#5615 |
Erected Member
Drives: frs
Would be awesome if you could post up a couple of instructions with detail pictures about the issues you had and how you solved it so that we could maybe compile a more complete and detailed install instruction.
#5616 | |
Drives: '13 BRZ Limited WRB Phantom ESC 1.5
At the very top in parenthesis, it mentions "Filament tape recommended". Apparently duct tape is fine. I didn't have any filament tape, so I went with duct tape. The top row right pic is the finished product. Don't go ahead and set the batteries in the tray. Just wait. The 2nd row left pic is irrelevant if you ordered the 1.5 dump pack - you're not doing the conversion from dump 1.0, so you will only receive the longer block with the negative cable already installed. On the 2nd row middle pic, don't be too concerned about breaking terminals off when bending them up. They seem to be plenty bendable. Note: you will have to bend them up close to the body of the battery, as the "series block" connectors are just long enough. I bent and re-bent multiple times until I was comfortable with the connections. 3rd row middle pic: The kit tray seems to be designed to fit in the oem tray. I had already taped all the batteries together, so I just set them all in the tray after putting the tray in. When it says "Install 12v starter" that obviously means "12v starter battery". DO NOT FORGET TO INSTALL THE COPPER CONNECTOR ON THE BACK OF THE MAIN DUMP before moving to next pic. 3rd row, right pic: My cover sheet was cut out for the positive terminal, but was not cut out for the ground cable. I just cut out a portion along the edge for the ground cable. Yes, install factory pos and neg wires. DO NOT TIGHTEN THEM DOWN YET.
'13 BRZ Ltd MT WRB Phantom ESC 1.5
2012 Honda Accord Coupe 2006 Saab 9-3 2.0t 1997 Honda Accord Coupe 1995 Honda Prelude VTEC |
| The Following 2 Users Say Thank You to robwbright For This Useful Post: | fenton (05-24-2014), shif7i7down (05-24-2014) |
#5617 | |
#5618 | |
START with the regular install instructions. Some of the confusion came from reading only the 1/2 dump conversion instructions for putting the battery packs together (I thought I'd just go ahead and get the battery pack together) BEFORE doing anything else. Read both the single dump and 1/2 dump instructions together before starting and it should save you some time. Again, start with the regular install instructions, then switch to 1/2 dump instructions when I note that below. Top row left pic: Ignore "bolt copper series connector" (you'll do that after you put the batteries in the tray but BEFORE putting on the cover sheet and holddown block - see 1/2 dump conversion instructions). Go ahead and tape the main dump batteries together. Ignore the other batteries for the time being. Don't do top row right pic yet. You'll do that later. 2nd row left: I'd just say be careful when you drill the rivets out so as not to get any metal shavings down in the airbox. 2nd row right: When you reinstall the intake box, don't tighten it all down yet. And don't forget to hook up the connector that connects to the intake box - my connector had slipped below the level of the intake box and I just didn't notice it. That connector being disconnected gave me two CELs even though I had flashed Shiv's OFT tune. The instructions don't really mention the sound tube at all. After removing the resonator and reinstalling the intake box, the sound tube will just be hanging out there. It bolts on to the top left of the engine and then down and into the firewall. Just pull on it and it will come right out. Bottom row left: Make sure your clamps are all tight and turned up where you can get to them. Also, this is where you will want to play with adjusting the clamps, compressor and intake box so as to get a good fit on the intake box against the piece that it connects to coming from the bumper. I didn't do those adjustments (yet) and my intake box is slightly sideways (look several posts up for a pic). Bottom row right: The control box is a bit of a tight fit. You'll probaly find it easier if you put the bolt thru the frame hole first, then set the control box down over it. Turn page... now switch to 1/2 dump instruction page, 2nd row, middle pic. Go ahead and follow those instructions down to the end of the 1/2 dump instructions. Now back to page 2 of the regular install instructions... but you'll have already done most of the top row of pics when you followed the 1/2 dump instructions. The exception is "Use factory [battery] hold clamp" from top row middle pic - that's obvious, but not mentioned on the 1/2 dump pack instructions. Top row right pic: NOW you've gotten to why I said not to tighten the pos and neg terminals. "Connect eyelets to pos/neg factory clamps...". NOW you can tighten them up. 2nd row left pic: Before you get under the dash by the throttle pedal, you'll probably look funny at the WOT bracket and wonder how that's going to mount. Look at it and notice how the switch mechanism works. Then, once you get under there, the connection point will be VERY obvious. There a threaded stud sticking out behind the throttle pedal. Mount the bracket there so that the throttle pedal arm hits the switch and bend to what appears to be somewhere between 70 and 90% of the movement of the throttle pedal towards the floor. 2nd row middle pic: I hate breaking plastic pieces in cars. I was a little concerned about removing the lower console center panels. Don't be. Just pry on the edges until the plastic rivets pop loose. If I recall, there are three - one on the forward facing edge, one on the back facing edge and one upper middle. Do the forward and back first, then pop the upper middle. After those panels are removed it's pretty easy to snake the wires thru. Bottom middle pic: I just left the fuse cover off. Not sure what others are doing. Bottom right pic: The 1/8" rubber line connects to a little nub/nipple on the passenger side of the mounted control box. Can't see that in the pic. I think that covers all of my issues. Some of those will be obvious to others, and some of them only made me hesitate for a few seconds. A couple of them resulted in me wasting 20-30 minutes. I hope my notes help speed up your install.
| The Following User Says Thank You to robwbright For This Useful Post: | shif7i7down (05-24-2014) |
#5619 |
Drives: Fiat Abarth
Installed my 1.5 dump pack!
