Old 06-23-2017, 07:16 PM   #561
steve99
Originally Posted by thornad View Post
I flashed the "Stg2 UEL 98 v111.2.AU.Rich A01G.bin"
I am MT. Do I need any other changes? Is the tune ok for MT as it is?
Thank you
The tune should be fine give it say 100km to settle in then log for knock and do a wot run to max rpm to check fueling you just might need to tweak the open loop end of maf scale to suit if the high end fueling is rich or lean
Old 06-23-2017, 07:21 PM   #562
steve99
Originally Posted by Minsekt View Post
just did my 60k service and my dealership still didnt update from 700I, dont have any knock though. am i correct if i use the non-hacked cal id Stg1 A01I rom from OP and the latest github A01I definitions i can update the ecu to A01I with tactrix?
Yes with tactrix you can flash whatever rom you want even incorrect ones.
If your original rom was 700I then you safe to flash the tuned A01I rom from first post to your car.
As kode said the oft guys tunes are calid hacked but its best to avoid the caliid hacked roms with tactrix as you dont need to fool an oft.
With tactrix just use A01I roms and definitions for your car.
A01I is the correct factory update
Note ecuflash\tactrix defs are different to romraider defs, romraider is edit only , ecuflash\tactrix is flash and edit always correct the checksum if it asks
Old 06-24-2017, 04:36 AM   #563
Minsekt
Minsekt's Avatar
Drives: GT86
thank you, everything went flawlessy.
Minsekt is offline   Reply With Quote
Help uploading 2.06 tunes to OFT Jimmy817 Software Tuning 3 12-28-2014 09:06 PM
Custom Az Tunes Juggles Arizona 13 11-08-2014 10:15 AM
EcuTek Tunes Rio Engine, Exhaust, Transmission 1 04-29-2014 12:10 AM
How long until *other tunes? ScionFrsFan Engine, Exhaust, Transmission 61 12-07-2012 05:34 PM
Speedhunters - TRD TUNES THE 86 quik1987 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 69 05-22-2012 04:26 PM
