Old 09-28-2015, 11:06 PM   #43
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Originally Posted by Racecomp Engineering View Post
A lot of it will come down to alignment and making the most of the tires as you can.
Originally Posted by mav1178 View Post
GOSPEL RIGHT HERE.
Praise jebus
The Following User Says Thank You to cdrazic93 For This Useful Post:
Racecomp Engineering (09-29-2015)
Old 09-29-2015, 02:07 PM   #44
Originally Posted by Calum View Post
I just measured and inspected. I've got about 2500-3000 Kms on this setup. (Revelent stuff; MPSS, 2.5 camber, and 5.5 degs caster, 0 toe). I'm down a 32 on the inside vs the outside, but there's no gum balling or anything that would indicate too much heat.
I'm not trying to flame, just trying to add info to the subject.
You could use a little more caster FYI.
- Andy
Old 09-29-2015, 02:32 PM   #45
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Originally Posted by JEDI View Post
I think out of the box this car is great. I did notice my 13 stock FR-S tended to or was easier to slide around compared to my RS1.0, and the only difference between the two cars mechanically is the TRD springs as far as I know. Anybody know spring rate for the TRD's? Where's it better to start? Tires, Springs, or alignment? When it comes to chassis tuning. Not trying to thread jack. I cant wait to do some mountain driving with some sticky tires.
It's different, they changed frs damper to closer to brz setting starting 2015.
Old 09-29-2015, 03:00 PM   #46
strat61caster
strat61caster's Avatar
- Andy
Curious, what performance benefit is there to increasing caster on this car? I just moved mine up with the Raceseng CasCams from 5.9 to I suppose 6.9 degrees, the steering feels heavier but I don't like it, it almost feels like an artificial weight with no benefit, I'll drive it hard before I go back to be sure but so far I'm not a fan.
ineedyourdiddly
Old 09-29-2015, 03:10 PM   #47
Basically, as you turn the steering wheel your outside tire loses negative camber (even without body roll). More caster limits this effect. It's noticeable mostly in tighter corners with lots of steering input.
Steering feel does get a little weird with higher values. Some really don't like it, other's don't mind it.
- Andy
The Following User Says Thank You to Racecomp Engineering For This Useful Post:
strat61caster (09-29-2015)
Old 09-29-2015, 03:11 PM   #48
Calum
That Guy
Drives: 2013 asphalt FRS MT
- Andy
You're killing me Andy.
I have the whiteline caster bushings. I'm honestly not sure what finally the number is, but I think it was ~5.5 deg.
I've replaced my strut mounts 13 times. I have no desire to do it again. At this point unless the extra camber and caster from an adjustable mount is going to give free felatio every time I get in the car, I'm gonna stay with the group n mounts.
How much were your new mounts again?
Old 09-29-2015, 03:22 PM   #49
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
Drives: '13 Whiteout FR-S A/T
With the exchange rate the way it is, WAY too much $$$ now.
-Me loving 7.0 caster
drewbot is offline   Reply With Quote
The Following User Says Thank You to drewbot For This Useful Post:
Calum (09-29-2015)
Old 09-29-2015, 03:35 PM   #50
strat61caster
- Andy
I'll stick with it for awhile, thanks.
I want to say mine were at least 5.5 or 5.9 OEM everything, I think you might be misremembering...
ineedyourdiddly
Calum (09-29-2015)
Old 09-29-2015, 05:39 PM   #51
$419.
Maybe try that 16mm rear bar first.
I agree, that seems a bit low if you have the WL caster bushings.
- Andy
Old 09-29-2015, 05:56 PM   #52
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
One other possible drawback is overworking the onboard power steering, increased caster does put more stress in the steering system.
Given that a handful of us were able to overheat the electrical power steering by simply running R-comps, it may make it worse.
-alex
The Following 3 Users Say Thank You to mav1178 For This Useful Post:
Calum (09-29-2015), Racecomp Engineering (09-30-2015), strat61caster (09-29-2015)
Old 09-29-2015, 06:56 PM   #53
strat61caster
-alex
It definitely feels like I'm overworking the steering for no good reason, but that's probably just my mind making stuff up.
ineedyourdiddly
My quest Rocket.BRZ Off-Topic Lounge [WARNING: NO POLITICS] 46 09-08-2014 07:23 PM
Quest for the 86 Calls44 Member's Car Journals 10 05-15-2014 06:09 PM
Never ending quest for more TylerLieberman Off-Topic Lounge [WARNING: NO POLITICS] 5 10-17-2013 04:52 PM
My quest for a BRZ in China is over! Godzpeed Other Vehicles & General Automotive Discussions 9 08-13-2012 05:17 AM
