NGLI No.2 EP Red Grease.
This other one is heard entirely inside the cabin. For this sound, you wouldn't hear it if you're outside and the doors are closed and someone is pumping the clutch.
Anyway, I figured it out already. It's the clutch master cylinder, the internal push-rod/plunger rubbing against the inner bore as it's too dry. As per the service manual, re-grease with SILICONE GREASE G-40M or equivalent. DO NOT USE THE SPRAY SILICONE LUBRICANT, IT WILL NOT LAST.
Use a toothpick or something thin with grease on the tip, push the clutch in all the way, and go ahead and grease the inside of the CMC.
The Following 3 Users Say Thank You to bottle For This Useful Post:
strat61caster (10-15-2017), Ultramaroon (05-28-2017), wrh3 (05-28-2017)
Old 05-28-2017, 04:18 AM   #581
BFIFE22
BFIFE22's Avatar
Good to know in case i starting getting that particular squeak
Old 09-14-2017, 01:08 PM   #582
cmihaylov
So 2 years ago I had to take my car in to get the TOB, pressure plates, etc. replaced due to this squeak...that stopped the squeak for 2 years and a couple of days ago it started again. This time it was squeaking only when I pressed on the clutch and not when releasing it. I figured it had to be the clutch fork. So I went outside, removed the rubber boot that's on top of the transmission and sprayed a generous amount of white lithium grease inside on the pivot point...squeak is gone now. We'll see for how long that lasts.
cmihaylov is offline   Reply With Quote
The Following User Says Thank You to cmihaylov For This Useful Post:
sato (10-01-2017)
Old 10-09-2017, 05:20 PM   #583
Zoid
Zoid's Avatar
Drives: 2015 Subaru BRZ Series.Blue CWP
Seems I'm having this issue. Gonna have to take it to a dealer and hope they fix it.
Zoid is offline   Reply With Quote
Old 10-09-2017, 05:22 PM   #584
cmihaylov
Try what I did above if you are out of warranty. If you are still under warranty, by all means take it to them.
Old 10-09-2017, 05:50 PM   #585
Zoid
Zoid's Avatar
Yeah I got the car in May and it's a MY2015 and I'm nearing 32,500 miles, so I think I'm in warranty?
Old 10-09-2017, 05:52 PM   #586
DrButtDrugs
yerp
Drives: 2015 WRX
Do you have a diagram or picture of the place that should be greased? I just wanna have an idea where to look before I climb under the car
DrButtDrugs is offline   Reply With Quote
Old 10-15-2017, 10:08 PM   #587
ZZT86
ZZT86's Avatar
Drives: BR86
I lubed the clutch fork pivots & TOB as best I could using HTB grease through fork/boot next to slave using a flexible plastic paddle & my fingers. I did this a few months ago, noise is gone & actuation is far smoother . . . for now.
ZZT86 is offline   Reply With Quote
Old 06-17-2018, 04:53 PM   #588
YandereValkyrie
Drives: '15 FRS
I just started hearing the whirr today, the clutch has been a bit squeaky for a awhile, I figured it was normal.. Just under 70,000km, taking it in tomorrow to see if they'll cover it under warranty since It has the 5yr/100k and I paid more for the extended coverage.. This bullshit comes up right as I'm in plans to get a second car
YandereValkyrie is offline   Reply With Quote
Loud 'Squeak' Noise From Clutch? Brndn704 Issues | Warranty | Recalls / TSB 23 07-20-2020 09:58 AM
Upgraded Clutch Squeak Rybot Issues | Warranty | Recalls / TSB 116 10-09-2019 03:10 PM
Clutch pedal adjustment gone wrong? Clutch issues. PulpBrah Engine, Exhaust, Transmission 12 03-06-2017 05:08 PM
Clutch Squeak CatDaddysBBQ Issues | Warranty | Recalls / TSB 4 07-14-2015 07:44 AM
Clutch pedal squeak. merino_frs Engine, Exhaust, Transmission 1 08-25-2014 02:00 AM
