#43 |
Drives: 2022 BRZ Limited
he's been monitoring the temps at the track day but I am not sure if the real effects can be observable completely..
for me there's no voodoo magic, if it doesn't crack and allow smoother/faster flow it's fine, I tend to keep my expectations low
#44 |
Drives: 2013 Black FR-S
Destroyed my stock header a few days after going turbocharged.
#45 |
thanks for the feedback
![]() what have you been running since then?
#46 |
JDL uel for a long while. Now I'm back to NA.
#47 |
you had a turbo setup, correct?
#48 |
He had a ptunning kit
2013 Series 10 FRS #553
#49 |
Drives: 2016 FR-S
So, which aftermarket header is a good choice for the JRSC CARB version?
#50 |
No rice, no life
Drives: 2013 Asphalt FR-S
If you're getting an aftermarket header, you should really ditch the CARB tune. It's designed specifically for the OEM exhaust.
2013 Asphalt Scion FR-S | Jackson Racing Supercharger | KW V3 | Enkei RS05RR 18x9.5
#51 |
None. Unless you ditch the carb tune. Then id recommend the ACE header which has been dyno proven with the JRSC to make delicious power by Delicious Tuning. Check the ACE header thread.
#52 |
#53 |
Drives: 2016 FR-S
So one just has to deal with cracked stock headers...
#54 |
No rice, no life
If you crack your header with the CARB tune then congratulations, you're the first. A lot of R&D went in to making it as reliable as possible for both street and track use. In fact I've never even heard of headers splitting open before this thread.
#55 |
it's been already noted that it has nothing to do with the quality of the tune and even Some stock cars had this issue
#56 |
This is not a tune issue, but a stock header issue.
| Looking for used aftermarket exhaust or header | vitti821 | Want-To-Buy Requests | 1 | 04-07-2015 10:58 PM |
| Who has Open Flash Header (or aftermarket UEL header) in the GTA with stock exhaust? | alanhung85 | CANADA | 6 | 10-21-2014 10:41 PM |
| WTB: Aftermarket Header | Akari | Want-To-Buy Requests | 1 | 08-08-2014 12:57 PM |
| Gutted cat stock header vs aftermarket catless header NA application | stevo585 | Engine, Exhaust, Transmission | 8 | 04-04-2014 04:12 PM |
| Aftermarket Header help!!!! | chiefshayan | Engine, Exhaust, Transmission | 20 | 11-20-2013 02:32 AM |
