Old 10-05-2015, 01:05 PM   #43
wparsons
wparsons's Avatar
Those other "quiet" exhausts are not quiet enough for our requirements.
What sound level are you trying to hit? Assuming you're trying to hit the sound requirement fully catless, right?
flickr
Old 10-05-2015, 01:06 PM   #44
Correct!
We want to be under 90db from 30 feet away, 30 degrees offset to the passenger side, without cats, boosted.
Even with this hard requirement, the muffler will NOT cause a power loss with an NA car; it flows more than enough. The challenge for us is to not lose any power with a FI (supercharged) car
Old 10-05-2015, 01:58 PM   #45
wparsons
wparsons's Avatar
90db is a lofty goal, but if it works out that'll be awesome for tracks with tight requirements.
flickr
Old 10-05-2015, 02:36 PM   #46
BRZoomTX
BRZoomTX's Avatar
Drives: '13 BRZ
Correct!
I'd imagine that goal would be much easier on a turbo car. This is a very attractive muffler for me as I am over loud exhausts. Will there be a full 3" version?
The tips need to be raised up as well. They are very low IMO and make the rear look very "off".
'13 WRB BRZ ~470whp // Instagram // YouTube
BRZoomTX is offline   Reply With Quote
Old 10-05-2015, 03:30 PM   #47
churchx
churchx's Avatar
Drives: 2014 GT86
If 10db is twice perceived loudness .. 90 vs 96 of +6db is BIG difference and harder bar to hit. Anyone knows stock or Q300 levels for comparison sake at similar 30ft/30deg offset/catless/boosted?
Old 10-05-2015, 05:43 PM   #48
It's not a lofty goal; it's mandatory to run at Laguna Seca.
There are a TON of creative solution you see there, and many series have "Laguna Seca Spec" or "Laguna Seca Special" mufflers that they run ONLY at Laguna Seca, and many of these cars have higher output than we do.
It can be done
Old 10-05-2015, 05:43 PM   #49
without cats it is over 100db.
Old 10-05-2015, 05:48 PM   #50
It won't be released until it's perfect
A turbo car will absolutely be quieter than a NA or SC car.
3".... if there is enough demand, possibly, but I'm not sure we can hit 90dB with a 3". From other platforms, we already know that a 63mm exhaust can support 500+hp with virtually no power loss on a NA/SC car. Turbo cars, love large exhausts, and somewhere a compromise will need to be made.
Old 10-05-2015, 06:17 PM   #51
BRZoomTX
BRZoomTX's Avatar
Drives: '13 BRZ
No big deal if it weren't able to get 90db on 3". This still seems to be one of the quietest aftermarket mufflers (potentially soon to be) available so far.
I would definitely be interested in a 3" option regardless of what actual sound level you are able to get out of it. The CX kit came with 3" back to the cat-back position so its just a preference to keep the exhaust all 3". Otherwise I agree 2.5 would be sufficient.
If you guys need a catless turbo car with full 3" exhaust for sound level testing....
Old 10-05-2015, 06:55 PM   #52
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Originally Posted by Jrdad View Post
How does this compare to the stock muffler?
Originally Posted by olsonpg View Post
Yeah does anyone know stock exhaust sound level in db?
Stock is (quoting Fujitsubo site):
http://www.fujitsubo.co.jp/prods/det...04741/00001474
Idle 61dB
5250RPM 82dB
3000RPM 73dB
4000RPM 80dB
2000-4000RPM "response" 87dB (most likely revving engine in this range)
Old 10-05-2015, 11:30 PM   #53
churchx
churchx's Avatar
Drives: 2014 GT86
mav1178: any numbers should be accompanied by nfo how loudness was measured. For example for this Fujitsubo data how can one know distance (which can change measurements a lot) at which those numbers were seen? Hence one cannot gauge what these dBs mean vs 90dB mentioned earlier.
Old 10-06-2015, 10:04 AM   #54
Wepeel
Drives: '13 BRZ Ltd
Really interested in this. Is it safe to assume that with a fully catless setup, a Perrin 2.5 resonated or Q300 would exceed 90dB?
Wepeel is offline   Reply With Quote
Old 10-06-2015, 11:14 AM   #55
It's not an assumption; I've seen cars fail the sound check at Laguna Seca.
Old 10-06-2015, 12:52 PM   #56
Jrdad
Jrdad's Avatar
Drives: 2013 Scion FR-S 6M Argento
Fwiw a stock c7 with dual mode exhaust hits ~96db
Jrdad is offline   Reply With Quote
FNA rear fog light Kit 1 w/high power LED HATED1 Exterior Parts (Aero, Lighting, Etc.) 5 02-09-2015 04:31 AM
HKS High Power Spec-L Ti-Tip Tien Engine, Exhaust, Transmission 0 10-23-2013 11:54 PM
Mach V muffler delete prototype Mach V Dan Engine, Exhaust, Transmission 118 02-01-2013 07:41 AM
5W High Power CREE LED Zoomryder Cosmetic Modification (Interior/Exterior/Lighting) 0 09-21-2012 06:30 PM
