12-08-2014, 11:47 AM | #575 |
Fbm uses PnP 12" Spal fans and they're own design rad. The fans used by Carolina dyno are actually a lower grade and cfm rating due to the straight blade design. An oil cooler with a fan will work better especially in stop and go traffic.
The Following User Says Thank You to Dipstik-sportech For This Useful Post: | yomny (12-08-2014) |
12-08-2014, 11:54 AM | #576 |
Drives: 2013 FRS Whiteout
Good info, i was going solely on pictures as i didn't have more info but this does seem like a better deal specially at a lower price.
The Following User Says Thank You to yomny For This Useful Post: | Dipstik-sportech (12-08-2014) |
12-08-2014, 12:21 PM | #577 | |
What kind of power output are you thinking? I'm a huge fan of the 20A 12" SPAL fans, and you only need to do some minor wiring to make them work. Which series is the Setrab you're thinking? 20 rows are generally a 1 or 9 series core. |
12-08-2014, 12:47 PM | #578 |
Drives: 2013 Black FR-S
The STOCK radiator hasn't proven to be a bottleneck at the track for multiple people. People need to stop assuming that the stock radiator is inadequate.
Control your oil temps well and if you want to do more ... address getting airflow through all the cores and out of the engine bay. This could mean vented hood or some sort of airflow mod, and/or powerful fans and/or replace the stock crash beam. No one to my knowledge has proven that more powerful fans will do anything on this platform ... yet. I think @CSG Mike is planning on testing that in the future.
12-08-2014, 12:49 PM | #579 | |
The big fans will probably go on sometime in January; we have a custom shroud to accommodate the fans, and will put them into production if there is demand. It's easy to fit fans with the JRSC; other systems may have some clearance issues depending on where piping is routed, etc. It may be on before Laguna Seca... |
12-08-2014, 01:15 PM | #580 | |
@sw20kosh i wanted to install a radiator because most turbo kits replace fans and thought it would be practical to install the rad along with the kit since i may endup needing it in the future.. on that thought, is what led be to opt for the upgraded rad with shroud and spal fans now rather than after or during the kit. Kind of preparing the ground for the future plans. Maybe going with a kit that doesn't replace fans at all would be better and focus on venting the heat? Just getting ideas here. |
12-08-2014, 01:34 PM | #581 | |
Oil temps have minimal correlation with output, except that the turbo may be oil or oil/water cooled, which adds heat to the oil. If the oil cooler is the first cooler in your airflow stream, a 9 series 20 row will probably be slightly on the too much side. If it's 2nd, after the FMIC, then it'll probably be perfect. 1 series and 9 have different widths; you're probably looking at a 9 series, which is 15" wide. |
The Following User Says Thank You to CSG Mike For This Useful Post: | yomny (12-08-2014) |
12-08-2014, 07:31 PM | #582 | |
I run a 25 row series 9 right behind the intercooler. It is doing great for track. It is overkill for street. I will live with it as all I need to do is block off some of the airflow to it in order to keep street oil temps nominal. I would say a 20 row is perfect if it is behind the intercooler.
The Following User Says Thank You to sw20kosh For This Useful Post: | yomny (12-09-2014) |
12-08-2014, 08:13 PM | #583 |
I'm planning on installing my oil cooler in the passenger fog light area.
This requires some long lengths of coolant lines, to and from the cooler from the sandwich plate, compared to a cooler mounted in the center of the radiator grill. I do not want my oil cooler sitting directly in front of my intercooler. Is the extra 2-3 feet of oil lines to the cooler a big deal? I know there's some pressure loss from running the cooler and longer lines. It just seems to me on my car the best placement is going to be the fog light passenger side (about as far away from the sandwich plate as can be) using the AVO ducting as well.. |
The Following User Says Thank You to mike the snake For This Useful Post: | Dipstik-sportech (12-08-2014) |
12-09-2014, 01:27 AM | #584 | |
Driving Coach
12-09-2014, 05:34 AM | #585 |
I don't think there's room because I moved my radiator and condensor forward for clearance. I don't think there's room in front of, or behind the intercooler now.
12-09-2014, 09:44 AM | #586 |
Drives: Toyota GT 86
Tell me please which one "sticks out to the back? I really need that one! I bought Mishimoto and it "pushes forward" and can't live together with the intercooler from the HKS V2 setup without major modification of mounting points.
12-09-2014, 03:54 PM | #587 | |
The Koyo is a "fatter" core. |
The Following User Says Thank You to CSG Mike For This Useful Post: | Efferalgan (12-10-2014) |
01-31-2015, 03:56 PM | #588 |
Drives: RX-7 / BRZ
Anyone know wether the DEI "cool tape" or "reflect-a-gold" are worth a damn? I've seen some go as crazy as wrapping the entire intake pipe and oil pan. Also has anyone had any issues with the spal fan melting?
@Reaper The Varis hood with the center NASA duct would be perfect for your setup with the holes in the cowl panel.
//2018 Crystal White Pearl BRZ Ts 2.2l Harrop Supercharged Last edited by Kiske; 01-31-2015 at 04:06 PM. |
Similar Threads | ||||
any serious benefit Heat Tapes? | Djen | Engine, Exhaust, Transmission | 22 | 02-18-2014 03:20 PM |
Heat bad for your car? Ways to cool it? | BushMan | Scion FR-S / Toyota 86 GT86 General Forum | 35 | 08-01-2013 10:15 PM |
Misfire with heat? | bigjake | Issues | Warranty | Recalls / TSB | 2 | 04-28-2013 09:02 PM |
Do I Need a Heat Shield? | arleewa | Engine, Exhaust, Transmission | 1 | 01-08-2013 06:37 AM |
Overpipe Heat question | Amadeus | Engine, Exhaust, Transmission | 5 | 12-19-2012 01:18 AM |
