#561 |
Drives: 2015 WRB BRZ Premium
Unless I'm extremely confused, your solution uses both GM and subaru ECUs correct?
Or are you removing the subaru ECU?
2015 WRB BRZ - Nameless - Raceseng - Eibach - Whiteline - Cusco - Perrin
#562 | |
Drives: 2001 Impreza 2.5 RS
Colin Beck
| The Following 2 Users Say Thank You to MRS-Colin For This Useful Post: | Nickosport (08-23-2016), SleepingPanda (08-23-2016) |
#563 |
I want one so hurry up!
#564 |
Drives: 85 corolla gts
In order to keep the factory ecu in place you would have to send it specific signals to make it do its job. It would be much easier to just put the info onto the can bus via one of there products and have the gm ecu send data to it.
#565 |
Drives: United States
Really hoping you guys get everything worked out by the time I'm ready for and ls swap. if you need a car guinea pig vehicle let me know, My BRZ isn't my daily, i can afford to part with it for a while
#566 | |
Colin Beck
#567 |
I still feel leaving a factory ecu in place (fa20), when you are able to output what you want through your own box (one of the mrs electronics products) is a waist of time. As well its (the fa20 ecu) broadcast output is limited with zero engine speed. Why work around that when you can ditch the factory ecu and just use a gm. The gm can output the majority of the info the system (factory can bus) is looking for, just have your own box recode it for the chassis to be happy. I will just stick with an ems system for total control.
#568 | |
It's not working around, its working with. Eventually if I learn the entirety of the network traffic from the ECU and what it means. People know this, I don't. I just haven't spent the time to RE the whole message structure from the ECU, I just know what I need to know for the rest of the car to not complain. This would bring the packaging of the solution down to a module the size of a larger automotive relay...
Colin Beck
#569 |
Cause when the ecu does not see the engine running the info that is output is minimal. For the amount of supplemental data it is only a little more to just replace the ecu. Good luck with your project.
#570 | |
Drives: 2016 BRZ Hyper.Blue
If it's a race car? Absolutely. Who cares. Replace the ecu. But keeping the stock ecu functioning somewhat. Is essential for the obd readiness test. |
#571 | ||
EDIT: Also, for immobilizer push button start cars it could be an issue to remove the OE ECU. Quote:
Unless you know someone who wants to disassemble every possible OS and reprogram the GM PCM to spit out the appropriate messages and data, this is the way.
Colin Beck
| The Following 3 Users Say Thank You to MRS-Colin For This Useful Post: |
#572 | |
Drives: FRS Silver LS1 swapped.
.......once again I'm the guniea pig working with MRS Electronics and have been pushing Collin to share on this forum, dont think he likes too, but I know some of you are on the cusp of doing the swap and need the info......Can-bus and related is what this man and this company do for a living and in most cases on a much larger and complex scale, just check out their web site.....if anybody can figure this crap out they can.......we are in good hands for a simple cost effective solution, its just going to take a little research and ground work, a product I'm sure will be available soon.
#573 |
Drives: 2015 frs
@MRS-Colin can I just run the OEM GM ECU and your product for my swap or do I have to keep the FR-S ECU as well. I need to know so I know if I can sell the FR-S ECU. If you need a ECU from a FR-S to work with to help you develop your product further let me know where to ship it. The car is down and will be until March.
#574 | |
Colin Beck
| The Following User Says Thank You to MRS-Colin For This Useful Post: | Zer0 (08-24-2016) |
| FS: KW V3 Coilovers w/ Vorshlag Front Camber Plates | Steeze_Its | Brakes, Suspension, Chassis | 7 | 06-27-2014 10:32 PM |
| FS: Vorshlag Front Camber Plates | h4nh | Brakes, Suspension, Chassis | 1 | 03-01-2014 11:49 PM |
| FS: KW V3 w/ Vorshlag camber plates & oem stock suspension (SF bay area) | serial gixxer | Brakes, Suspension, Chassis | 18 | 05-20-2013 09:51 PM |
| WTB: Front Vorshlag Camber Plates | YDNA | Brakes, Suspension, Chassis | 0 | 05-03-2013 06:31 PM |
| Maybe a repost, but have you seen the Vorshlag project car? | Bart1 | BRZ First-Gen (2012+) — General Topics | 3 | 01-07-2013 02:19 PM |
