Old 12-19-2014, 09:45 AM   #5769
Calum
That Guy
Drives: 2013 asphalt FRS MT
Originally Posted by CK_Bladesmith View Post
Just to be on the safe side. The pcv valve on our cars is pretty weak. I got a brand new one from toyota and I can blow air back through it. It's just an extra precaution to keep the crankcase from potentially being pressurized.
I wonder if the valve on the FA20DIT would be any better.
Old 12-19-2014, 10:31 AM   #5770
blown
Drives: ft86
they do have a different part number
fa20dit
11810AA140
vs
fa20
11810AA130
blown is offline   Reply With Quote
Old 12-19-2014, 10:41 AM   #5771
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
I bought a couple of these: http://www.usplastic.com/catalog/item.aspx?sku=64175
Fizz is offline   Reply With Quote
Old 12-19-2014, 11:02 AM   #5772
blown
Drives: ft86
Originally Posted by Fizz View Post
shipping sucks
Old 12-19-2014, 11:05 AM   #5773
CK_Bladesmith
CK_Bladesmith's Avatar
Drives: Raven FR-S
Those are the exact ones I've got as well.
Raven FR-S mods: Unichip, Ground Control street coilovers with camber plates and strut tower brace, SPC Lca's, Drag DR-38 wheels with Dunlop Direzza DZ101s, Perrin CAI and silicone inlet tube, Perrin 3" resonated catback, Perrin high flow catted front pipe, Rev Works UEL header.
CK_Bladesmith is offline   Reply With Quote
Old 12-19-2014, 08:24 PM   #5774
stockysnail
Just the tip
stockysnail's Avatar
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
Originally Posted by whataboutbob View Post
I was getting squeaking from the idler pulley. It never failed completely, but when I took it off it had a lot of slop in the bearing. I'd suggest you pick up one of the pulleys that I linked to above, I've had it on my car for some time now and it isn't squeaking. Seems like a good fix.
Upon your recommendation I picked up the idler pulley NuLine EP075. I could only find it in Australia unfortunately as O'Reiley doesn't carry it anymore. Shipping was more than the part. At least it was still only $33. Hopefully this fixes the squeak that started a couple months ago as it's starting to get annoying. Hopefully this is the part that's making the noise.
stockysnail is offline   Reply With Quote
Old 12-19-2014, 08:35 PM   #5775
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Let us know how it went, whether it cured the squeak. In fact I think I might just replace it at the same time when swapping to the 72.5mm pulley.
Old 12-19-2014, 10:36 PM   #5776
dhsean
Drives: 2013 White FRS
I was unable to find as well. We replaced with a new OEM pulley for now but had to change the belt as well. If you still get a chirp try replacing the belt. I had about 15000 miles since the kit was installed. Everything is good now. Also check to see if you intercooler fluid is still circulating. Noticed it stopped recently - the fuse popped.
dhsean is offline   Reply With Quote
Old 12-20-2014, 06:48 AM   #5777
Hempo
Drives: Subaru BRZ
I've tried searching but couldnt find anything.. what's the highest revlimiter you guys run? I'm going up 1mm on the valves with stiffer springs etc.. and getting some headwork done.. Planning on maybe raising the revlimiter to 8500-8650 or maybe even higher.. IF it shows any gain
Hempo is offline   Reply With Quote
Old 12-20-2014, 09:35 AM   #5778
8686
8686's Avatar
Drives: 86
I am looking for high tensile bolts for the SC but couldnt find it online. I will be installing the intercooler soon and thought it will better to have them changed at the same time.
If any one can guide me where to get these M6 20 mm
VOLK LE37 17X7.5, SWIFT Springs, Bilstein B8, HKS intake duct, Cosworth Air Filter, HKS headers, PLM Over Pipe, EVS Down Pipe & Exhaust, FD 4.55, GFB pulleys, Axle-Exchange Drive Shaft, Mishimoto oil cooler, Cusco F&R strut bar, TRD door stabilizer, Innovate SC, Delicious Tuned
8686 is offline   Reply With Quote
Old 12-20-2014, 09:51 AM   #5779
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
I found high grade bolts at my local hardware store. They shouldn't be hard to find.
Old 12-20-2014, 09:55 AM   #5780
8686
8686's Avatar
Drives: 86
I am living in the middle east. So i am not sure that I can find it in a local store.
Old 12-20-2014, 10:39 AM   #5781
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Random question. Which direction does the coolant flow through the blower? Front to back or other way round?
Old 12-20-2014, 01:04 PM   #5782
blown
Drives: ft86
not 100% sure but I think it goes from back to front..
anyone else thinking about using a larger reservoir?
2 whp better than n/a e85, 2 whp? you're an idiot., 2screwsbetterthan0screw, 65 whp better than na e85, bspt fittings ftl, hate u all me no have sc, im just here for the tags, inorite!, it's no turbo but, only big numbers matter, screwyou, whine sexier than turbo, whines_more_than_your_gf, wts grey market butthurt.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 12:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 05:14 PM
