Old 03-07-2016, 05:11 PM   #43
denso
Drives: 86
Do you know how this adapter should look like or got some CAD stuff?
Nice stuff dude.
denso is offline   Reply With Quote
Old 03-29-2016, 09:15 PM   #44
Astroboy
Astroboy's Avatar
Drives: None
Updates
Sent from my LG-D850 using Tapatalk
Astroboy is offline   Reply With Quote
Old 04-08-2016, 10:09 PM   #45
turbov630
Drives: 2013 Scion FRS
I PMed you but your inbox is full
turbov630 is offline   Reply With Quote
Old 07-20-2016, 12:39 AM   #46
kask2_6.0
kask2_6.0's Avatar
Drives: 13 BRZ
It's been a while since I've updated this thread but the project is still going strong. I promise. Will have more updates to share in the coming week.
But I do have one really exciting update for today. @VeloxEric hooked me up with a prototype radiator!! This thing is awesome! It is a direct drop in replacement for the OEM radiator and the fit was absolutely perfect. This radiator uses a motorsport specific core technology that has a very high density. Because of it's ultra high efficiency construction a smaller, lighter core can be used and still be able to shed a massive amount of heat. The entire assembly without fans is only 5kg. It is the highest quality core I have seen this side of a $20k Mezzo unit. I don't typically share anything personal on the forum but to put this in perspective I feel like it should be noted that I spent years as a development engineer for what is arguably one of the most successful race teams in the world. Long story short, I've seen a lot of high quality parts. This ranks right up there with the best. I really hope it makes it to market because there is nothing else like it for this platform. Not even close.
Enjoy the pics!
Check out the difference in tube density between the CBR and Velox radiator. And the CBR is even much high higher quality than Mishimoto, etc.
About 2" additional clearance vs. oem shroud for those with a front mount turbo.
kask2_6.0 is offline   Reply With Quote
The Following 4 Users Say Thank You to kask2_6.0 For This Useful Post:
Draco_PR23 (07-20-2016), Guff (07-20-2016), new2subaru (07-20-2016), VerusEric (07-20-2016)
Old 08-06-2016, 12:13 AM   #47
kask2_6.0
kask2_6.0's Avatar
Drives: 13 BRZ
Ok some big news. I actually have real deadline now. Just registered for a dyno tune day for October 13-14! @DeliciousTuning
The Following 2 Users Say Thank You to kask2_6.0 For This Useful Post:
BigFatFlip (08-06-2016), DeliciousTuning (08-11-2016)
Old 08-10-2016, 01:08 AM   #48
kask2_6.0
kask2_6.0's Avatar
Drives: 13 BRZ
Made some really good progress this weekend. Welded an intercooler mount, mounts on the intercooler itself, and some piping. Also finalized a few drawings, confirmed fitment with 3D prints, and sent CAD to the machine shop. Getting real excited now things are coming together.
The Following 5 Users Say Thank You to kask2_6.0 For This Useful Post:
BigFatFlip (08-10-2016), Draco_PR23 (08-10-2016), Rosticles (08-10-2016), VABeachBRZ (08-10-2016), VerusEric (08-10-2016)
Old 08-17-2016, 11:27 AM   #49
kask2_6.0
kask2_6.0's Avatar
Drives: 13 BRZ
As of this weekend the BRZ is no longer my only form of transportation so now I can really get this project movin. It was quite the pain to have to start working on things Saturday mornings and have to put it back together Sunday nights to get to work Monday.
Neat shots showing design iterations of the turbo sump along with the final product (still needs AN bungs and the bottom welded on).
Exhaust mocked up and tacked together. Had to order a second regulator for my argon tank so I can back purge and finished welding everything.
The Following 9 Users Say Thank You to kask2_6.0 For This Useful Post:
Andew727 (09-13-2016), Astroboy (08-24-2016), ATL BRZ (09-16-2016), BigFatFlip (08-18-2016), DustinS (08-17-2016), prj3ctm4yh3m (08-17-2016), sato (09-25-2016), Sportsguy83 (08-25-2016), VerusEric (08-17-2016)
Old 08-22-2016, 04:08 PM   #50
AdamAnt
Looks really good. How low is the turbo? Could be the angle but looks like its a bit lower than the transmission.
AdamAnt is offline   Reply With Quote
Old 08-24-2016, 01:13 PM   #51
Astroboy
Astroboy's Avatar
Drives: None
Nice
Old 08-24-2016, 01:48 PM   #52
djwishbone
Last Starfighter
Drives: 2016 FR-S Series 2.0
This is my favorite location for the turbo. I look forward to seeing your dyno curve. Love the design so far!
Sent from my SM-G930T using Tapatalk
djwishbone is offline   Reply With Quote
Old 08-24-2016, 11:27 PM   #53
kask2_6.0
kask2_6.0's Avatar
Drives: 13 BRZ
It is a bit lower than the trans. Its tucked in behind and slightly higher than the steering rack though.
Old 08-25-2016, 12:11 AM   #54
kask2_6.0
kask2_6.0's Avatar
Drives: 13 BRZ
Got some more parts in from water jetting
Mini washer fluid reservoir to make room for Velox brake ducts.
Can even keep the stock fill tube!
Mount and fan assembly for huge 40 row oil cooler.
Cooler is behind the cooling stack so I'm not really sure if it will be enough to keep it cool but I figured I would give it a shot (air doing the cooling will be hot from radiator and intercooler). Others have been successful keeping FI cars cool with much smaller coolers BUT they are getting much cooler air out front. There are a few reasons I wanted to try this placement 1) I really like the packaging. Oil lines are even a direct shot. There won't be any possibility of them rubbing on something and eventually leaking. 2) Cooler is very protected. In the case of hitting debris on the road or even track I would much rather lose boost due to an intercooler leak than lose oil and a motor. 3) I want the intercooler to get as much cool air as possible.
ATL BRZ (09-16-2016), BigFatFlip (08-25-2016), cactus (06-06-2021), VerusEric (08-25-2016)
Old 08-25-2016, 01:26 AM   #55
JDLAutoDesign
JDLAutoDesign's Avatar
Drives: 13 FRS
Love the custom fab work! Wanna make a billet sump for a GTX series turbo ?
JDLAutoDesign is offline   Reply With Quote
Old 08-25-2016, 01:56 AM   #56
djwishbone
Last Starfighter
Love the progress. I also would like to keep my wash bottle around. Seems like a simple fix.
Considering a CSP Build from my STX twin.. Scooby South Tracking / Autocross / HPDE / Drifting 9 10-17-2015 12:10 AM
Best twin build performance wise? gt8613 BRZ First-Gen (2012+) — General Topics 9 01-19-2015 08:29 PM
- 86FLY - Australian Custom Turbo Jetkit 4.0 Build + Custom Flex Fuel Dyno Tune aaronsadventures Member's Car Journals 6 12-04-2014 03:01 AM
JET86. The Australian self built, twin charged build. jet86 Member's Car Journals 85 11-15-2014 05:35 PM
what's the difference between twin screw, centrifugal, single turbo and twin turbo? warplane95 Forced Induction 86 04-17-2014 03:36 PM
