Old 12-29-2014, 10:18 PM   #5825
Ultramaroon
not playing cards
Ultramaroon's Avatar
Originally Posted by TemeCal View Post
Any idea why it would only happen the first minute, then go away?
It's charging your battery. You just used it to start your car.
Old 12-29-2014, 10:20 PM   #5826
Ultramaroon
not playing cards
I don't quite understand how it could be the culprit either. However, some have claimed that they have removed the belt and spun the alternator pulley and it was squeaking for them.
I'm a bit frustrated with the squeak (just really annoyed by it). I'd LOVE to get to the bottom of it and fix it once and for all. It's obviously a very common issue, as many of us with the Innovate kit seem to have it.
Oh, I just read this. No. That doesn't make sense.
edit: I mean I agree it's not likely to be the alternator.
Old 12-29-2014, 10:22 PM   #5827
Ultramaroon
not playing cards
If not the alternator, then rotate all the idler wheels by hand (belt removed - duh).
If there is anything but smooth, dead silence, the bearing on that wheel is blown.
QFT- I have been lurking on this blower but don't have one. Not an expert with it specifically. Is the gearbox any stiffer when it's cold?
Old 12-29-2014, 10:26 PM   #5828
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Yea it doesn't make sense. If they get squeaking from spinning the alternator pulley, then surely it's something else faulty inside the alternator......not the pulley itself since that part doesn't have any bearings and doesn't spin freely on its own.
Fizz is offline   Reply With Quote
Old 12-30-2014, 02:17 PM   #5829
xxscaxx
Drives: 2013 SWP BRZ
I am the one that said I had a squeak coming from he alternator. I didnt say particulary say it was the pulley, just it was coming from the actual alternator.
I wonder if it has anything to do with running the gates blue belt.
xxscaxx is offline   Reply With Quote
Old 12-30-2014, 05:33 PM   #5830
blown
Drives: ft86
i had a squeek with the gates blue belt as well.. loud screech only at start up.. never tried the other belt though..
blown is offline   Reply With Quote
Old 12-30-2014, 07:10 PM   #5831
Ultramaroon
not playing cards
I'd be willing to bet the belt material is too stiff and doesn't hook up enough. That squeak is just the moment after using the starter when the alternator dumps all it can back into the battery.
Old 12-30-2014, 07:30 PM   #5832
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
I think a video of the squeak would help. These blowers make a squeaking type of noise just by themselves. If you're new to twin screw blowers it is easy to mistake it for an issue when there isn't one.
Blue or standard belt won't matter since the tensioner sets the tension.
Xero-Limit is offline   Reply With Quote
Old 12-30-2014, 07:43 PM   #5833
Ultramaroon
not playing cards
Disagree in principle. That's just like saying different tire compounds don't matter since the car weighs the same.
Old 12-30-2014, 07:58 PM   #5834
Xero-Limit
Xero-Limit's Avatar
The belts aren't supposed to slip like tires do, so it shouldn't matter
Old 12-30-2014, 08:24 PM   #5835
Ultramaroon
not playing cards
5 minutes of google reveals the Gates Blue is a stiffer belt designed for higher loads. It matters.
Old 12-30-2014, 08:53 PM   #5836
TemeCal
Drives: 86
It's definitely not the blower. I've had a few supercharged vehicles before, and they never squeaked like this. It's a very noticeable squeak that goes away quickly, once I start driving. It's coming from the belt or a pulley.
I'll try to get a video of it, when I get home on Sunday.
TemeCal is offline   Reply With Quote
Old 12-30-2014, 09:13 PM   #5837
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
I'm also quite certain it's not the blower that is squeaking. It sounds like it's coming from one of the pulleys....bit I just can't pinpoint which one is faulty.
By the way I'm using the Gates K061015 belt.
Old 12-30-2014, 09:47 PM   #5838
Ultramaroon
not playing cards
How much preload is there on the tensioner? If it's slack, will the next shorter step fit? K061010 is about a half inch shorter
edit: I may be incorrect about the tensioner position if it is of a constant torque type. The shorter belt may not help/matter.
2 whp better than n/a e85, 2 whp? you're an idiot., 2screwsbetterthan0screw, 65 whp better than na e85, bspt fittings ftl, hate u all me no have sc, im just here for the tags, inorite!, it's no turbo but, only big numbers matter, screwyou, whine sexier than turbo, whines_more_than_your_gf, wts grey market butthurt.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 12:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 05:14 PM
