Old 11-26-2014, 05:50 PM   #5643
s2d4
s2d4's Avatar
Originally Posted by Jac View Post
While doing my research on this kit the most common failure/issue seems to be coil packs going bad. Has anyone figured out why? Tune?
Heat.
Old 11-26-2014, 06:55 PM   #5644
Sellout
Mr. Cranky Pants
Sellout's Avatar
Drives: 2013 Argento FR-S
The supercharger kit isn't causing them to go bad. They are a problem before the supercharger kit is installed and the supercharger kit causes them to be realized as a problem earlier than they would be if the car was left NA. This is the only explanation that makes any sense.
Sellout is offline   Reply With Quote
Old 11-27-2014, 08:14 PM   #5645
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
I just found out that the Spintex kit now comes with State road transport authority compliance/approval (in Western Australia). This is a big tick for me, and I might just have to go with this instead of the AVO. Compliance approval = car can be fully insured + cop friendly.
Fizz is offline   Reply With Quote
Old 11-28-2014, 04:24 PM   #5646
jjkerr626
jjkerr626's Avatar
Drives: 2013 Subaru BRZ Sport Tech
Originally Posted by jflogerzi View Post
To me it looks like the sweet spot for non IC users is the 72mm pulley and E85. This setup should yield 250WHP and 200WTQ with nice instant boost response. This should also allow the car to run on 91 if need be.
I got 225whp and 185lbsft on 94 octane and the stock pulley non inter cooled.
Performance Parts: Innovate Motorsports Supercharger, Mishimoto Oil Cooler, Borla UEL Header, Perrin Cold Air Intake, Perrin Cat Back Exhaust, Perrin Crank Pulley, Perrin Rear Shifter Bushing, Perrin Transmission Bushing, Perrin Master Cylinder Brace, Billet Pro Short Shifter. Handling Parts: Perrin Control Arm Braces, Perrin PSRS Offset Steering System, Perrin 22mm Front & 22mm Rear Sway Bars, Perrin Spherical Rear Endlinks
jjkerr626 is offline   Reply With Quote
Old 11-28-2014, 04:34 PM   #5647
jflogerzi
jflogerzi's Avatar
Thanks for the info. I can see E85 with more timing doing 250/200 even a bit more.
Old 11-29-2014, 03:08 PM   #5648
whataboutbob
AutoX-10/10ths every run
Not sure if this info has been posted, but I got an upgraded idler pulley for my SC from Innovate some time ago to replace the original that had failed.
http://www.oreillyauto.com/site/c/de...0074&ppt=C0007
Build thread:Here
The Following 4 Users Say Thank You to whataboutbob For This Useful Post:
CK_Bladesmith (11-29-2014), Dream20b (11-29-2014), Ethan (12-02-2014), stockysnail (12-06-2014)
Old 11-30-2014, 11:19 AM   #5649
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Nice. How has that been holding up so far?
Just noticed they're manufactured by Dayco, which should be good quality stuff.
Old 12-02-2014, 12:16 AM   #5650
whataboutbob
No issues. This is what should have been spec'd from the start IMO.
Build thread:Here
Old 12-02-2014, 12:17 AM   #5651
Ethan
Drives: Subaru BRZ
For those who have e85 available but have been waiting on the sidelines, I suggest jumping in. Not only for a bit more power, but for how smooth it make the engine run. Big thanks to Bill Knose at Delicious Tuning. Car loves the e85.
Ethan is offline   Reply With Quote
The Following 3 Users Say Thank You to Ethan For This Useful Post:
J.C. (12-10-2014), whataboutbob (12-06-2014)
Old 12-02-2014, 12:20 AM   #5652
Ethan
Drives: Subaru BRZ
And for the record, I have the 69mm pulley, intercooler, and flex fuel kit from Delicious. Car is happy, happy, happy.
Old 12-02-2014, 12:35 AM   #5653
jjkerr626
jjkerr626's Avatar
Has anyone run a water/meth kit and how much increase in power have you seen? Thanks.
Old 12-02-2014, 01:29 AM   #5654
poorsche
poorsche's Avatar
Drives: 13 BRZ Limited, 2000 Impreza Sport
The pulley itself failed? Not understanding
Innovate powered- Corn fed- FBM tuned
poorsche is offline   Reply With Quote
Old 12-02-2014, 05:38 AM   #5655
brianhj
Drives: 2017 Camaro 1SS
Yes, they can sieze up and break belts
brianhj is offline   Reply With Quote
Old 12-02-2014, 12:05 PM   #5656
poorsche
poorsche's Avatar
Funny you mention that, I've broken a belt although I don't think it was pulley related. Are you talking about the bearing that the pulley sits on?
2 whp better than n/a e85, 2 whp? you're an idiot., 2screwsbetterthan0screw, 65 whp better than na e85, bspt fittings ftl, hate u all me no have sc, im just here for the tags, inorite!, it's no turbo but, only big numbers matter, screwyou, whine sexier than turbo, whines_more_than_your_gf, wts grey market butthurt.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 12:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 05:14 PM
