Old 09-30-2015, 08:02 PM   #43
dallenj
Drives: Grey FR-S
Originally Posted by justinsstang View Post
I really wish they would put a real motor in these cars, or a lower compression turbo setup from the factory lol.
16second quarter mile is just ridiculous. I know they didn't make it for drag but come on SUVs and trucks run that
The reason why they are slow is because its a tuner car. If you want a fast car car make it if you just want a good well rounded sports car dont do anything.
dallenj is offline   Reply With Quote
Old 10-26-2015, 06:00 PM   #44
DHitHim
Drives: 2015 CWP Limited BRZ
I want to do a 50 shot too. I have a 20lbs bottle that has been sitting for a few years that was supposed to be for my other project.
DHitHim is offline   Reply With Quote
Old 10-27-2015, 02:22 PM   #45
Spartarus
...Just add nauseum
Spartarus's Avatar
Drives: 2003 (AP1) S2000
Just want to fix a few bits of your build.
Originally Posted by dallenj View Post
With that built engine I will be reving to 9000.
The oil system in this engine will not support 9000 rpm. 8200 is as high as you can go without extensive and highly impractical modification.
3 inch exhaust will not help you with your build. It will make less power than a properly tuned 2.5. I can explain why if you want (there are builds where 3in. is a great idea. Nitrous and high compression with no FI is not that build).
I really am thinking about that going a straight nitrous build. I even wanted to go higher compression on my engine, but I want to see the development of a inew intake manifold first. I think ft86club is working on one and so is fbm. Want to see those first. Like I said in the post this is a changing build right now
You're right about the stock intake manifold. Something will have to be done about that. The FBM manifold is developed already, and will not help you with a naturally aspirated configuration. The Velox/Ft86SF manifold did not initially see favorable results NA.
Axles fine. Driveshaft unnecessary.
Also clarifying the term "build thread." those go in the "members car journals" subforum.
There are many ways to displace.
-Spartarus
Spartarus is offline   Reply With Quote
The Following User Says Thank You to Spartarus For This Useful Post:
ATL BRZ (01-11-2017)
Old 10-30-2015, 12:44 PM   #46
dallenj
Drives: Grey FR-S
I have been looking at an element Tuning engine and they do oil system work that will allow the car to rev upto 9k rpm. The 3" exhaust is incase I end up going turbo, if I go that route I dont want to buy all new componets, but I want to get the most out of this car with just nitrous before I do anything else. Thanks for the input.
Old 01-10-2017, 07:26 PM   #47
dallenj
Drives: Grey FR-S
Update on the nitrous car. Just got up on the Dyno with a 75 shot. Fuel solenoid went out before I could do a full test. When I get that fixed I will be posting another update.
The Following 5 Users Say Thank You to dallenj For This Useful Post:
chaoscentral (01-11-2017), COO86L (01-11-2017), Lonewolf (01-10-2017), mrk1 (01-12-2017), new2subaru (01-11-2017)
Old 01-11-2017, 11:43 AM   #48
chaoscentral
Drives: 2013 Scion FR-S Series 10
Who did the tuning for that?
Current Mods: Eibach Sportlines/ Borla UEL Header/ Invidia N1 Catback/ OFT Stage 2 UEL E85 Tune/ Enkei EDR9 18x7.5
chaoscentral is offline   Reply With Quote
Old 01-17-2017, 08:32 PM   #49
dallenj
Drives: Grey FR-S
Abel Racing in Midwest city, Oklahoma.
The Following User Says Thank You to dallenj For This Useful Post:
chaoscentral (01-17-2017)
Old 01-18-2017, 08:10 PM   #50
Kris86
Kris86's Avatar
Drives: RHD Gt86
Let's see some videos of her driving
Toyota - Making Dreams A Reality
461hp on 91octane - JDL turbo GTX3076r GEN 2 - Mazworx CD009 transmission
Kris86 is offline   Reply With Quote
Old 01-18-2017, 09:11 PM   #51
mrk1
Drives: Sterling BRZ Ltd
Awesome
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 01-19-2017, 11:52 AM   #52
dallenj
Drives: Grey FR-S
Unfortunately my car is down for a little bit. I am having a fuel pressure problem. My fuel solenoid for my nitrous injection is lagging and causing me to lean out. My fuel pressure is to high since I installed a dw300c fuel pump. I'm going to rewire my kit and install a fuel pressure regulator to drop my fuel pressure below 70 psi so my solenoid will operate correctly. More info coming soon.
Old 01-25-2017, 01:16 AM   #53
dallenj
Drives: Grey FR-S
Here is a quick video of my car running what do you guys think is wrong? My local group says its an exhaust leak.
Old 01-25-2017, 09:21 AM   #54
chaoscentral
Is there any new smoke? Throwing codes? Any oil on the ground? At first listen it sounds like a horrible exhaust leak. But without knowing the full picture it is hard to diagnose.
Old 01-25-2017, 10:35 AM   #55
dallenj
Drives: Grey FR-S
no smoke no oil
Old 01-25-2017, 10:57 AM   #56
chaoscentral
are you able to tell if the sound is coming from the valve cover or not? only things i can thing of with that sound is either valvetrain or exhaust, and unless you ripped off half the exhaust without knowing I kind of doubt it is that. if you can't figure out where the sound is coming from try using a big screw driver as a stethescope to locate the sound. I know some of the 13s(if you have a 13 that is) have some rocker issues, but do you know when this started happening?
Nitrous setup Subaru86 Engine, Exhaust, Transmission 6 08-03-2015 01:54 AM
Nitrous build dallenj Forced Induction 34 08-01-2015 03:27 AM
nitrous? ender2664 Forced Induction 48 06-13-2015 10:36 PM
Anyone running with Nitrous? JDMenrique Forced Induction 29 10-21-2012 10:02 PM
nitrous eindio Forced Induction 17 09-22-2012 01:09 AM
