Old 02-06-2018, 10:32 PM   #43
churchx
churchx's Avatar
Drives: 2014 GT86
pros:
- probably 60-80%? gain of aftermarket catless ones
- cheapest performance oriented "upgrade" (if one leaves aside need to get some ECU upgrade to disable CELs)
- 100% stock looking, for where there are visual checks during MOT testing
cons:
- less performance gains. If NA tuning already is expected to be limited & expensive, why not try to get most what's possible for not that big of price vs some other possible mods?
- no completely stock & with functioning cat header left to bolt back, in case if it's needed to pass MOT or to be put back prior selling off car
churchx is online now   Reply With Quote
Old 02-08-2018, 04:40 PM   #44
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
If this is collapsible then I would shove this in where the cat was like deploying a stent in an artery versus trying to weld in a pipe if I was looking to get better flow while remaining stealthy.
Old 02-08-2018, 05:53 PM   #45
bfrank1972
Drives: 2013 FR-S Argento
On the expense side, a person would really be 'splitting hairs' vs a used aftermarket header. You can pick up a good aftermarket header used for around $400+/- some, and then you still have the OEM header intact if you want to return it to stock (or sell it for $50-$100). Paying someone to remove the cat and weld in an new pipe will be a couple hundred bucks at least. If you do the screwdriver + hammer method, that works, but flow is even less ideal and I hear it sounds pretty bad due to the resonance in the empty cat area.
bfrank1972 is offline   Reply With Quote
Old 02-08-2018, 06:10 PM   #46
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Are you guys referring to the first post? Difference is 12whp and most of it is from the tune (~8whp). It is not from the gutted header and the front pipe. Aftermarket catless headers might give more, but it is because of the better header design and not the catalyst. Don't try to mix apples and oranges.
Old 02-08-2018, 09:44 PM   #47
bfrank1972
Well part of it is the cat - the big thing with headers on these cars is removal of the torque dip. The first post shows that a decatted stock header can do that - a tune by itself can't do that to the torque dip. That said, for marginally more money you could have a better design, and a spare stock header.
Sent from my SM-N920V using Tapatalk
Old 02-08-2018, 10:40 PM   #48
ApexEight
Drives: 2014 Subaru BRZ Limited 6MT SSM
But the curve looks much better. Idk if that has to do with just the tune, but I would imagine the gutted cat helped with that. The curve is more important than peak gains.
ApexEight is offline   Reply With Quote
Old 02-08-2018, 11:16 PM   #49
Irace86.2.0
Cost is one factor. I’m not an advocate of removing the cats, yet regardless of my opinion, some may wish to remove the cats, but are afraid to run catless. Fines in California are really expensive. A way to reduce the risk is to gut the cat or weld in a straight pipe. Welding in a straight pipe won’t fool an officer looking for a straight pipe (maybe I’m wrong, maybe the heat shield would cover the section that was modified). A gutted cat would be about as stealthy as someone could take things.
Back to the mod, I wonder if boring the cat would be better to be able to press fit a straight pipe in the center. Basically leave the surrounding cat intact. Ideas?
Old 02-09-2018, 02:01 AM   #50
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Sure gains in the dip area are much better. Personally, I never worried about the torque dip. I guess it is the way I drive the car and my focus on a track oriented setup (peak gains at high revs).
Old 02-18-2018, 04:16 AM   #51
Harey
Drives: 2013 Toyota 86
Not a single corner falls below 4750rpm? They say the fastest way around a corner is most of the time to stay in the higher gear.
Harey is offline   Reply With Quote
Old 02-18-2018, 08:40 AM   #52
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Depends where you drive. If you want to go fast on a track or on an autobahn without speed limits, then you'll be above 5000rpm. If you want to go fast on a country b-road, I agree that many times you'll be below 4750rpm. However, you are already going fast and going faster means you don't obey any speed limits and you take too much risk to lose your car. This is not an AWD car and requires a lot of skill and risk to go really fast in anything than perfect tarmac. The only area I can think mid-torque improvement can help is on drag racing from stop.
Old 02-18-2018, 03:38 PM   #53
Harey
I take mine to a race track (Phillip island, Australia) and there are at least 2 corners that rpm drops into the low to mid 4krpms.
Old 02-18-2018, 05:19 PM   #54
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
If your rpm's are so low and you are in the correct gear, then you need to change your final drive ratio to a shorter one. Maybe a 4.55 will match good on such track. It always depends the track. It is not optimal to solve your issue by eliminating the torque dip. No matter how good is the curve in the mid rpm's, you won't get the maximum acceleration. You'll need to have the revs on the higher end area for the best acceleration.
Old 02-18-2018, 09:17 PM   #55
Lantanafrs2
Drives: 2013 frs red
Sheesh I'd rather swap a header than rear end gears
Old 02-19-2018, 11:44 AM   #56
ApexEight
What's that guy's deal lol. Better change your final drive bro, he says you need to
Best Catback/Front Pipe/Over Pipe/Header Combo for the BRZ? O.Z. BRZ Engine, Exhaust, Transmission 22 04-17-2019 09:44 AM
Ceramic coating header only vs header/over pipe/front pipe pixel67 Forced Induction 8 08-18-2015 02:39 PM
FS: OEM FRS/BRZ Header w/ Gutted Cat malubawla Engine, Exhaust, Bolt-Ons 10 06-06-2014 11:29 AM
RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP NickFRS Engine, Exhaust, Transmission 44 04-19-2014 05:42 PM
Gutted cat stock header vs aftermarket catless header NA application stevo585 Engine, Exhaust, Transmission 8 04-04-2014 04:12 PM
