Old 09-27-2015, 05:56 PM   #43
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Ok, so a while back I threw a code which said something about the injectors. P1170 to be exact. Now, when it came on I was using cruise control. Recently I was driving with it on again, and once more the same problem happened. So I conducted an experiment by driving the same distance I did the previous times without cruise control. Nothing happened. I believe it has something to do with the tune so I'll need to contact Cosworth to figure it out.
Of course, if you don't put it on cruise control, it never comes on and there are no issues. I'll figure something out.
MS, CSCS, TSAC-F, CPT
Old 10-02-2015, 02:06 AM   #44
TxFrs10
TxFrs10's Avatar
Drives: 10 series fr-s
Originally Posted by weederr33 View Post
Ok, so a while back I threw a code which said something about the injectors. P1170 to be exact. Now, when it came on I was using cruise control. Recently I was driving with it on again, and once more the same problem happened. I'll figure something out.
Same thing happened to me. It felt like it wanted to shut down for a sec then came back. I doubt it would change anything but have you tried it in a different map setting? They said to make sure the wiring wasn't pinched next to the cpu box. Let me know what you find out.
TxFrs10 is offline   Reply With Quote
Old 10-02-2015, 09:36 AM   #45
weederr33
weederr33's Avatar
I believe the first time I was on map 2 (93 octane), and the second time I was on map 1 (91 oct). I didn't look for any pinched wiring so I'll have to take a look.
Old 10-02-2015, 05:29 PM   #46
Ernie L
Ernie L's Avatar
Drives: 2014 BRZ black premium
Current Owners:
weederr33 - Cosworth Stage 2.3
@Ernie L
@enigma
don't forget JerryIII
♠♠♠88
Ernie L is offline   Reply With Quote
Old 10-06-2015, 12:51 PM   #47
350matt
Drives: toyota mr2/ Toyota GT86
any news on this chap? was the injector wiring / connector being pushed off?
350matt is offline   Reply With Quote
Old 10-06-2015, 01:02 PM   #48
weederr33
weederr33's Avatar
I hadn't seen anything wrong. I didn't see wires touching (that would cause any shortage), nothing seemed "pinched" and the injectors are fine. Personally I blame the tune. However, I don't see the harm in staying off of cruise control. As long as I don't use it, there are no problems. Though, some data logging may help to illuminate any issues.
Old 10-08-2015, 12:11 AM   #49
Insurme1
Drives: 2013 Scion FR-S 10-Series
I had my sensor there too and the s/c flattened it.
Insurme1 is offline   Reply With Quote
Old 10-11-2015, 05:29 PM   #50
weederr33
weederr33's Avatar
I'm thinking about adding larger injectors, and fuel pump because I may go flex fuel. Do you guys think just the injectors and pump will yield any extra power despite the pulley staying the same?
Old 10-12-2015, 12:00 PM   #51
350matt
until you go over to E85 then don't expect any power increase just from the larger injectors
as you won't be on the limit of the standard parts just yet
and you'll need a re-tune when you increase the injector size as the Pfi part will be all screwy
interested to see what she'll do on Corn juice though
300+ Whp?
Old 10-12-2015, 12:05 PM   #52
weederr33
weederr33's Avatar
300+ Whp?
Well my ultimate goal is 320-325 hp at the crank. I don't care really about making insane power. So I'm thinking I could make that with E85 or even a mixture like E50. But longevity is important, too, as I don't want to be that ricer whose always saying their car is in the shop because of some BS, despite bragging about my power.
Old 10-12-2015, 12:59 PM   #53
350matt
I think delicious tuning was talking about developing an E85 tune for this kit, might be worth giving them a call
Old 10-20-2015, 08:44 AM   #54
JerryIII
Drives: Subaru BRZ
I popped codes with and with out the cruise on. Post catalyst trim to lean bank 1 only when it seem to not be under power? Never at the track. just recently the throttle/pedal position sensor/switch "A,B,E,D" CEL came on during my autocross run cleared the code and seems to be running fine now. Has any one else had any problem with the packing coming out from their exhaust?
JerryIII is offline   Reply With Quote
Old 10-20-2015, 10:33 AM   #55
weederr33
weederr33's Avatar
I recently threw the lean bank 1/ running lean code when I was driving home from work. Cleared the code, checked the charge pipe and connections since I changed the filter recently. Runs fine. I tried to contact Cosworth but haven't heard anything yet. Maybe someone else can try?
Old 10-20-2015, 05:03 PM   #56
350matt
might be worth contacting Nameless about the exhaust as they make it for Cosworth so their gaurentee should still apply
Jackson Racing Supercharger Owners Thread enivid Forced Induction 6049 06-25-2026 10:40 PM
Kraftwerks Supercharger Owners Thread projek_01 Forced Induction 4310 04-07-2025 01:12 PM
HKS Supercharger owners thread wbradley Forced Induction 1054 10-26-2024 01:18 PM
Phantom FTS Electric Supercharger Owners Thread TM Forced Induction 1206 12-15-2019 02:33 PM
Supercharger Kits! Vortech/Cosworth RallySport Direct Forced Induction 61 06-29-2015 11:26 AM
