02-28-2014, 09:34 PM | #561 |
Drives: 86 GTS White
Has anyone tried installing the Perrin CAI with the AVO kit?
02-28-2014, 09:37 PM | #562 |
Boosted
Drives: Not a supra....yet
02-28-2014, 09:39 PM | #563 |
I Love custom Turbo kits
Drives: Limited BRZ
me and @gdrider77 it fits, but have to make a small custom bracket because the way its designed, it will point a bit to the sky, and to make it level with the AVO inlet, need a custom bracket. Not a big deal, any piece lf aluminum drilled will do.
02-28-2014, 11:42 PM | #564 | |
02-28-2014, 11:50 PM | #565 |
Drives: 2013 "AVO Orange" FR-S
I got one of the exhaust manifolds back that the customer was worried about - and just as discussed in another thread, the flange surfaces themselves were actually flat, it was simply that they were not on an exact flat plane to each other.
The Following User Says Thank You to AVOturboworld For This Useful Post: | SkAsphalt (03-01-2014) |
03-01-2014, 03:22 AM | #566 | |
03-01-2014, 07:38 AM | #567 |
Drives: Limited BRZ
I never ran it with the stock intake. I do believe there is not much to be gained and it was more for the turbo sounds purposes.
The Following User Says Thank You to Sportsguy83 For This Useful Post: | Skorov (03-01-2014) |
03-01-2014, 07:41 AM | #568 |
Drives: Limited BRZ
Why does that matter? It's a legitimate question.
03-01-2014, 07:57 AM | #569 |
Drives: White 2013 FRS
Really want to go AVO, but there have been too many people reporting these exhaust leaks. Leaning towards SC in the mean time until the turbo wrinkles on the 86 get ironed out
Maybe a redesigned header with thicker flanges would put people's mind at ease? If these reports are holding me back, they are probably holding others back as well... |
03-01-2014, 12:04 PM | #570 |
As I mentioned in the other thread, we'll be providing new metal gaskets in all kits from now on so that people will not re-use their old gaskets. I've provided two new exhaust manifolds recently to two of the people concerned.
One that I got back was fine - there was no warpage of the flange itself, they simply were not on a flat plane to each other, which is very common with Subaru headers, but can be confusing to people only used to inline header design. The other one, the cracking issue was caused by using thicker gaskets, but not spacing out the bracket at the turbo end, which pulled it down. Still warrantied his header even though it's been quite a while since it was installed. |
03-01-2014, 02:21 PM | #571 |
Ridge Racerrrrrrrrr
Boom, customer service
The Following User Says Thank You to SkAsphalt For This Useful Post: | gdrider77 (03-01-2014) |
03-01-2014, 04:35 PM | #572 |
Drives: 2JZ FRS
I still have not had any issues. I re torqued mine after a couple hundred miles and have a few thousand on the kit now. New OEM frs gaskets with a skim of copper rtv on each side
03-01-2014, 09:01 PM | #573 | ||
Drives: AE86 / FRS / FC3S / GC8 / S14 / R32
Meanwhile, in other news, do you see any of my customers have any issues? Or anyone of my installs using sealant? And pouring sounds like you already have a bias when you haven't even done one for yourself. I reckon if they did, they'd be here talking about it and not enjoying themselves like they are. Course, you could take that for what it's worth. My 2 cents. Bob @ Drift-Office, LLC |
03-01-2014, 09:19 PM | #574 |
Drives: Limited BRZ
You are saying that the turbo spool is louder with Perrin CAI or other aftermarket intake when compared to stock aribox?
Tags |
avo, avoturboworld |
Similar Threads | ||||
Innovate (Sprintex) Supercharger Owners Topic | DarrenDriven | Forced Induction | 9139 | 12-29-2023 10:58 PM |
FA20Club Turbo Kit Owners Topic | pixel67 | Forced Induction | 1531 | 09-09-2014 12:36 PM |
OFF TOPIC: Spotted a Gallardo | markmatley | Hawaii | 4 | 02-24-2013 04:26 PM |
Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 12:18 PM |
Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 05:14 PM |
