Old 03-29-2014, 04:47 PM   #561
AdrianG
Generally Well Liked
Drives: '08 STi Hatch, '11 Outback 3.6R
Nice! I hadn't seen it if you had. Are these 8 bit too?
- AdrianG
AdrianG is offline   Reply With Quote
Old 03-29-2014, 04:51 PM   #562
Td-d
Garden variety obsessive
Drives: 2009 Sti Hatch; 2015 Audi RSQ3
Nope - float values, x-50
Td-d is offline   Reply With Quote
Old 03-29-2014, 05:15 PM   #563
AdrianG
Would you mind helping me out with putting this to use? Please?
Old 03-29-2014, 05:40 PM   #564
Td-d
Sure
Code:
paramname = Intake_VVT_Advance_Angle_Right(degrees)
paramid = 0xFF8C0E8
isfloat = 1
scalingrpn = x,50,-
paramname = Intake_VVT_Advance_Angle_Left(degrees)
paramid = 0xFF8C0EC
isfloat = 1
scalingrpn = x,50,-
paramname = Exhaust_VVT_Advance_Angle_Right(degrees)
paramid = 0xFF8C130
isfloat = 1
scalingrpn = x,50,-
paramname = Exhaust_VVT_Advance_Angle_Left(degrees)
paramid = 0xFF8C134
isfloat = 1
scalingrpn = x,50,-
Try that out, otherwise, it might just be the float value without the conversion.
Old 03-29-2014, 07:21 PM   #565
AdrianG
If shipping to South Africa didn't cost as much as a turbo kit, I'd buy you a case of beer. Let me know if you're ever in continent
In case anyone cares, my logcfg.txt on dropbox has been updated with the AVCS parameters, but I haven't been able to test them personally yet.
Old 03-29-2014, 07:33 PM   #566
steve99
Hey Td-d Thanks for fixing the 32BITBASE base timing scaling problem works fine.
Thanks
Old 03-29-2014, 07:37 PM   #567
steve99
Does anyone know if these RAM addresses for Tactrix/ecuflash logging various ROM's are posted anywhere, so we don't have to annoy guys like Td-d.
I got a few off @ztan for G rom which was great. Have you managed to find gefogger for "G" ROM ?? thanks
Maybe a branch on Github would be useful ??
Old 03-29-2014, 07:52 PM   #568
AdrianG
There's a list or two from Td-d in this thread actually. I started a separate thread just for logging parameters thinking it would help but it didn't get much traction, the conversation stayed in this thread.
The Following User Says Thank You to AdrianG For This Useful Post:
steve99 (03-29-2014)
Old 03-30-2014, 04:15 AM   #569
Td-d
Doesn't bother me, really. The Github branch is a good idea - just thinking how to do it.
Bit of a chicken and egg situation - the easiest way of generating the logcfg files is using logcfg.exe with the Romraider logger.xml file - which currently has no BRZ parameters, since logging for the BRZ in Romraider (using OBD) is still being developed by DSchultz. That being said, doesn't prevent me from creating an Alpha branch of the logger xml that can be substituted - I'll just need to create a whole set of new parameter definitions, since you don't have P parameters anymore (e.g. before, AVCS would be logged using a P parameter, not direct logging - will now need to create a new AVCS set of direct parameters).
Once I have that set up, it's very quick to generate the logger xml files for all the roms - I define the ram locations as I go along in any case.
The Following User Says Thank You to Td-d For This Useful Post:
steve99 (03-30-2014)
Old 03-30-2014, 04:39 AM   #570
Td-d
RAM:FFF89393 Ram_Defogger_Switch
ZA1JA01G
Old 03-30-2014, 11:51 AM   #571
steve99
ZA1JA01G
Just tried it works fine can see defogger toggle 0 to 1 in log.
Only drama is trigger does not seem to work runs as soon as ignition on and toggling defogger does not start stop log.
@AdrianG did your trigger work ??
; Defogger switch for logging start/stop
paramname = Defogger
paramid = 0xFFF89393
databits = 8
conditionrpn = Defogger,1,==
action = start
conditionrpn = Defogger,0,==
action = stop
Old 03-30-2014, 12:00 PM   #572
AdrianG
I haven't been able to test yet, but I will update when I do.
- AdrianG
Old 03-30-2014, 12:42 PM   #573
Td-d
Maybe put the defogger parameter up higher in the list, not sure why it's not being used as the trigger...
Old 03-30-2014, 01:08 PM   #574
steve99
Just tried that same problem unfortunately, might see how @AdrianG goes
I'll go back to my RPM trigger for now, might try commenting out some parameters in case theirs a limit or something.
Thanks
Close iJason Member's Car Journals 1 08-04-2013 08:26 PM
Close pche Engine, Exhaust, Bolt-Ons 3 08-04-2013 02:04 AM
Sorry. please close. finch1750 Scion FR-S / Toyota 86 GT86 General Forum 1 07-31-2013 01:00 AM
please close abutterman Wheels and Tires 0 07-05-2013 09:40 AM
