#5657 |
AutoX-10/10ths every run
I had the bearing in the idler pulley start to fail in about 7k miles.
[ Delicioustuning | Counterspacegarage | RS-R USA | Cusco USA | SPL Parts | ACE Header | Stark Performance | Infinite Motion | Ciro Racing | Build thread:Here ] [ GR Corolla Core in White w/LSDs on wish list ] |
The Following User Says Thank You to whataboutbob For This Useful Post: | poorsche (12-02-2014) |
#5658 | |
Drives: Flat grey Toyota 86
@sales@delicioustuning.com When will the full kit and tune be on the website? |
#5659 |
Drives: 13 BRZ Limited, 2000 Impreza Sport
Ok, so the bearing failed and was replaced with the pulley. Got it.
Innovate powered- Corn fed- FBM tuned
The Following User Says Thank You to poorsche For This Useful Post: | whataboutbob (12-02-2014) |
#5660 |
Senior Addict
Drives: 86 GT
Stupid question, but do we have 2 idler pulleys?
#5661 | |
PhoneFlash by EcuTeK
Sincerely, Zach Delicious Tuning |
The Following 2 Users Say Thank You to DeliciousTuning For This Useful Post: | Lawnik (12-03-2014), whataboutbob (12-03-2014) |
#5662 |
Drives: 2014 WRB BRZ
I've got a noise/squeak from the idle or tensioner pulley now, and only 500 miles after installing the supercharger. Does the pulleys making noise pretty much mean it's about to go, or is it normal now with the added strain from the SC?
#5663 |
I was getting squeaking from the idler pulley. It never failed completely, but when I took it off it had a lot of slop in the bearing. I'd suggest you pick up one of the pulleys that I linked to above, I've had it on my car for some time now and it isn't squeaking. Seems like a good fix.
The Following 2 Users Say Thank You to whataboutbob For This Useful Post: | CarzCarzCarz (12-03-2014), Xero-Limit (12-03-2014) |
#5664 |
Senior Addict
Drives: 86 GT
I've read about some guys having low speed drivability/throttle modulation issues, whereas some others say their's feel just like stock...simply by using a canned tune (i.e. Delicious).
So I went down to see a local sprintex installer/tuner (renowned subaru specialist) chatted a long time but he pretty much said it can't be totally eliminated. According to him they can smoothen but it'll always be there. I always thought a dyno tune would be best. So I left there slightly confused and not feeling very confident about using them ![]() Going to speak to another tuner tomorrow. Plan is to bet boosted before xmas ![]() |
#5665 | |
#5666 |
Senior Addict
Drives: 86 GT
#5667 | |
#5668 |
Isn't he the service manager at the dealership? didn't know he is a tuner.
#5669 | |
Drives: Raven FR-S
Innovate (Sprintex) Supercharger Owners Topic
Mine still to this day surges and bucks while the oil temperature is cold, and this is on the most recent revision from @DeliciousTuning. I'll be pulling the blower off of my car soon to look at the laminova core and to redo the pcv/ breather system on the car. Gonna be installing dual Radium catch cans and replacing the pcv valve. I'll also be adding check valves to the outlet sides of the catch cans, since radium doesn't supply any, if I can find them. Edit: I also replaced the 2 coil packs that were misfiring the most and it still misfires while the engine oil temp is cold. Spark plugs, however, looked good when I checked them.
Raven FR-S mods: Unichip, Ground Control street coilovers with camber plates and strut tower brace, SPC Lca's, Drag DR-38 wheels with Dunlop Direzza DZ101s, Perrin CAI and silicone inlet tube, Perrin 3" resonated catback, Perrin high flow catted front pipe, Rev Works UEL header.
#5670 | |
Innovative ideas to increase interior storage capacity? | swift996 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-30-2013 10:45 PM |
AVO vs Innovative | diss7 | Forced Induction | 32 | 01-21-2013 06:15 PM |
Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 12:18 PM |
Technical topic sub-forums | OrbitalEllipses | Site Announcements / Questions / Issues | 1 | 07-17-2012 11:38 PM |
Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 05:14 PM |
