Old 12-06-2016, 08:16 PM   #547
lostpanda
Originally Posted by makinen View Post
Yes I read it already.
But you think if you do a track day....
bump!
lostpanda is offline   Reply With Quote
Old 12-07-2016, 12:27 AM   #548
Yobiwan
Yobiwan's Avatar
Drives: Toyota 86 Turbo, Lexus NX300H
Originally Posted by Torry@HKSUSA View Post
Ok, made this:
http://www.hksusa.com/supercharger-kits-5/
Anything else you guys think should be on there that I'm missing? I forget what all parts everyone was asking about.
replacement parts for BYPASS VALVE DIAPHRAGM?
2012 Toyota 86 6MT / 11:1 CR block by Outfront / SBD500x Turbo 17PSI@93gas /Avo 2.5 overpipe+Avo 2.5 catted frontpipe /MAP 3" CBE/ Tein Mono sport / STI brembo Front /OS技研 LSD/SSR GTX01 18x9.5
Yobiwan is offline   Reply With Quote
Old 12-07-2016, 01:58 AM   #549
lostpanda
About the HKS V3
I paste some picture from my moblephone![ATTACH]Name:  745617535699405931.jpg
Size:  220.4 KB[/ATTACH]
Old 12-07-2016, 08:28 AM   #550
Torry@HKSUSA
Torry@HKSUSA's Avatar
Drives: HKS
Originally Posted by empower-auto View Post
Where is the traction fluid filter found on an installed system? (V2)
It's located directly underneath the supercharger.
Torry@HKSUSA is offline   Reply With Quote
Old 12-07-2016, 09:09 AM   #551
zeal86
zeal86's Avatar
Drives:
Sorry for duplicate post... new Tapatalk app is a little screwy... plus I'm still getting used to it
zeal86 is offline   Reply With Quote
Old 12-07-2016, 09:11 AM   #552
zeal86
zeal86's Avatar
Drives:
Pictured below is my traction fluid filter install on my v3. I don't believe there is a difference between the v2 and v3 when it comes to this part of the installation.
__________________________________________
projekt zeal86 build
zeal.eightsix Facebook
Instagram @zeal.eightsix
Old 12-07-2016, 07:44 PM   #553
lostpanda
How many KM we need to change this filter or how long we need change it ?
Old 12-08-2016, 12:48 AM   #554
Yobiwan
Yobiwan's Avatar
every 5yrs or 70000km
Old 12-09-2016, 01:33 PM   #555
Koj
Koj's Avatar
Drives: Toyota GT86
Ok, made this:
Thank you Torry !! Well done !
As Obiwan, I m interested about the bypass ..
The intercooler can be changed ? The Traction Fluide radiator too ?
Koj
S/C HKSv2, HKS R Spec Manifold, Fujitsubo Authorize R Type S Catback, and more...
My Journal/Garage
Koj is offline   Reply With Quote
Old 12-09-2016, 02:16 PM   #556
wbradley
Sarcastic SOB
wbradley's Avatar
The intercooler can be changed ? The traction fluid radiator too ?
I wasn't able to purchase a traction fluid radiator alone, so I substituted a Setrab 7-row which is probably a more effective cooler. Considering mine is zip tied to the crash bar in the bumper, it better be more efficient as the air flow is limited in this location.
You can change to a different intercooler but then you should have a custom tune and your piping will probably need to be customized. A bigger intercooler might cause some latency in pressurizing the intake, depending on how much bigger. That's what I have in my "mystery" V1 kit originally from a member here in Turkey. Has a brand new supercharger now though.
Old 12-09-2016, 02:27 PM   #557
Koj
Koj's Avatar
Drives: Toyota GT86
My car do a strange noise some times on Drift lap.
In normal way, rear way, or lateral ... I hear it all the ways the car goes.
It's like the compressor still pushing and the bypass is opening the way but it's singing louder
It is like : BILI BILI BILI BILI BILI ...
I have a video : it s short but it can be hear at 0:12
In the V2 manual it is wrote : "After driving a while and stop the engine when the engine room is at high temperature, the belt may make squeaking noises. This is caused by the factory auto-tensioner’s adjustment function; this is normal."
Could it be that ?
Or my HKS Hypermax IV SP Coil Over could do that noise ?
Koj
My Journal/Garage
Old 12-10-2016, 09:43 PM   #558
Gearbanger
Gearbanger's Avatar
Drives: Lexus is300 celica gts
So does cold air effect boost levels? I'm on a V3 100 mm pulley and e85. I had car out tonight it's in the 20's and I was pegging 15lbs of boost instead of 11.5lbs as rated.
https://instagram.com/p/BN2pnXsjezI
Gearbanger is offline   Reply With Quote
Old 12-11-2016, 02:57 AM   #559
Shinra Inc
Shinra Inc's Avatar
Drives: Tiny Bronco
I've had mine installed for about a month. So far so good. Intercooler was a pain to install because of the thicker radiator. HKS should redesign the kit with a thicker rad in mind. Chances are people adding a supercharger will upgrade that part.
Still have to send it my flash editor for the 93 tune. Car pulls great and has really good low rpm roll on the throttle performance even though the dyno graphs make it look other wise. Tq dip replaced by tq event!
Shinra Inc is offline   Reply With Quote
Old 12-28-2016, 02:38 PM   #560
Andew727
Drives: Scion FR-S
Could it be that ?
compressor stall?
Andew727 is offline   Reply With Quote
Kraftwerks Supercharger Owners Thread projek_01 Forced Induction 4310 04-07-2025 01:12 PM
P&L Turbo kit Owners thread Hawaiian Forced Induction 73 07-07-2018 02:31 AM
Five Axis Edition FR-S Owners Thread digital_assassin FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 563 07-08-2015 09:22 PM
**Offical 213/323/626/818 owners thread** mr. slim Southern California 71 10-07-2013 12:58 PM
Supra Owners Build Thread BoostJunkie Other Vehicles & General Automotive Discussions 164 03-12-2012 09:37 AM
