Old 04-06-2014, 10:11 PM   #561
MPI_Jack
Drives: '13 FRS, '02 BMW 530i(550HP, turbo)
18x9.5 Enkei NT03+M 245/40/18 Federal Formoza(can't wait till they wear out)
MPI_Jack is offline   Reply With Quote
Old 04-07-2014, 10:52 PM   #562
Joe-G
Canada Eh!
Joe-G's Avatar
Drives: '13 FRS
18x9.5 +48 Wedssport SA-15R 255/35/18 all around
Joe-G is offline   Reply With Quote
Old 04-08-2014, 02:34 AM   #563
Amir Ghadiri
Amir Ghadiri's Avatar
Enkei RPF1 18x9.5 +38 Square
265/35-18 Falken RT615K
KW V3 Coilovers
Size:  169.1 KBName:  ImageUploadedByTapatalk1396938681.752421.jpg
Size:  244.0 KBName:  ImageUploadedByTapatalk1396938708.140341.jpg
Size:  238.9 KBName:  ImageUploadedByTapatalk1396938797.929040.jpg
Amir Ghadiri is offline   Reply With Quote
Old 04-08-2014, 09:11 PM   #564
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
Originally Posted by Juvenile View Post
Any pics of stock wheels with extra meat?
you can't do anything meaty with a 7" wheel
Jive Turkey is offline   Reply With Quote
Old 04-09-2014, 01:36 AM   #565
humanshield
Drives: bucket
Second pic is badass. love it.
humanshield is offline   Reply With Quote
Old 04-09-2014, 02:15 AM   #566
cactus
cactus's Avatar
Drives: 13 SWP BRZ
My autox setup is 245/40/17 on stock rims, is about as meaty as some others in this thread.
cactus is offline   Reply With Quote
Old 04-09-2014, 12:08 PM   #567
Jive Turkey
the tuna, no crust.
yes, and if you read the title in here should be 255 AT MINIMUM.
that must bulge a lot?!
Old 04-09-2014, 12:23 PM   #568
gramicci101
Off Topic
So, for 18x8/18x9, would you go 225/255, or 235/265?
Old 04-09-2014, 12:24 PM   #569
sdemo
sdemo's Avatar
Drives: '13 SWP ZC6 R
I wouldn't stagger in the first place. What's the point? You like uneven wear? A square setup fits perfectly on this car.
sdemo is offline   Reply With Quote
Old 04-09-2014, 12:27 PM   #570
gramicci101
Off Topic
True, but 255 is bigger than I want to run in the front. I'm staying on springs and struts, and I don't want to worry about clearance issues. I could do 225 all around, but I like the wide rear tire look.
Old 04-09-2014, 12:33 PM   #571
sdemo
sdemo's Avatar
I'm fairly certain plenty of members - in this thread even - are running springs on stock struts with 255 tires. If you're concerned about clearance, buy 245s and be done with it.
Old 04-09-2014, 02:31 PM   #572
UltraMarine86
UltraMarine86's Avatar
Drives: Ultramarine '13 FR-S
^^It's not worth the extra money to go staggered. When it's time to rotate your tires you can't cuz your not square. Think longer term not just right now. It might look pretty but that bill for 4 new tires every time is gonna suck. Just my opinion though
Sent from my SCH-I605 using Tapatalk
UltraMarine86 is offline   Reply With Quote
Old 04-09-2014, 03:01 PM   #573
Jive Turkey
the tuna, no crust.
uneven wear has nothing to do with it. all depends on your alignment, etc etc etc. unless you're referring to the inability to rotate tires front to back.
eh, so you can't rotate, but most cars that are street driven and majority of owners don't rotate anyway, especially for those of us who have dedicated winter/summer/track setups this is minor because tires last much longer.
here is a rule of thumb that i go by. 245/40 is SQUARE on a 8.5" rim. a 255/35 or 265/35 is square on a 9.5" (obviously this is dependent on brand) and then for every half inch take out 10-20mm and bump the aspect ratio. so a 235/45 instead of a 245/40....etc etc. it also depends what look you want (stretch/square/bulge)
also depends on what brand/type of tire you're going for.
on a staggered 8/9 setup i'd run a 235/45 front and a 245/40 or 255/35 rear (dependent on brand) some tires run really wide so a 245 can fill out a 9" no problem.
with that said, a square setup fits the car really well and makes life a bit easier. but if your'e on springs/struts clearance might be an issues depending on tire size/offset/width of rim.
-ivan
Old 04-09-2014, 03:19 PM   #574
gramicci101
Off Topic
I hadn't meant to start a big discussion, but thanks everyone for the inputs.
on a staggered 8/9 setup i'd run a 235/45 front and a 245/40 or 255/25 rear (dependent on brand) some tires run really wide so a 245 can fill out a 9" no problem.
-ivan
Why would you only increase the tread width by 1 cm when the wheel width increases by 1 inch?
Winter Tire Review Thread (Please contribute) pastuch Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 344 03-13-2024 05:49 PM
Wheel Directory: Forgestar F14 18x8.5 +38/18x9.5 +38 ScionFR-S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 97 09-09-2015 06:32 PM
Meaty rubber on flush spoke rims? red_comet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 06-14-2013 12:21 PM
Official wheel/tire fitment thread needed empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-22-2012 01:40 AM
The Wheel and Tire Fitting Thread EvoFanatic Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 03-15-2012 03:05 PM
