12-06-2014, 11:06 PM | #561 |
I'm not a fan of fog-light mounting solutions, as I'd rather reserve that space for brake ducting.
Although it's not a concern for most, venting air out the fender liner introduces a lot of drag. I've always thought about an opening that goes through a cooler, and then the post-cooler air going to a brake duct.... but it hasn't been done on this car, yet. |
12-07-2014, 12:25 AM | #562 | |
Drives: many
12-07-2014, 02:10 AM | #563 | |
The OEM or OEM style sandwich plate ones are great for light duty and street driving (perfect actually), but are completely inadequate for any tracking or spirited canyon driving. |
12-07-2014, 02:08 PM | #564 |
Junior
Drives: a car
This may be a stretch, but what about the other side of the tire? Why not make brake ducting through the fender on the door side, freeing up the space for the oil cooler in the front of the fender.
12-07-2014, 02:09 PM | #565 |
in orbe terrum non visi
Drives: violent
Or put it where I did.
12-07-2014, 11:34 PM | #566 |
corolla specs/GTR looks
Drives: ooh oooh pretty tail lights
Robispec
I haven't overheated since and I track in 100+F Best money I ever spent on my brz kidz
SOLD THEM BOTH
Hers: 2007 987S Mine: 2012 991S That was fun, thanks Hachi |
12-08-2014, 01:33 AM | #567 |
Drives: 2013 Black FR-S
Lol those aren't sold nor supported anymore and several people have had issues with the core leaking coolant after about a year.
12-08-2014, 08:50 AM | #568 | |
I must have gotten a good one, mines been flawless, tho a tite fit So ...koyo
SOLD THEM BOTH
12-08-2014, 08:56 AM | #569 |
Drives: dark grey metallic Toyota 86 MT
AVO oil cooler
Bolt on with no cutting involved. The duct protects and directs air to the oil cooler. I was not able to go beyond 200 °F (oil) on a spirited run. Compared to around 230 °F without an oil cooler when I ran the same route earlier this year.
12-08-2014, 10:30 AM | #570 |
Drives: 2013 FRS Whiteout
This question goes mostly for track participants. What would be an adequate setup for NA car with enough overhead to run a turbo at the track. I was considering running a setup like the one carolina dyno makes, shroud with spal fans along with koyo rad, this paired with a front mounted oil cooler such as seatrab core with a sandwhich type adaptor. Any suggestions, althought nothing seems to be good enough for turbo's at the track due mostly to placement of the kitss.
@CSG Mike What about these guys from setrab, i think its a 20 row. Last edited by yomny; 12-08-2014 at 10:51 AM. |
12-08-2014, 11:05 AM | #571 | |
So basically the same as a Full Blown setup?
12-08-2014, 11:31 AM | #572 |
Didn't know that FB used a Koyo rad. The only thing that is similar is that there are fans and a shroud involved, so no, not the same thing Carolina's fans are wire to be plug and play. I'm not sure of what the specs or details are on the FB because there isn't much info given on their site about it. The fans on the first picture below are 12" spal slim line also different from the ones FB uses(based on the picture). Again the concept is similar, thats about it. FB's is priced lower so thats more appealing. On a side note, would the seatrab cooler with fans make any difference or the heat still needs to be removed from the engine bay via venting methods? |
12-08-2014, 11:39 AM | #573 |
Very interested to find out who makes that shroud and fans for the oil cooler.
I looked and couldn't find the AVO oil cooler or shroud in the pic posted earlier. The pic was for an FRS, will it work on the BRZ? |
12-08-2014, 11:47 AM | #574 | |
FP920M22I The FP920M22I is the most popular Setrab fanpack, due to its compact size, high performance, and universal nature. Featuring a Setrab ProLine 9-series 20-row cooler (p/n 50-920-7612) and two low-profile 342cfm sealed-motor Spal fans, this unit performs sitting still as if mounted in the direct airflow at 50mph. Typical applications:
Similar Threads | ||||
any serious benefit Heat Tapes? | Djen | Engine, Exhaust, Transmission | 22 | 02-18-2014 03:20 PM |
Heat bad for your car? Ways to cool it? | BushMan | Scion FR-S / Toyota 86 GT86 General Forum | 35 | 08-01-2013 10:15 PM |
Misfire with heat? | bigjake | Issues | Warranty | Recalls / TSB | 2 | 04-28-2013 09:02 PM |
Do I Need a Heat Shield? | arleewa | Engine, Exhaust, Transmission | 1 | 01-08-2013 06:37 AM |
Overpipe Heat question | Amadeus | Engine, Exhaust, Transmission | 5 | 12-19-2012 01:18 AM |
