| Member's Car Journals Car journals by our members. |
#43 |
Canada Eh!
Drives: '13 FRS
Got the chance to take the car our for a quick spin and test out the rigidity of the front splitter and mirrors... They didnt fall off so thats a good sign! lol Took a couple quick snaps while I had the chance... ![]() ![]() ![]() |
| The Following User Says Thank You to Joe-G For This Useful Post: | MisterSheep (02-16-2016) |
#44 |
Drives: 14' FRS
Hey can I ask for the tip size? Im looking get tips for my self, need to find the specs.
| The Following User Says Thank You to BTXP.XD For This Useful Post: | MisterSheep (02-16-2016) |
#45 |
Killed Scion
Drives: 2013 FR-S Whiteout
Can we get more pics of how that Sard wing looks on your car? Been considering the Sard wing with the TRD Japan lip spoiler but most people are doing it with the RS1.0 spoilers and yet to see it done with the TRD JP
Miyuki みゆき "Beautiful Snow" The Whiteout FR-S Instagram: trevor.parque |
#46 | |
Canada Eh!
Drives: '13 FRS
Don't have any specific shots, but I took these last weekend. ![]() ![]() ![]() ![]() |
#47 |
Drives: 14' FRS
Can I ask the size of those quad tips? Thanks
Sent from my SM-N910W8 using Tapatalk
#48 |
Canada Eh!
Drives: '13 FRS
DIY Homebrew Oil Cooler
Some of the pieces showed up for my homebrew oil cooler setup! ![]() ![]() ![]() ![]() ![]() Its only a 10 row oil cooler... The rest of the parts come in tomorrow. Should have it all installed by Saturday with some autocross testing on April 24th, and a track day on April 29th. ![]() |
#49 |
Canada Eh!
Drives: '13 FRS
Oil cooler install was successful! Although I think the thermostatic plate is rated to 160 F, which is quite low for our climate here. On what we would consider to be a warm day of 15-18* C, the oil temps would hover around 73-75* C (~160 F) on the highway.
I guess cardboard it is! Until I go to the track, or until we start seeing 25* C and up weather. On another note, I rebuilt my splitter out of aluminum composite (Polymetal), and cut some holes into my hood. (Post to follow) |
#50 |
Canada Eh!
Drives: '13 FRS
DIY Hood Vent
Decided to cut some holes into my hood to help with exhausting heat this season. I really liked the Velox hood louvers, but the budget is tight this year and I would rather put that towards more seat time rather than parts. If I pick up another hood, I think I would eventually get the Velox pieces. With how easy it is to cut the hood, the Velox louvers are actually quite nice. The new splitter material can be seen in the next few pictures. Materials - Aluminum flat bar - Aluminum angle - M6 hardware - Automotive rubber edge trim Tools Used - Angle grinder w/ 5" 1mm zip disk - Drill with ~6mm drill bit (will vary w/ hardware) - Hammer - Vice/Table to assist with bending Pulled off the hood ![]() What it should look like ![]() Marked out the location of the relief holes ![]() Drilled out the holes ![]() Marked out the lines ![]() And went to town with the zip disk! ![]() Made some relief cuts to allow for the bend... ![]() Cut the aluminum flat bar to length with the zip disk, drill a couple holes, and bolted it in place! It was a bit too long, and I had clearance issues with the intake so I ended up making it a bit smaller than pictured... ![]() ![]() ![]() ![]() With the aluminum angle sandwiched in place to act as wickers [/url]DSC_0764 by joeag., on FlickrPainted black.. but I actually ended up making another set out of 1/4" tall angle. ![]() Tried to do some testing without the wickers DSC_0791 by joeag., on Flickr![]() And did some more testing with wickers ![]() ![]() Decided to cut another hole just behind it. No pictures of the process, but it was very similar... Also installed some automotive rubber edge trim for the street. Wickers can be sandwiched into place for track days/autocross. ![]() ![]() ![]() ![]() ![]() And now to polish the hood... |
#51 | |
Canada Eh!
Drives: '13 FRS
I believe they are 3.5" outlets |
| The Following User Says Thank You to Joe-G For This Useful Post: | BTXP.XD (04-13-2016) |
#52 |
what made you decide to change the intake? thoughts on the grimmspeed vs. HKS?
| My Journal | Weasel Soup | Member's Car Journals | 27 | 10-03-2016 05:07 PM |
| < RYO > Car Journal | RYO | Member's Car Journals | 3 | 04-16-2015 01:48 PM |
| EWY's Raven FR-S Build Journal | EWY | Member's Car Journals | 22 | 02-25-2015 10:30 AM |
| 1 SIK FRS Raven FRS Build Journal | 1SIKFRS | Member's Car Journals | 20 | 01-19-2014 03:58 AM |
| Duder's BRZ Mod Journal | duder | Member's Car Journals | 17 | 06-26-2013 11:54 PM |
