Old 12-05-2013, 07:36 PM   #561
mike the snake
Car was dynoed today, 100% stock for a baseline. Mustang dyno, and it was cold and dry out.
I was surprised by the numbers we got, on the high side for bone stock (159 and 131)
Old 12-05-2013, 07:40 PM   #562
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
pretty high for a 91+mustang dyno
Old 12-05-2013, 07:48 PM   #563
mike the snake
Agreed. I was expecting much lower numbers.
It was pretty cold and dry out though.
Old 12-06-2013, 08:25 AM   #564
FullBlown
FullBlown's Avatar
Drives: Scion FRS
I'm excited to see how this turns out with the meth.
FullBlown is offline   Reply With Quote
Old 12-06-2013, 10:43 AM   #565
Dustin@Dynosty
Originally Posted by SmsAlSuwaidi View Post
I think dynosty discarded their haltech project but could still do it for you
Sent from my IBrick
Depending on the final dollar figures on the Motec, we may switch from the current Haltech parallel setup, but we do not have any issues with how things are running currently. We have spent countless hours doing R/D on the shop car before we started offering it to the public. The DI responds fine after we took control of the PI with the Haltech, just have to spend the time with both EcuTek and Haltech to get them to cooperate, but after that we are confident in the pair. We just recently tuned this car in Antigua with our Haltech setup.
http://www.ft86club.com/forums/showthread.php?t=52882
Dustin@Dynosty is offline   Reply With Quote
Old 12-06-2013, 11:04 AM   #566
SmsAlSuwaidi
Boosted
That is very nice and interesting, but it does seem like a costly way to setup things and a bit of hassle; nevertheless good job guys
Sent from my IBrick
Old 12-06-2013, 05:59 PM   #567
Dustin@Dynosty
^ unless Motec changes their prices from what we were quoted, expect:
M150 ECU – $3770.00
FR-S/BRZ/FT86 M150 Package - $800.00
Wire Harness Adapter - $900.00
Options:
Logging Level 2 - $375.00 (features 200 channels at 200 Hz and 1 set of log set parameters can be setup)
Logging Level 3 - $585.00 (req. Level 2 logging, features 1000 channels at 1000 Hz and 8 sets of log set parameters can be setup)
Pro Analysis - $1040.00 (Recommended Logging 2 or 3 purchased, allows access to i2 Pro)
Which if those numbers hold true, I expect sales to be extremely low on this unit; making our Haltech solution less than half the cost, and apart from being a parallel system, would have most of the features of the Motec. Again, we too are contemplating the Motec solution, but I think for it to be marketable, the unit needs to be around $3500 out the door.
Old 12-07-2013, 09:02 PM   #568
toekneehair
toekneehair's Avatar
Drives: 2013 Subaru BRZ/FBM turbo flexfuel
I had a few quick questions for other Full blown kit owners.
When you received your kit what was your Wastegate springs set at?
I followed the steps for the tubing having the top hole vented to the atmosphere and one of the side connections hooked up to to a vacuum line. I just wanted to know if the blowoff valve needs any lines run to it? I didn't see anything listed in the instructions.
toekneehair is offline   Reply With Quote
Old 12-07-2013, 09:28 PM   #569
Deadspool
Much title. Wow.
Deadspool's Avatar
Drives: 2013 BRZ Sport-Tech
Use the supplied vacuum T and run a line to the BOV shared off the line to the wastegate
Deadspool is offline   Reply With Quote
Old 12-07-2013, 09:38 PM   #570
Dipstik-sportech
Dipstik-sportech's Avatar
Mine had the 7ish psi spring in the wastegate and a 12psi brown spring in the bov
Old 12-07-2013, 09:38 PM   #571
toekneehair
I was thinking it was something like that. so the vacuum line will run from the engine then T off to the top of the blow off valve and the side of the wastegate with the top connection for the wastegate just open to the atmosphere?
Old 12-07-2013, 09:39 PM   #572
Deadspool
Much title. Wow.
Deadspool's Avatar
Correct. And my wastegate was 5psi. my BOV was also a 12psi spring.
Old 12-07-2013, 09:44 PM   #573
toekneehair
I didn't even think to open the BOV yet. inexperience right there for me. so should the springs be set to the same amount of psi? and so your wastegate came delivered at the 5.6 psi? I ask because mine was set at 15psi. I and the prior owner of the kit think the mechanic who did the install either neglected to change the spring or installed the wrong one.
Old 12-07-2013, 10:05 PM   #574
Dipstik-sportech
I think unless you specifically tell LJ to put a higher psi spring in the wastegate it comes with the lowest one in it as a default.
best company ever, big fuck off turbo, blown, bow chicka wow wow, fbm, full, owners, powaaaaaa!, thread, will work for turbo
AVO Turbo Kit Owners Topic Sportsguy83 Forced Induction 1935 02-20-2023 10:46 AM
Full Blown FRS/BRZ Stage 1 Turbo Kit FullBlown Forced Induction 456 09-27-2021 03:10 AM
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 12:36 PM
Full Blown Turbo Kit! Unleashed Engine, Exhaust, Bolt-Ons 70 10-09-2013 09:46 AM
WTB: Full Blown turbo kit (used) whitefrs Engine, Exhaust, Bolt-Ons 12 03-29-2013 09:15 PM