Installation summary
![]() Installation was very simple apart from one part, removing the negative cable from the short block and inserting into the long block. This honestly probably took me 30-45mins of struggling taking it out of the short and forcing it into the long block. After spending 45mins getting it into the long block the connector decided to snap off after i tried to bend it back into place, thank you Rob for including a replacement in the kit! ![]() Although my plier did not survive the installation ![]() ![]() The negative cable itself didn't fair too well either, see the exposed copper. Some electrical tape fixed that though. ![]() After doing a few WOT runs my first impressions are that the 1.5 dump pack doesn't feel anymore powerful (peak torque i mean) but definitely feels like it holds the power for longer. Before i felt peak torque start to drop at 5K RPM, now maybe i feel it start to drop around 6K RPM. I'd suggest the ESC should've probably come this way from the beginning but its a nice upgrade! Planning to hit the dyno next week and will report back with the gains
Phantom Supercharged BRZ | 205WHP / 185WTQ Nameless FP/OP Combo |
#5620 |
Did you set it on the OEM battery tray? It appears to be designed to work with it. The oem fits down in the two little holes which help hold it in place. The 1.5 dump tray fits nicely down in the OEM.
#5621 |
I just want to say thank you to all the people posting notes and suggestions on the install.
This is such a great community that wants to help anyone and everyone. All of this critism is great and will be built into future revisions of the kit where applicable. |
| The Following User Says Thank You to fenton For This Useful Post: | raven1231 (05-24-2014) |
#5622 | |
Lightning McQueen Driver
Drives: Limited Red 6MT BRZ
I love the new battery tray. Double check your positioning. Both nlowell and I found it more secure.
Installed Mods: Phantom Electric Super Charger | Open Flash Tune | Perrin OP/ HFC Front pipe | Invidia Q300 catback | ST Suspension | JDL Header | Flex Fuel |
#5623 | ||
Custom User Title
Drives: Spaceship
![]() I'm really looking forward to E85, though. I think that will really take advantage of the boost. Quote:
Now I just need to get that SSP shift kit and a higher ratio final drive... |
| The Following User Says Thank You to alexand3r For This Useful Post: | raven1231 (05-24-2014) |
#5624 |
Drives: Firestorm FR-S AT
Ok, here is a log. This was basically two 0-60 runs, the first without the ESC and the second with it.
http://datazap.me/u/stormalong/esc-t...&data=1-2-9-12 Don't know if this tells anyone anything, I'm still figuring out how to interpret it.
Phantom Electric Supercharger with Procede controller, GReddy SP Elite, CA-FI Dashlinq4
#5625 | |
E85 is really going to change this for the better for the people that have it available to them. Take a video and post it up for other to see :-) I'm installing the Ofh today and will post some videos up later as well |
#5626 | |
Drives: WR Blue BRZ, 240Z
Purchase your tools from SnapOn or Craftsman and you'll never have to worry about a broken tool because 1) they don't break, and 2) they have a lifetime warranty. Cheap tools will just piss you off.
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
#5627 | |
Custom User Title
Drives: Spaceship
------------ Remember: ------------ Header to Cylinder - 22 ft-lb Header to OP - 26 ft-lb Do a circular pattern on the bolts and keep torque reletively even until they're ready for final torque. A crows foot socket and long extension makes the single header nut much easier to torque down. It also helps to start the car while it's still up in the air to get it warm and then re-torque. You probably know what you're doing and I mean no offense. I've just been through the exhaust leak thing before and it's no fun! |
#5628 | |
Drives: 2013 Scion FRS
After doing a couple of runs I download the log and upload to datazap.me First I turn on just Throttle and zoom in on a section where I went full throttle. I then turn on RPM. This is what that looks like: ![]() I then turn off Throttle and turn on AFR to see how that looks: ![]() Finally, I turn off AFR and turn on boost to see how that was. Notice there is a ~1 second lag between full throttle and boost pressure and for some reason no boost is being logged as 72lbs of boost... ![]() I'm still running lean for some reason and have a bump early on (< 5,000 RPM). I'm going to get this straightened out once the e85 tune comes out. If anyone thinks this isn't the right way to run gear pull logs please let me know. I'm by no means an expert!
Complete Part Out: http://www.ft86club.com/forums/showthread.php?t=125688
| Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras | Circuit Motorsports | Member's Car Journals | 4 | 03-21-2013 05:45 PM |
| Subaru BRZ : Full Throttle, powerslide, hard revving & ride | ESBjiujitsu | BRZ Photos, Videos, Wallpapers, Gallery Forum | 20 | 05-30-2012 07:43 PM |
| 86 Full Throttle Video + another. | Aus86 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 2 | 04-02-2012 08:07 AM |
