#561 | |
Platinum Member
Drives: Toyota 86 Vortech SC
Phew, thanks for your kind words.
I thought Sunday was anything but smooth. I tried with nannies off, in sport mode, with nannies fully on, I tried aggressive, I tried gentle and smooth and all of that amounted to was a negligable 0.1 sec diff ![]() I've actually got video of powersliding T5 (the 180° hairpin) with the nannies fully on. I had so little grip that even with the power stifled by the nannies, there was still enough to powerslide - LOL. What did work well was using higher gears to reduce power and torque, and make throttle inputs less sensitive - like using 3rd thru the chicane and the central section. Quote:
I'm going to experiment with a variety of road-legal semis, and R888 is one that's on my list. My sponsor has also located a set of Yoko AD08's in 235/40R17 which I'm going to test too.
#562 |
Official anti-BS squad
Drives: Toyota 86 High 6MT
Coilovers doesn't necessarily mean harder, that would be a function of the spring rates(which you can specify, with valving to suit). It would give you much more adjustability in terms of camber, ride height and damping.
Else simply get camber plates.
Toyota 86 High 6MT (Satin Pearl White)
95RON SAV Tuned |
| The Following User Says Thank You to sav For This Useful Post: | Fish Eagle (05-05-2016) |
#563 |
Platinum Member
Thanks.
What do camber plates cost nowdays?
#564 |
95RON SAV Tuned |
#565 |
or if your still on stock struts you can get about -1.5 with these
http://m.ebay.com.au/itm/SALE-WHITEL...638?nav=SEARCH |
#566 | |
Platinum Member
I need to go to -2.5°
#567 | |
I've bought them because Toyota didn't have stock at the time.
95RON SAV Tuned |
#568 |
Platinum Member
Well, after 3+ years, 75000 kms, and 30 track days, I've had my second failure - clutch thrust bearing seized. (First failure was a cracked header, which I had welded up 6 mths ago, and it's still OK)
I have no idea why the thrust bearing failed, but I'd resigned myself to probably also replacing clutch plate and pressure plate while it was out. The good news is that my clutch plate and pressure plate look great, and they're going back as is. Recently someone said that you have to upgrade clutch if you go FI - this is proof that you don't. I believe that the real clutch killers are drag racing and gymkhanas - which I don't do.
#569 |
Platinum Member
Regarding buying parts...
The thrust bearing is the second example I've had where I've compared prices between Toyota and Subaru, and again Subaru came out tops, by far. Imperial Toyoya Nelspruit quoted Toyota list price. NTT Toyota Barberton (my dealer) quoted Toyota list -20% Subaru Nelspruit came out at 17.5% less than NTT Bton We're lucky to have the choice of supply channel, and the price differences are substantial, so always get a quote from both.
#570 |
Cool, yeah mine also recently failed. bearing and clutch replaced under warranty. Plate was also still looking good but they said they've replaced it anyway while the box was out because the springs were a little bit rattly.
95RON SAV Tuned |
| The Following User Says Thank You to sav For This Useful Post: | Fish Eagle (05-21-2016) |
#571 |
Drives: Toyota 86 - Charcoal Grey
@Fish Eagle what were the symptoms of the failure? Was it gradual or sudden?
#572 | |
Platinum Member
I don't think that FI or racing contributed to failure. Normally thrust bearing failure come from lightly resting one's foot on the clutch a lot, which I don't. So I dunno, but I'm not hassled either way.
#573 |
Drives: Lawn moweR
Thank you for the detail and pics @Fish Eagle,
I have been noticing loud clutch noises for 2 months now, Took it to Toyota and they greased a few parts (I think one of them was a spring). Toyota didn't know what else to do, the noise came back in 2 days of driving. I hope it does not lead to any failures, I read up on this thread, but there does not seem to be any solution, other than getting your clutch replaced (Or in your case, the part replaced). http://www.ft86club.com/forums/showthread.php?t=56882 |
#574 |
Platinum Member
The sound in those videos says linkage to me. It's not relative to rotation of the clutch, so I'd rule out clutch plate, pressure plate and thrust bearing.
Very different to the noises mine made. If I had that noise, I'd lube everything to do with the pedal and linkages with Q20 or Tool-in-a-Can, but that's guesswork.
| Anyone know a good detailer in south florida? | Red FRS | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 2 | 08-27-2013 08:12 AM |
| Good service advisor in LA area (South Bay)? | 96z2 | Southern California | 0 | 08-30-2012 12:58 AM |
| FRS / BRZ in Seatle to show to South African Enthusiast? | RudiG | Northwest | 9 | 06-22-2012 04:59 AM |
| Looking for a good Dealership in the South Bay! | MrWyatt | Southern California | 2 | 05-08-2012 07:25 AM |
