Old 02-18-2016, 04:37 PM   #43
fumanchu1
Drives: 2013 Brz C38 (bought not built :P)
Originally Posted by morswestford View Post
Well I think i finally fixed my broken belt issue. My car guy had re-tensioned the belt and went down from 17mm down to between 11-12mm (after driving about 200 miles), as per the exact instructions from Kraftwerks.
But now my car is making really high pitched squealing sounds. It's embarrassing. It does this when going down below 1k RPM to idle.
My car guy put in rotrex traction fluid, but that didn't do anything.
I went on youtube and saw other kraftwerks videos, and nobody else has any high pitched squealing sounds. does anyone know what this is about and how to fix it?
i sent an email to kraftwerks about it and i am waiting for them to reply.
From memory you may have overtensioned your belt and that may be the cause of the squealing. or like ATL said the unit itself may be on it's way out
I will recommend that everyone use the Gate app. Some said it didn't read proper frequencies but that's because their belts are too loose to even get good readings off of.
BTW I have a KW C38 kit and never snapped a belt (nor has the previous owner) they are very finicky and really need to be set spot on to avoid potential breaks
fumanchu1 is offline   Reply With Quote
Old 02-18-2016, 04:39 PM   #44
fumanchu1
Originally Posted by ATL BRZ View Post
Sounds like the SC itself has failed internally. Check this out, same compressor: http://www.ft86club.com/forums/showthread.php?t=99677
Might be warranty time. Which means taking the SC off the car, sending it to KW who have to send it to Rotrex in Sweden for inspection and either approving or denying the warranty.
are they in Sweden or Denmark? I see those two thrown areound when speaking about Kraftwerks
Old 02-18-2016, 05:20 PM   #45
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Just checked. Denmark. Will edit.
Old 02-18-2016, 05:28 PM   #46
fumanchu1
I mean Scandinavia anyways but for the sake of correctness
Old 02-18-2016, 05:44 PM   #47
morswestford
morswestford's Avatar
Drives: 2013 Subaru BRZ
how can the unit be on its way out if i have less than 1k miles on it? how is that even possible?
and i followed the tensioning instructions exactly given to me by the engineering dept of krafwerks,
they said tension the belt between 16-18mm, then drive a few hundred miles and re tension it down between 11-13mm, which is exactly what i did.
so i dont understand how i could be having this squealing sound from an overtensioned belt if i followed the exact instructions from kraftwerks.
morswestford is offline   Reply With Quote
Old 02-19-2016, 12:56 AM   #48
86Tony
Drives: 2015 AOZORA EDITION
after reading all this ima stay away from kraftwerks on the fa20 platform. i kno they are great on the honda platform but this is some serious issue
86Tony is offline   Reply With Quote
Old 02-19-2016, 07:29 AM   #49
morswestford
Well i got a reply back from Kraftwerks.
They said "The whine can only be one of two things… either the idler pulley bearings are finally reaching their threshold after going through belts, tensioning, re-tensioning, belts, etc. or the supercharger has internal bearing issues but usually those are much higher pitched so my initial thoughts would point towards the idler pulleys."
they are sending me a replacement for the pulley bearings.
I hope that fixes the problem and it's not anything more serious.
Old 02-20-2016, 04:56 PM   #50
morswestford
well im waiting for kraftwerks to send me the replacement pulleys.
meantime today i was driving on the highway. I went about 10 miles. All of a sudden i heard no more loud squealing sounds when downshifting. I thought, great maybe it just went away. But i also felt i had no more boost. I thought maybe those pulleys stopped working or something.
I got home, popped the hood and saw the belt snapped, laying there at the bottom of my vehicle. Unbelievable. This is my 5th broken belt!
This is unbelievable. I emailed kraftwerks again and now im waiting their reply. I followed their EXACT tension instructions. Someone Please tell me how this could possibly happen? Now I have another broken belt. I cannot get anywhere with this supercharger. Broken belts. Loud squealing sounds from the pulleys.
I thought the belt issue was resolved. Then had the loud squealing sounds from the pulley. Fail. Everything in this system seems to be failing. I haven't even gone 1k miles in it. I have yet to enjoy it and it just keeps breaking on me.
Everything was tensioned correctly and it failed yet again. When i thought one thing got fixed, another thing happens with the squealing from the pulleys. This system is terrible Terrible design, terriblly finicky with the tension, and i cannot keep wasting my life away dealing with troubleshooting this system to get it working. I've spent so much time here and nothing is working.
I wish they would just replace the entire system or refund me. I am wasting my life away trying to get this system to work.
Old 02-20-2016, 06:41 PM   #51
Bykov
Drives: 2014 Monogram FR-S Whiteout
With a manually tensioned system you cannot rely on their instructions, only on equipment designed to measure belt tension by frequency. I am sorry to say that I personally think you will not find a resolution for your system. It needs constant monitoring and adjusting unlike a system tensioned by the OEM tensioner, which is the route I recommend you take. It will fit your wants a little better as you never have to tinker with belt tension. No other system on the market is known to consider belts as a consumable (except maybe the early vortech kits). So that leaves JRSC, Innovate, and Edelbrock systems. All very good options so you don't have to give up on FI.
Bykov is offline   Reply With Quote
Old 02-21-2016, 12:51 PM   #52
morswestford
i agree, it's a horrible design to have a system that needs to be constantly monitored all the time. who wants to deal with all that? i am just following the recommendations from the engineering department of kraftwerks. i assume they would know the exact tension requirements. but honestly i don't know anymore given the fact i followed the instructions and my belt failed again.
Old 02-21-2016, 06:17 PM   #53
Bykov
That's the thing. They wouldn't know the correct measurements for your car. They know the correct tension but the measurement can be different from car to car and belt to belt. 22mm could be perfect for you and 17mm for me. Eventually the belt will settle and the system becomes really low maintenance and reliable but most people will break the belt before it ever does. I recommend you get another kit. I know it sucks but I promise you would be happy with anything else out there. Read the owner's threads for every kit and the SC comparison thread. I did and that's where you can get a real feel for the kit. Vendors will always prefer what they sell.
Old 02-21-2016, 06:49 PM   #54
morswestford
how could they make a kit for this car if the measurements are different from car to car? i don't understand that. shoudnt the belt work for all brz/frs work equally?
and as for the tension, they said to start at 17mm, then drive a couple hundred miles then tension it again at 11mm, which is what i did and that failed.
now that 4th belt broke, i have to start the tension process all over again, and i wonder where should i start and end at now, given their instructions are wrong.
Old 02-21-2016, 07:06 PM   #55
scarfo
Drives: gts 86
Use the harmonic app this time.
scarfo is offline   Reply With Quote
Old 02-21-2016, 07:38 PM   #56
Bykov
I don't know either but they did and people bought it. It is what it is. I honestly was going to buy it but it took them far too long to get CARB approval. Use the app and that is your best hope of making it work for you because changing out kits will cost you a pretty penny.
Kraftwerks Review projek_01 User/Vendor/Sponsor Reviews, Feedback, Comments 0 07-23-2015 03:44 PM
SOS. Monterey area. Belt tensioner/belt The Racers Line Northern California 11 04-06-2015 02:33 PM
DPS Kraftwerks Scion FRS - KW / Invidia / Kraftwerks / Enkei rickspecd Member's Car Journals 40 06-26-2014 12:42 PM
