07-04-2013, 07:24 PM | #575 | |
07-04-2013, 11:38 PM | #576 |
Drives: it has 4 wheels and a motor
tune updates?
07-05-2013, 12:39 AM | #577 |
WELL WELL WELL - I am simply exstatic about the results tonight. Toma tuned us up nice, didnt invest too much time in it and he still wants to play around with it more.
We got it working at 2500 RPM no problem and this thing is a TORQUE monster, it just rockets away. The top end feels soooooooo good now too, its just buttery smooth and pulls hard all the way to redline. The AFR's are much better as well. It doesnt go quiet as rich up top as it did with the stock tune. I cant wait to get some more video's up for you guys in the coming days. We did another pull after this with a extra little battery pack that Rob rigged up and made ALMOST 210hp but we arent posting that dyno as that will probably be considered a power adder or something like that. Rob didnt want to artifically inflate the numbers for you guys, he is straight shooter and Toma is a Tuning master!! Without further ado, our preliminary tune results!!!! |
The Following 10 Users Say Thank You to fenton For This Useful Post: | ATL BRZ (07-05-2013), Calum (07-05-2013), CBR600RR (07-05-2013), cobrabyte (07-05-2013), DAEMANO (07-05-2013), Fish Eagle (07-05-2013), Gixxersixxerman (07-05-2013), nonicname (07-05-2013), slates74 (07-05-2013), SloS14 (07-05-2013) |
07-05-2013, 01:12 AM | #578 |
Drives: Viper, Mustang, FD RX7, FFR GTM
That's not a tune btw. Lol. That was quick and dirty couple hours type thing. This this thing presents some very unique airflow.... would like to spend more time on it. May not make more power, but there are a couple things that are making me scratch my head lol.
Glad it feels good. It was fun! |
07-05-2013, 01:15 AM | #579 |
Drives: GT86 DGM
Wow. You guys inverted the torque dip with a hairdryer! :-D
This is REALLY interesting! |
The Following User Says Thank You to atledreier For This Useful Post: | fenton (07-05-2013) |
07-05-2013, 01:21 AM | #580 |
07-05-2013, 02:18 AM | #582 |
Drives: Orange gt manual
Re Electrocharger
I have been following this for some time now and think its a great idea. @fenton what current draw is the Dc to Dc voltage convertor drawing.
Cause even when ur WOT ur system charges at full capacity. General rule of thumb is for every 10Amp u draw its 1Hp so if ur drawing 100 Amp at 12V its equivalent of 10HP. Be interested to see how much ur taking from the engine. The 130 Amp alternator is at 14.4v so its max charge capacity is "1872"Watts Also what type of batteries are you using? u will have to be careful that ur not charging them to quickly. Here is a system i would build if i had the money and time. Just putting it out there that there are other options as well i have found an alternator that charges at 191amp at 56V "thats to charge a 48 volt system" thats 10696Watts of power, If i was building a kit from scratch i would have that running so that it would switch on only for deceleration charging, while under breaks ( more like a regenerative hybrid) it draws almost 25hp Id use a Switched Reluctance motor driving the system, they have no brushes and are driven off pulsed width modulation. They have better torque, no magnets, cheaper to produce, and low inertia due to there simple design. Faster spooling time than brushless and more ability to control the rpm at great response to change. the batteries i would use are the one someone posted earlier on here http://www.shoraipower.com/Products/...18L1-BS12.html They are 18A/H and can be charged at 18AMPS safely probably twice that with shorting the life span and only weighs 2.31 lbs each That would give u charging rate of 36Amp at 56volt so the excessive sized alternator would be over kill If you were to draw 8000W 8Kw Motor at 48V it would take 166.6AMP to drive. those Batteries are capable of 270CCA 18A/H Divide by 166.6Amp = "0.109 of an hour before it ran flat" so 60Min X 0.109= 6.54Min Run time with no Charging. you could double the batteries for extra capacity and charge time without adding to much weight. Im extremely interested in this idea as u might tell. with the introduction of some supper capacitors for charging purposes the proposal i put forward would be some what feasible for short term track use. With other news headlines i have read lately like New battery scientists have designed a new Lithium ion battery that holds 2000X capacity and can charge 1000 times quicker. A battery that can Hold higher power density than a Super capacitor and last longer than anything ever know to the battery world. This is the technology this is the way of FI in the future. U seen it here first
1uz cressida with ems 8860 one day to be S/C (last rwd (car) toyota preduced in australia). And now a Gt 86 some day to be turbo
07-05-2013, 02:46 AM | #583 |
Drives: 2013 Subaru BRZ
Looking great! Did you log IAT at all? I wonder how hot it gets at these boost levels.
07-05-2013, 05:30 AM | #584 | |
That Guy
Drives: 2013 asphalt FRS MT
07-05-2013, 05:39 AM | #585 | |
Reverse Burnouts
Drives: 2013 Argento FRS
2000 Carbon Blue Toyota Celica GTS 152000 miles (wont forget you) 2013 Argento Scion FR-S 2011 Infiniti G37x |
07-05-2013, 06:37 AM | #586 | |
http://hothardware.com/News/Californ...In-20-Seconds/ http://edition.cnn.com/2013/05/20/tech/whiz-kid http://www.extremetech.com/computing...0-times-faster Changes are coming @Calum I have no idea i was just looking around batterys would be around the $500-600 no idea what a compressor would be worth couldn't be much, im thinking of getting a quote on a Switched Reluctance Motor, http://www.chargedevs.com/content/fe...uctance-motors The hardest thing is the controller I'm learning online about the electronics the SR motor is hard to program and even make it move is a mission but I'm almost considering making something up. I think a custom 8kw motor that is capable of 75000rpm should do it. Id estimate that with 8kw and a higher rpm with full adjustability of the motor being a SR Drive would be able to crack the 250hp mark. off the stats these guys have provided I should stop cluttering the thread lol
07-05-2013, 06:57 AM | #587 | |
http://www.teslamotors.com/roadster/technology/motor |
07-05-2013, 07:07 AM | #588 | |
It points to the stock intake manifold being a culprit to the torque dip.
2013 FRS Argento Silver 6MT
Mods: Clear fender side lights Tactrix ZA1JB01C 2014 Calib |
Similar Threads | ||||
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras | Circuit Motorsports | Member's Car Journals | 4 | 03-21-2013 04:45 PM |
Subaru BRZ : Full Throttle, powerslide, hard revving & ride | ESBjiujitsu | BRZ Photos, Videos, Wallpapers, Gallery Forum | 20 | 05-30-2012 06:43 PM |
86 Full Throttle Video + another. | Aus86 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 2 | 04-02-2012 07:07 AM |
