Old 05-21-2014, 09:59 PM   #575
TmP
TmP's Avatar
Drives: A bunch of 'em...
Balls.
I learned today that the kart track that's within an hour of my place does not allow cars on track.
FUCK
They only rent out their road course, but it's 400 bucks an hour!!! Um... pass.
Well, public roads it is...
TmP is offline   Reply With Quote
Old 05-22-2014, 07:50 PM   #576
gk
Drives: 2013 Raven FR-S
So I might be going wide body soon. I might hold off on new wheels for a bit and would just run some large spacers instead. So my question is, would running a 50mm spacer be ok to drift with? Or would it cause unnecessary wear and tear to the car being spaced that far out
gk is offline   Reply With Quote
Old 05-22-2014, 09:34 PM   #577
TmP
TmP's Avatar
The car doesn't know if the wheel is far out due to offset or a spacer...
Old 05-25-2014, 12:22 AM   #578
drift94
Drives: 2013 scion frs whiteout
IDK what size wheels to get. i want full functionality since my friends like to road race, but my build is strictly for daily drifter. only lowering as low as i can go without screwing up the suspension geometry. and want something that will look good on the car, so flush to semi flush. i know im going to want more angle down the road so clearance is an issue too
drift94 is offline   Reply With Quote
Old 05-25-2014, 12:33 AM   #579
TmP
TmP's Avatar
I know that boat...
Going back and forth between:
17x8 et35
18x9 et35
18x9 et25
16x9 et20
Dah.
On the bright side: Picked up my blower today
Old 05-25-2014, 12:37 AM   #580
drift94
i think im down to 17 or 18. i know 17 are lighter so they will serve the purpose on the road course. idk what the benefits are from running 18 inch wheels besides filling up the wells nicer
Old 05-25-2014, 12:39 AM   #581
TmP
TmP's Avatar
Benefits? None. Purely cosmetic on a car of this weight and power.
Old 05-25-2014, 12:42 AM   #582
drift94
so 17x8 +35 with 235/45 all around would work, with the stocks on the back at the drift events of course.
Old 05-25-2014, 12:46 AM   #583
TmP
TmP's Avatar
Based on my research - yes.
Not speaking from experience though.
Old 05-25-2014, 10:36 AM   #584
executivekoala
executivekoala's Avatar
Drives: fr-s
I finally too my cars to adams motorsports park here in Ca. I am having trouble with a corner that I have to initiate with the e brake. Because of the drum set up I dont feel like its getting enough bite. Anyone else have this issue? And I do need to tighten the cable but still am not getting enough force.
executivekoala is offline   Reply With Quote
Old 05-25-2014, 11:15 AM   #585
drift94
Pull it a couple times before your run
Sent from my SM-N900T using Tapatalk
Old 05-25-2014, 11:27 AM   #586
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
Check the status of the cables. Maybe need to be tighter.
One method I've used for certain circumstances combines three techniques.
Feint motion while kicking the clutch and then once you set your angle, pull the handbrake. It's a bit weird at first if you've never done it but if you use the weight of the car through the feint and kick the clutch at the right time, it works every time.
TylerLieberman is offline   Reply With Quote
Old 05-25-2014, 12:16 PM   #587
executivekoala
Drives: fr-s
Is there a way around clutch kicking? I don't feel my driveline is beefed up enough to handle it yet, its just the car is my daily and I don't wants to wear on the transmission since its a daily till I get a missile.
Old 05-25-2014, 01:19 PM   #588
TmP
TmP's Avatar
Yeah, the way around is called fi lol
Got reminded again today, that I am a racer first and a drifter second...
First track day. Damn, what a chassis.
But the brakes are a joke. Even for the stock power and tires...
Is there a thread for 'people doing stupid things in their brand new car' thread? Symbiont FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 36 02-18-2013 12:24 PM
BRZ Drifting. Hunter BRZ Photos, Videos, Wallpapers, Gallery Forum 7 09-20-2012 08:57 AM
So Cal drifting Thefear13 Scion FR-S / Toyota 86 GT86 General Forum 0 08-10-2012 04:53 PM
REAL drifting thread TylerLieberman Off-Topic Lounge [WARNING: NO POLITICS] 17 02-28-2012 04:20 PM
FT-86 II (RC) Drifting ft86cbx FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 8 11-11-2011 02:02 AM
