Old 12-31-2014, 12:16 AM   #5839
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
I've ordered a GFB alternator pulley, should arrive next Monday. Will update on result.
Would the Gates Blue belt help? Anybody know the correct part number for that?
Fizz is offline   Reply With Quote
Old 12-31-2014, 01:01 AM   #5840
TemeCal
Drives: 86
I'm using the Gates blue belt, so I'd say it doesn't help. Someone actually recommended that I switch back to the black belt, to see if that quiets it. You have the black belt on?
TemeCal is offline   Reply With Quote
Old 12-31-2014, 02:54 AM   #5841
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Yup mine's the black belt K061015.
Old 12-31-2014, 11:19 AM   #5842
Mechazawa
Drives: FR-S, 6MT, White
I don't have one of these on the car, but it just sounds like normal belt "squeal" to me. Usually resolved by increasing tension or changing to a different brand of belt.
I remember it was common on miatas with gates belts in general. The concensus was that American made belts used a very slightly different profile from the oem Japanese made belts. You might try figuring out who the oem supplier is and sourcing the correct length belt from them. Or as someone else suggested go with a slightly shorter belt to increase tension.
Mechazawa is offline   Reply With Quote
Old 12-31-2014, 02:41 PM   #5843
Ultramaroon
not playing cards
Ultramaroon's Avatar
Ok, I had a chance to sleep on it. If it fits, a slightly shorter belt will definitely get you higher tension. I can go into details if someone wants. Otherwise just have a look at this and consider how much more tension you can get pulling down on a taught clothesline versus a loose one. It's all in the geometry.
It won't be dramatic. This is by design but tension will increase.
Old 12-31-2014, 03:35 PM   #5844
whataboutbob
AutoX-10/10ths every run
I'm not getting any squealing out of my setup. I've got the upgraded idler pulley, 75mm pulley on blower, raceseng pulley set, and a fresh black belt FWIW.
Build thread:Here
Old 12-31-2014, 03:44 PM   #5845
TemeCal
Drives: 86
I'm running the smaller, 70mm pulley. I wonder if it's only squeaking on those of us with smaller pulleys (using the same size belt as you). @Fizz - what pulley are you running?
Old 12-31-2014, 03:54 PM   #5846
Ultramaroon
not playing cards
bingo
Old 12-31-2014, 03:57 PM   #5847
TemeCal
Drives: 86
bingo
Time to possibly try a smaller belt!
Old 12-31-2014, 04:00 PM   #5848
Ultramaroon
not playing cards
Happy New Year!
Old 12-31-2014, 04:03 PM   #5849
whataboutbob
@DriftEm is also running a 70mm...
Build thread:Here
Old 12-31-2014, 06:36 PM   #5850
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
I'm running 75mm pulley.
Old 12-31-2014, 06:55 PM   #5851
Ultramaroon
not playing cards
Do we already have a photo of your tensioner position here?
Old 12-31-2014, 07:25 PM   #5852
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
No but I'll post up a photo later. How do you want the shot to be? I can't really take a pulley level shot without removing the bumper though...
2 whp better than n/a e85, 2 whp? you're an idiot., 2screwsbetterthan0screw, 65 whp better than na e85, bspt fittings ftl, hate u all me no have sc, im just here for the tags, inorite!, it's no turbo but, only big numbers matter, screwyou, whine sexier than turbo, whines_more_than_your_gf, wts grey market butthurt.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 12:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 05:14 PM
