Old 09-30-2013, 12:28 PM   #547
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Originally Posted by stevo_12v View Post
Hahaha! That'lll be me allright!
I'll fix it up when I get a proper dual catch can setup(Radium).
I'm glad that post was able to pay it forward and correct at least one PCV system! The crazy thing is that Cusco are selling their catch can kits and still picturing them in their catalog incorrectly routed to front breather hose.
I'm not sure what the included instructions say, but there has been some recent confusion on how the Cusco kit's hoses are supposed to be routed.
Hope you can begin catching some (but not much) real blow by soon!
Old 09-30-2013, 03:51 PM   #548
stevo_12v
Drives: Mazda MX-6 Turbo, Toyota GTS86 37J
EXACTLY!! I just followed what the CUSCO instructions had on their diagram. Apparently the connection from where I have it, it is for high RPM blow by? Somebody mentioned it to me online but I forgot who, not sure if the information is correct though.
But needless to say, I'll be going for a dual Radium catch can setup, one for the front and the back.
stevo_12v is offline   Reply With Quote
Old 10-01-2013, 09:22 AM   #549
ATL BRZ
ATL BRZ's Avatar
As I understand it and quoting a few of the facts from @Dezoris , the front breather tube under the AC compressor is not under vacuum. 80-90% of all blow by gas is routed to through the PCV valve at the back of the block under the intake manifold, where the hose connects to the top of the intake manifold. This is where you will collect the most amount of oil, unburned fuel and water vapor in a catch can. The front breather tube is for excess blow by not routed through PCV only under high load, namely in forced induction.
Old 10-01-2013, 10:17 AM   #550
Dezoris
Dezoris's Avatar
This is all correct. The only risk of running a can on the PCV line is vacuum leaks. Make sure the lines and can are sealed. Why I chose a more expensive can with velocity testing done. It maybe that cusco never designed their can to handle vacuum and put it on the breather side in the instructions. Something only they can answer but good luck.
Old 10-03-2013, 08:07 PM   #551
ATL BRZ
ATL BRZ's Avatar
Driveway Performance Labs had the Hancha group do some CFD analysis on their diffuser. I found this stuff fascinating.
Original thread with lots more data: http://www.ft86club.com/forums/showthread.php?t=48283
Originally Posted by Wonderbar View Post
The models say it's functional. It reduces drag and gets rid of all 90 lbs of lift the car generates at 100mph stock and makes downforce on top of that!
Since installing it doing even 85-90 mph on the highway with it I'd definitely agree with the models.
The rear tires feel more planted and the car stopped wiggling around so much when braking from high speeds.
The Following User Says Thank You to ATL BRZ For This Useful Post:
Wonderbar (10-03-2013)
Old 10-03-2013, 08:11 PM   #552
ravenblackfrs
ravenblackfrs's Avatar
Drives: 2013 Raven Black FRS
I don't know what it means... but I like it!!! lol
Raven FR-S, Magnaflow Axel Back Exhaust, Airaid Intake.... Pending Dynojet for performance gains... Big wish list... just need money to do it!
ravenblackfrs is offline   Reply With Quote
Old 10-03-2013, 08:23 PM   #553
Stevo22
Stevo22's Avatar
Drives: GR86
My Driveway Labs aluminum rear diffuser arrived today. I'll be testing it at high speeds at my next track day at Road Atlanta at the end of October.
What group you going with?
Stevo22 is offline   Reply With Quote
Old 10-03-2013, 08:25 PM   #554
ATL BRZ
ATL BRZ's Avatar
Peachstate Porsche Club
Old 10-03-2013, 08:28 PM   #555
Stevo22
Stevo22's Avatar
Drives: GR86
Can you pm me the details? Would I be allowed to go. I think you have to pay a membership fee or something right?
Old 10-03-2013, 08:34 PM   #556
ATL BRZ
ATL BRZ's Avatar
PM sent with details. It has recently been the most popular event of the year so it may be sold out already.
It means the diffuser reduces drag, gets rid of all the lift the car generates stock at 100mph and makes measurable downforce on top of that, which translates into MORE GRIP!
Old 10-04-2013, 09:50 AM   #557
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Do want that diffuser. I was critical of the price originally, but now I think I really need it in my life.
Old 10-04-2013, 01:41 PM   #558
ATL BRZ
ATL BRZ's Avatar
All things considered after driving with it for a while I'd say it's definitely worth it. It's one of my favorite mods so far.
I bet it would look good in black against WRB.
Old 10-04-2013, 08:42 PM   #559
n8dog11914
n8dog11914's Avatar
Drives: 2013 WRB Subaru BRZ 6MT
Hey,
I was just wondering how your HC+800s are holding up to multiple track duty? Mine were fine for the first three months, but I am now experiencing increased noise, almost like a whistling sound after the pads heat up and the noise gets progressively noisier the longer you drive the car. Also, occasionally I am getting a little almost pad knockback at extremely slow speeds like when you apply that final touch to the brake petal to finally stop the car. Any ideas?
Thanks,
n8dog11914 is offline   Reply With Quote
Old 10-05-2013, 12:10 AM   #560
ATL BRZ
ATL BRZ's Avatar
I've upgraded my pads to the Club Racers. The HC+800's were a nice hybrid pad but they wore a little too quickly for my driving style on track. The fronts had about 5mm left after three track days and almost 2000 miles. They stayed quiet for me, I have no idea what's going on with yours. I'd check the supplied shims and maybe try swapping the OEM shims over on to them. The OEM ones look like they are better at keeping things quiet with two layers of material clipped on to the pads. Some brake parts cleaner may help if you just clean everything off including the surface of the rotors really good.
jdl turbo, mazworx, racecomp engineering, track build, verus engineering
Wnt3d's 86 - Turbo E85 Daily/Track Build wnt3d Member's Car Journals 77 07-17-2017 03:35 PM
No Limit Motorsport Full Blown BRZ Build No Limit Motorsport Member's Car Journals 16 07-08-2014 12:46 PM
