#561 |
Could have gone bad here as well if I had the wrong cop. I think I took him by surprise when I rolled down my window and he saw me though so that probably helped.
| The Following User Says Thank You to Tcoat For This Useful Post: | jawn (11-16-2015) |
#562 |
I'd buy a lottery ticket if I were you. Ride that good luck streak hard.
#563 |
not playing cards
Sorry, T. More plagiarism.
#564 |
/dev/null
Drives: Uphill
A British colleague of mine was in the middle of telling a joke when the CEO pops out from behind the corner.
The brit continues like this "...so we scrambled the database and twirled the JavaScript lengthwise, just like you said, and after the XML had recompiled into solid state the CSS was all chartreuse. The client is happy and we're already moving on to the next pipeline." The CEO nods solemnly at this and says "Keep up the good work, boys". |
| The Following 2 Users Say Thank You to Sarlacc For This Useful Post: | Tcoat (11-17-2015), Ultramaroon (11-17-2015) |
#565 | |
Definition, “race” and “contest” 2. (1) For the purposes of section 172 of the Act, “race” and “contest” include any activity where one or more persons engage in any of the following driving behaviours: 3. Driving a motor vehicle without due care and attention, without reasonable consideration for other persons using the highway or in a manner that may endanger any person by, i. driving a motor vehicle at a rate of speed that is a marked departure from the lawful rate of speed, ii. outdistancing or attempting to outdistance one or more other motor vehicles while driving at a rate of speed that is a marked departure from the lawful rate of speed, or iii. repeatedly changing lanes in close proximity to other vehicles so as to advance through the ordinary flow of traffic while driving at a rate of speed that is a marked departure from the lawful rate of speed. O. Reg. 455/07, s. 2 (1). (2) In this section, “marked departure from the lawful rate of speed” means a rate of speed that may limit the ability of a driver of a motor vehicle to prudently adjust to changing circumstances on the highway. O. Reg. 455/07, s. 2 (2). Definition, “stunt” 3. For the purposes of section 172 of the Act, “stunt” includes any activity where one or more persons engage in any of the following driving behaviours: 1. Driving a motor vehicle in a manner that indicates an intention to lift some or all of its tires from the surface of the highway, including driving a motorcycle with only one wheel in contact with the ground, but not including the use of lift axles on commercial motor vehicles. 2. Driving a motor vehicle in a manner that indicates an intention to cause some or all of its tires to lose traction with the surface of the highway while turning. 3. Driving a motor vehicle in a manner that indicates an intention to spin it or cause it to circle, without maintaining control over it. 4. Driving two or more motor vehicles side by side or in proximity to each other, where one of the motor vehicles occupies a lane of traffic or other portion of the highway intended for use by oncoming traffic for a period of time that is longer than is reasonably required to pass another motor vehicle. 5. Driving a motor vehicle with a person in the trunk of the motor vehicle. 6. Driving a motor vehicle while the driver is not sitting in the driver’s seat. 7. Driving a motor vehicle at a rate of speed that is 50 kilometres per hour or more over the speed limit. 8. Driving a motor vehicle without due care and attention, without reasonable consideration for other persons using the highway or in a manner that may endanger any person by, i. driving a motor vehicle in a manner that indicates an intention to prevent another vehicle from passing, ii. stopping or slowing down a motor vehicle in a manner that indicates the driver’s sole intention in stopping or slowing down is to interfere with the movement of another vehicle by cutting off its passage on the highway or to cause another vehicle to stop or slow down in circumstances where the other vehicle would not ordinarily do so, iii. driving a motor vehicle in a manner that indicates an intention to drive, without justification, as close as possible to another vehicle, pedestrian or fixed object on or near the highway, or iv. making a left turn where, (A) the driver is stopped at an intersection controlled by a traffic control signal system in response to a circular red indication; (B) at least one vehicle facing the opposite direction is similarly stopped in response to a circular red indication; and (C) the driver executes the left turn immediately before or after the system shows only a circular green indication in both directions and in a manner that indicates an intention to complete or attempt to complete the left turn before the vehicle facing the opposite direction is able to proceed straight through the intersection in response to the circular green indication facing that vehicle. O. Reg. 455/07, s. 3.
#567 | |
Feeling like thinking....
The following, IMHO, is the absolute pinnacle of proprietary ampicilliary obfuscation. Enjoy.. Barry |
| The Following 2 Users Say Thank You to MuseChaser For This Useful Post: | ScoobsMcGee (11-17-2015), Ultramaroon (11-17-2015) |
#568 |
/dev/null
Drives: Uphill
#569 |
Junior Senior with Cheese
#570 | |
/dev/null
Drives: Uphill
#571 | |
I like the wording where they say "intention" to do something. So even if you didn't do it if they think you were planning it they can still grab you. Be pretty hard to prove what you "intended" to do but still a pain.
#572 | |
Drives: 2015 CWP BRZ Limited
#573 |
#574 | |
/dev/null
Drives: Uphill
If the wrong cop in the wrong mood sees you at the wrong moment, your license is suspended for the 6 months it takes to save enough money to pay the fine. I have this whole speech prepared for the day I have to go to court for practising figure-8's in an empty, icy parking lot. It will probably cost me a month or two extra, but it'll be worth it. It starts with "Many traffic accidents could have been avoided if drivers were not so surprised over how their vehicles react when they suddenly have to brake hard or turn the steering wheel fast." The rest is obvious. Last edited by Sarlacc; 11-17-2015 at 04:03 PM. |
| Tags |
| escalation, foie queue, noob, poutine galore, return of squadrogue, spam and dumbfuckery, squadrogue fan club, the squadrogue trilogy, troll fest |
| How about we make a track tire data thread? | ddeflyer | Tracking / Autocross / HPDE / Drifting | 0 | 06-09-2014 01:25 PM |
| Is there a thread for 'people doing stupid things in their brand new car' thread? | Symbiont | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 36 | 02-18-2013 12:24 PM |
| The "if you wanna kiss the backside of white musicians make a thread about it" Thread | aliphian | Off-Topic Lounge [WARNING: NO POLITICS] | 8 | 12-19-2011 07:59 PM |
